283 user(s) are online (249 user(s) are browsing Forums)
1969 through 1976 Corvette.
« 1 (2)
Matatk Re: Head gaskets?!
JeffK wrote:
Matatk wrote:
JeffK wrote:
Got some silver header paint since the paint that Dad and I initially put on them burnt off about 30 seconds after we fired it up.
Yeah, that'll burn off too. It did on mine even with the "high temp header" paint.
Well damn, maybe I won't waste the time. That paint isn't cheap either. $9 a can.
Spent a couple of hours in the garage last night and all I accomplished was getting the intake manifold cleaned up.
I was reading on yellow bullet last night about some header paint. Some guys have used the VHT where you bake it off the car through several heat cycles and they say it works well. Also some recommended BBQ paint, although you might need to reapply yearly.
I'd probably still paint it just to help prevent corrosion on the lower parts that might not get as hot.
As far as the tall VCs, I've seen guys cut out under the bracket and weld the piece back in upside down.
Posted on: 2011/2/18 21:46
JeffK Re: Head gaskets?!
High Point, NC
1440 Posts
I might just clean them up really good and spray them with a couple of light coats. I have no way of baking them.
I looked into having them coated but the only places I found are in VA or SC..so much for Nascar country
I don't know how much I will get to work on it this weekend since we are leaving out Sunday morning. Hoping to atleast get the block surface cleaned up and replace the connectors that I bought for the MAP, TPS and IAC.
Might get to put the heads on Wednesday night.
Posted on: 2011/2/18 21:53
High Point, NC
1440 Posts
Got the block as clean as I could. There was still the outline of the old gaskets. It was smooth and all.
I got the dumbass award for only ordering 1 head gasket...thought they came in a set.
Sort of worried about using the 1094's on the non-machined block.
Posted on: 2011/2/19 22:56
Why are you worried? As long as all is straight you should be fine. If it's regarding piston depth, stock piston height is more than sufficient to prevent any interference.
Posted on: 2011/2/20 16:23
flyboy Re: Head gaskets?!
GM used steel shim gaskets for years but if you're going to have worry hanging over your head about a coolant leak or something, go with a fire ring gasket. Is that extra quench/compression worth piece of mind?
Posted on: 2011/2/20 16:31
High Point, NC
1440 Posts
I chickened out and ordered a pair of the 1010's
Should be here today. I just can't afford to have the head gasket fail and cause bigger problems. I should get a slight bump on comp with the 1010's. Again it's not like I track the car.
I ended up painting the headers just for the hell of it. They look so nice I hate to put them on the car.
Posted on: 2011/2/23 14:40
High Point, NC
1440 Posts
Got the heads bolted on last night. Gotta love that sequence.. especially doing 4 times per head.
Somehow the pushrods I got are not correct. They are about 3/4" too long. Guess it won't be back together this weekend.
Posted on: 2011/2/24 16:53
High Point, NC
1440 Posts
Ok, apparently the p-rods that I got are for the flat tappet motor? Should have been the 7.4 not the 7.8.
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/SU1HMDAxMzYtMjAxMTAyMjMtMjAxMC5qcGc.jpg[/IMG]
I also placed the valve cover on to check wiper motor clearance.
sorry for the crappy pic but you get the idea
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/SU1HMDAxNDAtMjAxMTAyMjMtMjEwNC5qcGc.jpg[/IMG]
Posted on: 2011/2/24 18:03
Where did you get the pushrods from? There shouldn't have been a confusion with a flat tappet motor and yours.
Posted on: 2011/2/25 1:56
High Point, NC
1440 Posts
I got them from Skip White performance. It was my fault. I wasn't sure of the stock length and they listed the ones I bought at stock for 350 SBC. I failed to read that they were for the flat tappet.
Posted on: 2011/2/25 2:42
Why the new pushrods?
Posted on: 2011/2/25 4:04
High Point, NC
1440 Posts
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/cm9ja2Vycy5qcGc.jpg[/IMG]
I went with non-self aligning roller rockers so I have to do hardened pushrods and hardened guide plates.
Posted on: 2011/2/25 12:10
Interesting. I have read that the self aligning rockers were employed as a cost saving measure (no hardened pushrods or guide plates). Also, some aftermarket heads (AFR for one) require the non-self aligning ones. I don't really know which are better. I suspect the non-aligning would be more bullet proof. What brand are your rockers? The color looks like Crane.
Posted on: 2011/2/25 14:08
High Point, NC
1440 Posts
From what I read most engine builders will not use the self-aligning. I am not an engine builder but I did research and everything I read was to go non self aligning.
They are Wysco.. Crane knock-offs. Price was right. I had my machinist clean them up and we looked them over real good. Don't seem to be any apparent issues and they have a 5 year warranty. I soaked them in oil for about a week too.
Posted on: 2011/2/25 19:46
High Point, NC
1440 Posts
Well, since I have no pushrods I couldn't get anything done this weekend. Sucks too because it was so nice out.
Anyway, I guess the all black intake is out because of the shiney new valve covers. I dread the thought of sanding all of the paint off the runners...what a pain.
I also noticed that the inside of my plenum is coated with oil. I don't know what could cause that. I must have botched something when I did the intake manifold the first time.
Posted on: 2011/2/28 2:50
Jeff, I found some light oil deposit in my manifold when I took it apart this weekend, too. I'm figuring it's from the PCV. Unless it's a huge amount of oil I wouldn't be super concerned.
Posted on: 2011/2/28 13:26
High Point, NC
1440 Posts
I am going to clean it up tonight, get the oil out and take my time putting it back together. I don't remember there being any oil in there when I took it apart to do the IM gasket a month or two ago. I am seriously wondering if the leak in the rear of the china wall could cause some sort of funky vacuum that pulled the oil up into there and caused the oil pushing out of the VC's
Posted on: 2011/2/28 14:49
joeld Re: Head gaskets?!
Are you using aftermarket valve covers? Some of those don't have the baffle and this will cause the PFC valve to actually suck oil fumes into the plenum. Dosen't take long for a coating of oil to cover the inside of plenum and even lower intake.
Posted on: 2011/2/28 15:38
High Point, NC
1440 Posts
I was using the stock VC's at the time.
I am replacing them with aftermarket baffled VC's.
Posted on: 2011/2/28 17:07
High Point, NC
1440 Posts
I adjusted the valve lash last night. I used the method that Joe C on the other forum wrote and a few other members supported. I haven't done valve lash but one other time and that was on Dad's engine when we had it on the stand so I'm a little nervous. There are so many different techniques to doing it.
Got the intake manifold on and torqued down too. I put a healthy dose of Right Stuff on the china walls so hopefully it doesn't leak this time.
I am going to have to shave the posts on my new valve covers to fit in between the rockers.
Posted on: 2011/3/3 13:23
Sounds like you're making good progress!
Posted on: 2011/3/4 2:40
High Point, NC
1440 Posts
It doesn't seem like it ;(
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/SU1HMDAxNTAtMjAxMTAzMDMtMjEyNS5qcGc.jpg[/IMG]
I want to be driving it.
Posted on: 2011/3/4 12:32
Think of all the gas money you're saving.
Posted on: 2011/3/4 13:44
High Point, NC
1440 Posts
The sad part about that it that the Vette gets better mileage than the Jetta...
Painted headers
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/SU1HMDAxNTMtMjAxMTAzMDQtMTYxNC5qcGc.jpg[/IMG]
Posted on: 2011/3/4 21:55
They look pretty! Hope they last. My vette used to get great mileage...until I stroked it!
Posted on: 2011/3/5 2:31
High Point, NC
1440 Posts
Well, I made some progess today. Except that I spent more time than I need on the valve covers thinking that they needed to be ground to clear the RR's. Turned them around and they fit great!
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/SU1HMDAxNTUtMjAxMTAzMDUtMjAxNy5qcGc.jpg[/IMG]
Posted on: 2011/3/6 3:05
High Point, NC
1440 Posts
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/SU1HMDAxNTQtMjAxMTAzMDUtMjAxNy5qcGc.jpg[/IMG]
Looks like I will be firing it up tonight.
Monday night I ..
Added antifreeze
Mounted Starter
Drained oil and installed new filter
installed Serp belt
installed new front shocks
Tonight I need to ..
Fill oil
install dist cap / plugs / wires
install and connect headers
hope that it starts and then
refill coolant
set timing
drive it!!
Posted on: 2011/3/9 15:58
Look forward to hearing the results!
Posted on: 2011/3/9 16:57
High Point, NC
1440 Posts
EDIT -
Re-adjust valves
Fill oil
refill coolant
set timing
drive it!!
Posted on: 2011/3/9 17:20
High Point, NC
1440 Posts
Re-adjusted the valves last night. Kind of glad I did since I realized that one of the VC's need a little trimming on the post. The post was rubbing against the rockers. Not sure what the covers are made of but it's a pain to file down by hand and ruins dremel sanding drums almost instantly.
Got the oil filled. Put the 4 passenger side plugs in and then started to put the headers on and put a 3" cut on the top of my head on the fender. I decided that it was time to quit at that point.
Posted on: 2011/3/10 20:31
High Point, NC
1440 Posts
IT'S ALIVE!!!!
Fired it up about an hour ago. I didn't drive it because it is too late. I'll do that tomorrow. It is down on all 4's now.
Fluids are topped off, timing is set. Oil pressure reading at 80 cold. I let it warm up a couple of times to try to cycle the header paint.
Now I really can't wait for 5 o'clock tomorrow!!!!
Thank you all for your help and support. And for answering my dumbass questions.
Posted on: 2011/3/11 3:39
Posted on: 2011/3/11 4:03
Awesome! Make sure to check those header bolts after a few heat cycles/500 miles. I'm not sure what type of bolts you used, but some are known to loosen up a bit.
Posted on: 2011/3/11 12:30
High Point, NC
1440 Posts
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/SU1HMDAxNTctMjAxMTAzMTAtMjIxNC5qcGc.jpg[/IMG]
Ordered a polished TB plate yesterday. Air delete bracket is being made in the next week or so.
Next payday I am buying a real digital camera.
Posted on: 2011/3/11 12:45
High Point, NC
1440 Posts
I used the Stainless allen heads that came with the kit I bought for the headers. Except for the very back bolt by #8.
I am going to invest in an Moates cable and datamaster next so maybe I can get Mick or someone to do a mail order tune for me and get rid of that EGR code 32.
Posted on: 2011/3/11 21:41
High Point, NC
1440 Posts
Got it all washed up today and my wife and I took a little cruise. Everything seems good. Still need to get exhaust leak at the cat fixed.
I posted a vid in the other C4 section.
I had to re-adjust the passenger side valves this morning. Think I still need to do the drivers side again.
Posted on: 2011/3/12 23:32
What did the shop decide on final cost if you don't mind?
You'll be a valve adjusting expert by the end of this!
Posted on: 2011/3/13 2:46
High Point, NC
1440 Posts
Matthew, I sent you a PM.
Yes, I will just about have the award for valve adjusting.
These rockers seem to be happy at 3/4 turn versus's the 1/2.
Posted on: 2011/3/13 3:13
86PACER Re: Head gaskets?!
41 Posts
What paint did you use on the headers? Is it holding up?
Posted on: 2011/3/18 3:52
High Point, NC
1440 Posts
I think it's VHT header paint. I is holding up really well so far.
Here's how I painted them.
Scrubbed them with simple green
wire brushed them really well
took a heat gun and got them warm
sprayed them with 3 medium coats using the heat gun in between coats to help "set" the paint.
Then they sat in the trunk of my other car for almost 2 weeks.
Posted on: 2011/3/18 12:08
« 1 (2)
