171 user(s) are online (105 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Ruby
Refers to 1993 Anniversary Editions.
These are the actual cars honored as anniversary cars. They have RPO Z25 to prove it....
84bluec4 84 Crossfire Corvette Engine Sound
Grass Lake, Michigan 49240
65 Posts
Please listen to the video clip...
Does this sound like a spun bearing?
A bad torque converter?
Starter still engaged to the flywheel?
Notice the sound it makes after the engine is off.
Oil pressure is at 45 psi and oil level is to the line.
I didn't see any metal in the oil and no oil puddles under the car.
Any suggestions appreciated.
Mark
Posted on: 2011/5/13 20:19
M Moore
1984 Lt blue/Med blue, z51, automatic, 3.07
350 crossfire
blue cloth interior, Bose stereo,
everything still stock (for now)
bogus Re: 84 Crossfire Corvette Engine Sound
20860 Posts
you have spun a bearing... for sure... but it's on the accessory belt drive somewhere!
I would remove the belt and go looking for broken things.
You can safely start the engine, when cold, for a minute or so to test the belt theory.
It is not in the engine. I am guessing AIR pump.
Another thing you can do, get a LONG handled screwdriver, put it on each accessory and then put the handle to you ear - cheap stethoscope. Listen to each and see what sound they are making.
I don't feel it is internal.
Posted on: 2011/5/13 20:39
84bluec4 Re: 84 Crossfire Corvette Engine Sound
65 Posts
I just got done pulling the accessory belt off. The sound didn't go away.
Now I am still trying to figure out if the noise is top or bottom.
Looks like a trip to the hardware store for a long screwdriver tomorrow.
Mark
Posted on: 2011/5/13 23:01
M Moore
350 crossfire
20860 Posts
Wow. Still making that noise.
Man talk about killing my theory.
I wonder if the harmonic balancer hasn't come apart.
Posted on: 2011/5/14 0:07
65 Posts
Just went out to check something............
You got it, Harmonic Balancer is just free spinning.
Any recommendations on a balancer?
Thanks again!!!
Mark
jpg  balancer.jpg (68.84 KB)
722_4dcdcdcd9950a.jpg 1024X768 px
Posted on: 2011/5/14 0:33
M Moore
350 crossfire
Matatk Re: 84 Crossfire Corvette Engine Sound
22810 Posts
When I replaced my HB on the stock motor I used a dorman replacement from rock auto. Just fine IMHO.
DORMAN Part # 594012 {#12551537, 6272221} Solid; Diameter; 6-3/4"; Width: 2-3/8"; Weight (lbs.): 8.36 Stock Balancer $27.79
Posted on: 2011/5/14 2:07
20860 Posts
And we have a discount from rock auto!
Posted on: 2011/5/14 5:07
PeteK Re: 84 Crossfire Corvette Engine Sound
Inspect the sheet metal timing cover for damage when it is apart.
Posted on: 2011/5/14 13:04
65 Posts
Got the crank pulley and the outside ring of the harmonic balancer off today. From what I can see and feel there is no damage to the front cover. I looks like it going to be a tight fit to get a pull/installer in there with the steering rack in there though.
Any one know of any tricks?
And thank you Matatk for the recommendation and I will be placing the order with RockAuto!
Mark
Posted on: 2011/5/15 0:42
M Moore
350 crossfire
20860 Posts
Well, with the balancer off, you have enough room, you may want to put the motor on a hoist, release the motor mount bolts and pull up an inch or 3.
Posted on: 2011/5/15 1:00
22810 Posts
As long as the 84 isn't different than the 89, the HB puller tool will slip through a "loop" in the steering rack line and you'll be able to get it out.
Here is an old post I made to get you started:
http://www.corvette-guru.com/modules/ ... pe=&topic_id=8433&forum=1
Posted on: 2011/5/15 3:20
65 Posts
Yikes, I forgot about this thread!
First off, thanks everyone for the info!
With the new balancer and u-joints installed, there is now ZERO drive line vibration.
I admit, I have been having too much fun this summer! :D
Posted on: 2011/8/1 2:13
M Moore
350 crossfire
20860 Posts
yay!
Posted on: 2011/8/1 2:37
biggrizzly Re: 84 Crossfire Corvette Engine Sound
I just listened to that video again. That would have scared the piss out of me if I'd have heard that one day. I had a real spun bearing, didn't sound that scary!!! LOL
Glad you got everything working and having some fun with that Blue Devil!
Posted on: 2011/8/1 7:56
