145 user(s) are online (87 user(s) are browsing Forums)
JeffK Barely used EGR Valve
High Point, NC
1440 Posts
Bought it from Rockauto for $60 then found out that my solenoid was the culprit so I bought headers and deleted the entire system.
It was on my car for less than 100 miles.
Call it $40 shipped and it's yours.
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/SU1HMDAxMDEtMjAxMDEwMTEtMTkyMy5qcGc.jpg[/IMG]
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/ZWdyMS5qcGc.jpg[/IMG]
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/ZWdyMy5qcGc.jpg[/IMG]
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/ZWdyNC5qcGc.jpg[/IMG]
Paypal is acceptable!
Posted on: 2010/10/12 13:53
hdfire Re: Barely used EGR Valve
Crest Hill, IL
48 Posts
Hey Jeff-
What year (not sure if there is a diffenence within the C4's)? Mine is a 89'.
Thanks
Posted on: 2010/12/20 23:27
bogus Re: Barely used EGR Valve
89 and 90 should be the same.
Posted on: 2010/12/20 23:45
JeffK Re: Barely used EGR Valve
High Point, NC
1440 Posts
Mine is a 90. I think it should be the same. According to Rockauto they are the same.
Posted on: 2010/12/21 0:06
Ultraman Re: Barely used EGR Valve
14754 Posts
What happens when you delete the system. How does it effect the car?
Posted on: 2010/12/21 3:27
High Point, NC
1440 Posts
Wow, that's a tough question to answer. Removing the EGR requires that you get a chip that deletes the EGR otherwise you have a code 32 constantly. I've read that it can cause predetonation also but as long as you run premium gas that sound not be a problem. I don't know that it really improves performance or anything. My EGR system was not functional from the time I bought the car. I bought the EGR Valve and replaced it with this one, still code 32 so I put the old one back on. I found out that the EGR Solenoid was bad and it is no longer available.
I ended up buying the cheaper hedman headers with no EGR provisions so I eventually removed everything EGR related. I have yet to get the chip because I'm not sure what other mods I want to do to the car.
I would say that if you are not going to do much to your Vette and you can keep the EGR system working then do it.
Posted on: 2010/12/21 16:51
flyboy Re: Barely used EGR Valve
I removed the EGR and all the rest of the emissions stuff for that matter, never got a code on the '91. This was when it still had the stock chip. Maybe they are not all the same though.
Posted on: 2010/12/21 16:57
Crest Hill, IL
48 Posts
Received the EGR yesterday, looks GREAT!
Thanks Jeff!!
JeffK is a stand-up honest guy! An asset to this Forum!
Thanks for helping a "new guy"!
Posted on: 2011/1/15 20:02
High Point, NC
1440 Posts
My pleasure!
Posted on: 2011/1/17 13:05
