144 user(s) are online (100 user(s) are browsing Forums)
Vettrock Lowered and Poly Bushings...
Henderson Nv.
34 Posts
Hi, I thought I would share some pictures of my of lowered frontend. While I was at it I put poly bushings in also. So far I like it but I haven't driven it much. I cut the rubber spacer off the top of the spring and glued on the wedges using 5 minute expoxy. I also switched to the '88 and later spring retainers. Which had to be cut down for a tight fit of the spring. Since I was going for maximum drop so I also cut the rubber pads off the spring ends. I got a 1.5 inch drop. Not too bad considering I have very little weight in front of the car. The car only weighs 2800 lbs. The control arms move freely with them torqued so I'm pretty sure that's all the drop I'll get.
Before
After
Posted on: 2008/1/25 2:27
1987 Silver Couple, 9.95 @ 138 mph on the bottle. Too many mods to list.
1998 Red Convertible, my daily driver. Pure stock.
Ramrod RE:Lowered and Poly Bushings...
S. California
296 Posts
Dam that looks nice, looks like you keep her in good shape. Do the poly bushings give you a stiff bumpy ride?
Posted on: 2008/1/25 3:05
Vettrock RE:Lowered and Poly Bushings...
Henderson Nv.
34 Posts
I don't think so. It seems to make the steering more responsive and I like that.
Doug.
Posted on: 2008/1/25 3:14
bogus RE:Lowered and Poly Bushings...
sweet look! I love the colour.
Posted on: 2008/1/25 3:23
cuisinartvette RE:Lowered and Poly Bushings...
Youll like the poly bushings, will drive nice and tight. Draglites look great on that car.
Posted on: 2008/1/25 13:11
Notorious RE:Lowered and Poly Bushings...
colour.
What are you, British?
That looks bad-assed!
Posted on: 2008/1/25 16:17
sliding RE:Lowered and Poly Bushings...
Zagreb, Croatia
326 Posts
Do you have some under the hood pics?
Posted on: 2008/1/25 18:42
Henderson Nv.
34 Posts
Thanks guys for the compliments.
Here's one. Is there a particular picture of something you want to see?
Doug
Posted on: 2008/1/26 1:34
Danspeed1 RE:Lowered and Poly Bushings...
Mooresville, North Carolina
1121 Posts
Sweet car,
How do you like that fuel injection setup,... my father just picked the same one up for his 377ci C3?
DG
Posted on: 2008/1/26 7:29
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
Zagreb, Croatia
326 Posts
Doug
Thanks, I was just interested to see what was under that big hood!
Great car!
Posted on: 2008/1/26 10:27
