303 user(s) are online (249 user(s) are browsing Forums)
C4DERF Window adjustment
332 Posts
I need the help of Gurus to show me how to adjust my passnager window. It does not seal along the winshield post seal at the bottom. It has a 1/8th inch gap. instructions with photos would be very appreciated. Thanks in advanced to the Gurus......
Posted on: 2011/1/16 4:43
bogus Re: Window adjustment
ooh... this is an annoying one.
I don't have photos, but... there are a series of adjustments that can be made, but the process is really touch and go.
I will dig out the pages from my helm and see if I can scan them in. But I will warn you, the manual is vague. I hope others will chime in.
Posted on: 2011/1/16 7:49
BillH Re: Window adjustment
It's the "tip in" adjustment on the window. It's done with the regulator mounting bolts.
There's also a felt covered guide at the top of the door which many guys incorrectly use to adjust the tip in.
These felt guides need to be inspected while you're in there, when they go bad, you end up with a scratched window.
Have you had the door panels off before? There's a hidden screw or 2.
Scribe the regulator position on the door frame (this position must be kept or other adjustments will be out).
Loosen the regulator bolts and the rear stablizer guide.
Move the regulator in or out to adjust (hit or miss like Andy said).
When it's correct, tighten the reg and stabilzer.
Double check the felt guides for too much pressure which will wear them out and scratch the window.
Posted on: 2011/1/16 14:37
Matatk Re: Window adjustment
Posted on: 2011/1/16 23:16
BrianCunningham Re: Window adjustment
it takes a lot of patience.
I needed to do my when I put in the new (to me) regulator
take a pic of all the connectors on the switch to help put them all back in the right place
Photobucket
Posted on: 2011/1/16 23:37
C4DERF Re: Window adjustment
332 Posts
Thanks Andy, BillH, Matatk and BrianCunningham!! I feel I will be very well armed (and dangerous0 to attempt this adjustment. Very appreciated fellow Gurus!
Posted on: 2011/1/17 22:09
If you've never removed the door panels before or don't have a FSM, there's a screw behind the door lock slider.
Posted on: 2011/1/17 22:32
-=Jeff=- Re: Window adjustment
Bartlett, IL
573 Posts
there are 2 hidden screws on the handle bezel, one behind the slide lock, one behind the light. a 3rd one can be seen behind the handle
there is another hidden screw behind the power window switch
5 screws along the bottom, 2 in the door pull 'cup'. one at the front 1/2 up one on the back above the hatch release
Window regulator top bolts will adjust tip in to a degree, there is a tip in and 'hook' bracket at the back of the door. the hook lock the window from pulling away from the weatherstripping. that is adjusted by a 10mm nut hidden in the door from view
there is a 10mm window stop towards the front.. 3 10mm hold the window.
with a 1/8 gap at the lower front of the window I have to wonder if the door isn't aligned. the door itself could also cause the window to not fit right
I will take some pictures as I have the Pass door apart.
Posted on: 2011/1/19 5:07
-=Jeff=-
1990 Corvette ZR-1 #1051
If that's the case, you have to pull off the lower fender gills and adjust the door hinges.
Posted on: 2011/1/19 12:41
Bartlett, IL
573 Posts
Pics:
95 inner door support with 95 PDL (on my 90)
Posted on: 2011/1/31 0:41
-=Jeff=-
332 Posts
Jeff and all the fine Gurus, Thanks for the info!!! When my travells slow down I plan to tackle the door with renewed vigor.....
Posted on: 2011/2/8 19:18
