tjpreul | LT1 intake porting? | ||
I will be porting the early style of the LT1 intake to match the AFR heads. On AFR's website it says to use a different intake gasket. I just want to make sure there aren't hidden cavities that I might find.
Posted on: 2011/5/17 2:29
bogus | Re: LT1 intake porting? | ||
nope. The intake is dry with the LT1 and the egr is all in the back.
You won't be cutting out all that much material, either. |
Posted on: 2011/5/17 2:58
biggrizzly | Re: LT1 intake porting? | ||
Here are few shots of my intake after it came back from Lloyd Elliot. Since then my latest engine builder cleaned up this work a little bit more for me, but you will see there is a good deal of material removed from the inside as well as the ports and runners.
Posted on: 2011/5/17 12:17
Aboatguy | Re: LT1 intake porting? | ||
My Advanced Induction ported intake is setup for a monoblade TB if I ever get around to buying one
Mike [IMG]http://i14.photobucket.com/albums/a342/aboatguy/DSC01309.jpg[/IMG] |
Posted on: 2011/5/17 22:44
88BlackZ51 | Re: LT1 intake porting? | ||
why would you want a monoblade? |
Posted on: 2011/5/17 23:50
Larger Air Intake - more air, big cam, big heads
Posted on: 2011/5/18 1:08
rklessdriver | Re: LT1 intake porting? | ||
I've got a Monoblade..... of course, others would want a Monoblade so they could be like me. Will |
Posted on: 2011/5/18 1:45
That's the only reason why I want a monoblade... to be rkless.
Posted on: 2011/5/18 4:25
