196 user(s) are online (109 user(s) are browsing Forums)
The Natio...
Durango_Boy TH2004R Shifting Improvement suggestions.
PeteK you still perusing the forums for transmission questions? LOL.
I put a TH2004R in my 1977 Corvette behind my roller 405 SBC. I installed a B&M lockup controller and the Grand National lockup converter that came with the transmission.
I'm not happy with the shifting points...like it never knows what gear to be in.
I need suggestions for what I assume I need, a shift help kit and possibly a higher stall converter. It seems like it's shifting too early, and I want to elongate the RPM band per shift without keeping the accelerator floored.
Thanks.
Posted on: 2011/5/10 13:18
Trae1976 Re: TH2004R Shifting Improvement suggestions.
Johnson City, TN
832 Posts
You've probably already checked it, but is it possible the TV cable is just a tad on the loose side? I believe that would cause quicker, softer shifts.
Posted on: 2011/5/10 18:52
Durango_Boy Re: TH2004R Shifting Improvement suggestions.
Yeah I built a TV cable bracket that allows me very specific and exact adjustment and it's just as tight on the carbs as the throttle cable. It starts at a 1 - 1 adjustment. I need to change the position of the bracket to account for more throttle movement of the carbs but for the time being it should be fine. I don't even use but a small portion of the throttle travel.
Thanks for the suggestion.
Posted on: 2011/5/10 18:58
Matatk Re: TH2004R Shifting Improvement suggestions.
22947 Posts
Shift points are controlled by the governor, similar to how the 700r4 works. Here are a couple links to get started:
http://www.oldspower.com/vb/showthread.php?p=408813#post408813
http://www.turbobuick.com/forums/tran ... -higher-shift-points.html
Posted on: 2011/5/10 23:11
tjpreul Re: TH2004R Shifting Improvement suggestions.
DB, give Troy a call. He's a GN guy.
Posted on: 2011/5/11 1:52
Johnson City, TN
832 Posts
DB, any progress?
Posted on: 2011/5/13 12:55
No my work schedule and the weather has kept me out of the garage. I'm going to have some time Saturday I think to tinker.
Posted on: 2011/5/13 13:16
PeteK Re: TH2004R Shifting Improvement suggestions.
Thanks.
I still check in from time to time.
Shift kit and converter will not change shift timing, but both will affect shift firmness.
Higher stall converters will soften a shift, due to internal slippage. How much it softens it will depend on the efficiency of the converter, and stall. Better quality converters result in a happier end user.
Shift kits are nice, and can be used to tailor shift firmness depending on the kit, and the converter conbination.
Triple check your tv system is working properly, and play around with the weights and springs in the governor.
Posted on: 2011/5/13 16:37
Johnson City, TN
832 Posts
I don't know if it will help, but this was our process in setting the TV system:
We started with a freshly rebuilt 700R4 and the Bowtie Overdrives kit.
First, we noticed that the TV plunger was not fully returning to its outermost position with the spring that was in it. So, per BTO's recommendation, we installed the TransGo SK700-Jr kit, which provided full plunger travel. Supposedly it also added some other desirable shift qualities, but I didn't have a "before" comparison, so I can't really speak to that.
Then, after installation, we set the TV cable per BTO’s instructions using a pressure gauge as a guide, but we obviously didn’t get it quite right. Over the course of a few hundred miles, I ended up attempting to reset it several times, due to occasional erratic shifting (mainly late shifts or no 3-4 shift). I did notice that if I went too far in my adjustments, I could get what I would consider "quick" shifts.
Finally, we decided to start over, but this time I dropped the pan so I could see exactly what was happening at the tranny end. One person made the bracket adjustments at the carb while I monitored the effect at the plunger.
We set it such that:
- at idle, the cable provides a very slight bit of pressure to the plunger, and
- WOT corresponds exactly to full plunger travel, no more and no less.
That adjustment has been good for several thousand miles, and I’m happy with the shift characteristics.
And I should mention I'm using one of the stainless universal cables and the BTO Holley carb brackets. Obviously your setup is different, but maybe something I mentioned will help.
Now, I’m just hoping Pete doesn’t tell me I've done it completely wrong.
Posted on: 2011/5/13 20:08
