294 user(s) are online (261 user(s) are browsing Forums)
« 1 (2)
bam Re: LT4 Hot Cam??
missouri
250 Posts
Matatk wrote:
Congrats on getting it all done! But I think it's all a fantasy since I haven't seen any pics yet
The best way to upload photos or video is to use a free file sharing website such as photobucket. Sign up for a free account, upload your pictures, and then use the links on the side of the screen once uploaded to show your pics!
Where are the links on the side of the screen? Is that here on CG under options? Opened a PB account so I can download some pix. When I click the "choose file" it takes me to my photos but if I try to download one from there they are too big???
Posted on: 2011/4/10 3:20
Matatk Re: LT4 Hot Cam??
bam wrote:
Where are the links on the side of the screen? Is that here on CG under options? Opened a PB account so I can download some pix. When I click the "choose file" it takes me to my photos but if I try to download one from there they are too big???[/quote]
When you are in photobucket, there is an option to "upload photos" - you need to click on that button and upload them to photobucket from your hard drive. Once that is done, find where you loaded them to (if you made specific folders). Underneath the thumbnails you will have about 4 options...it will say img code, html, direct link, email, etc. Copy the link that is "html code" and paste it directly into your corvette-guru posting. You can also click on the thumbnail in your photobucket account which will make it larger, and you will see the same links on the side of the photo.
Here is an example:
Posted on: 2011/4/10 11:32
missouri
250 Posts
Ok hopefully this will turn out to be a picture.ready to start
Posted on: 2011/4/10 19:34
Edited by bogus on 2012/5/10 6:29:31
Tom, the link would work if you don't put the "." in front of it. But the photo is not there on photobucket. Got any more?
Posted on: 2011/4/10 22:49
flyboy Re: LT4 Hot Cam??
Is photo #8 of the old pan gasket? Nice garage.
Posted on: 2011/4/11 0:29
missouri
250 Posts
Thanks, just built my garage this Nov., it's really nice, got my wood shop in there too.
And yes that's the old pan gasket, wish I had left it on there and not messed with it. I am almost ready to drop the pan again, we'll see what it looks like. You can't see or get to anything on the front of an LT1 motor w/o major work.
Posted on: 2011/4/11 0:57
missouri
250 Posts
I'll try that next time, don't have any more pix now. Can you believe I pulled the old cam out and stuck the hot cam in w/o taking any pictures!!! Makes me really mad. I was having so much trouble getting the motor up to pull the cam that I totally forgot about the pictures. I do have the receipt from Jegs for the cam and the old cam so it really did happen. Let me know if there is any specific picture you want and I'll try to take it if I don't have it.
Posted on: 2011/4/11 1:03
I took the liberty of posting these for you. Let me know if you don't want them up.
ready to start
dreaded wp seal
Photobucket
painted intake, EGR plugs
a little gasket matching
hot cam installed and new tim chain
new exotic muscle LT's
scorpion 1.6 rr's & new springs
checking rr wear pattern
Posted on: 2011/4/11 11:30
What do the marks on the valve stem tip represent in regard to the new shorter pushrods?
Posted on: 2011/4/11 13:02
missouri
250 Posts
Thanks for putting the pix up, one of these days I'll figure it out.
As to the wear pattern, the one in both pix is with the stock 7.2 len. push rods. I didn't take pix of the new wear pattern but it's much more centered on the valve stem.
I have a really bad leak in the front of the oil pan I am working on now. Have the pan almost ready to drop for the 2nd time **!!##@*, hopefully I can see what is wrong.
Posted on: 2011/4/11 13:14
missouri
250 Posts
Got the leak in the pan fixed thanks to a helping of "The Right Stuff" on the front and back of the curved part of the pan. There is something funny about that FelPro one piece gasket because in the front (where the leak was) it is bulging out where the pan meets the timing cover. Drove the car with the new hot cam, wow what a difference in power. Can't wait to get the new tune. Thanks to all for the good info here on the forum. I'll post up a vid. soon.
Posted on: 2011/4/13 19:42
RickAnthony Re: LT4 Hot Cam??
ASE Master Certified
Downers Grove, IL
703 Posts
Ah memories.. reminds me of when I did the LT4 Upgrade and hot cam on my 95'
Posted on: 2011/4/14 3:42
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
missouri
250 Posts
Well I had to order new heated oxygen sensors, one came today and I got it installed the other one should be here tomorrow. The guy who is doing my tune said there was no point in him doing any more tuning until I made the switch. Anyone else run into this problem? The car is running very rich. When I took the old (just replaced with new ones last summer) 02 sensors out they were getting pretty black with soot.
Posted on: 2011/4/21 1:52
Nice pictures. Glad you fixed the leak. As far as I know the heated O2 sensor puts the engine into closed loop quicker. Mine takes about 5 min. of driving to go closed without a heated sensor. Is your car OBD1? Try jumping the A-B diagnostic terminals and drive around to see what's happening with this test.
jpg  P1010001.JPG (136.19 KB)
1735_4daf9eec37856.jpg 640X480 px
Posted on: 2011/4/21 3:06
madmax53 Re: LT4 Hot Cam??
texas
16 Posts
flyboy,. i have a question sir about an old post if u dont mind. will the lifter tool that you sugested work on a l98 to change the cam without pulling the intake? it was posted that it would not work on the lt1-lt4 because of the oil pump drive shaft location. i think i read where you did it on the l98. thanks for the info..greg..
Posted on: 2012/5/10 3:15
bogus Re: LT4 Hot Cam??
Max - when did you last service the intake manifold?
If it's been a while, then it might not be a bad idea to R&R it just to be safe.
Also, you may want to port it a bit...
Posted on: 2012/5/10 6:31
Are you referring to the magnets he used to hold up the lifters?
Posted on: 2012/5/10 11:42
texas
16 Posts
bogus, i had it apart last summer to replace injectors and a leaking intake gasket. didnt really want to do it again if the cam can be installed without pulling it.waiting on my service manuel so i can run the charts on my code 33. thanks for the link bogus.. and yes, iam talking about the lifter tool or magnets to hold the lifters up. will this work on this engine? what about the oil pump rod. it pulls straight up doesnt it? thanks guys..
Posted on: 2012/5/10 13:43
92Polo Re: LT4 Hot Cam??
91 Posts
It depends on where your sensors are in your headers. Mine are down in the collector and they could cool off with excessive idling. This would cause it to run really rich until the computer would realize it and drop out of closed loop. New heated sensors took care of the problem.
I used the fuel pump enable wire from the ECM to trigger a relay to power them. I like this because it is only on when the engine is running therefore the sensors aren't being heated in just the ON or ACC position.
It will make a big difference in the ability to tune it accurately.
Posted on: 2012/5/10 23:29
I can only give you a link to his post, can't really help you with the technical aspect of it:
http://www.corvetteguruforum.com/modu ... id=112237#forumpost112237
Confused on what you are doing with the oil pump rod?
Posted on: 2012/5/11 17:45
I used pen magnets to hold the lifters. If I was going to do it again, I think I'd remove the manifold, less anxiety.
I did nothing with the oil pump when changing the cam.
Posted on: 2012/5/11 18:30
texas
16 Posts
Ok, Thanks you guys so much. i think i will attempt it with the intake on, and if not, ill pull it again. the iol pan does have to come off correct? to replace the lower front gasket? oh , ill read the link. thanks again. greg.
Posted on: 2012/5/14 19:49
« 1 (2)
