237 user(s) are online (151 user(s) are browsing Forums)
wilsonbh Change out Plug Wires on Drivers Side for a 1994 LT1
17 Posts
Has anyone changed out the plug wires on the driver's side without removing any parts? Can it be done?
Billy
Posted on: 2008/1/24 10:35
1994 LT1 Coupe, Automatic, Hypertech Tuned/160 mod, K&N Filter
Meziere HD Electric WP, MSD Optispark, Copper Metallic
CasetheCorvetteman RE:Change out Plug Wires on Drivers Side for a 1994 LT1
Yes, if you reach up from the bottom or reach under the power steering pump you can get to them no worries.
Posted on: 2008/1/24 12:29
biggrizzly RE:Change out Plug Wires on Drivers Side for a 1994 LT1
Easiest done with two people; one up top and one below to guide the wires. It's tight and can be a PITA but its not bad when two people do it.
Good Luck
Posted on: 2008/1/24 13:08
Notorious RE:Change out Plug Wires on Drivers Side for a 1994 LT1
If I remember right from doing this long ago when my engine was stock, unbolting the steering pump from the bracket should make this a ton easier. (No need to unhook any hoses) My factory manual stated that the pulley must be removed to unbolt the pump. That is wrong, it does not. The bolts are a little tricky to find but not difficult to remove once you do so.
If anyone ever has the accessory bracket off, there's a place where some material can be ground away that will make future plug wire changes much easier. And when you see the obvious area I'm speaking of, you'll see it will have no effect on the structural integrity of the bracket.
Posted on: 2008/1/24 16:34
I hate sporks...
BillH RE:Change out Plug Wires on Drivers Side for a 1994 LT1
If you remove just the pulley, you don't to loosen up the p/s unit. Since you have to pull the belts anyway, removing the pulley only takes 2 minutes. It makes it easy to see and get to that side of the opti. For $24, it's a pretty good investment.
Posted on: 2008/1/24 17:27
fnsblum RE:Change out Plug Wires on Drivers Side for a 1994 LT1
Nothern Utah
32 Posts
I am sixty + and not near as handy as I used to be. I was able to do mine without too much difficulty by removing the belt, tensioner assembly and part of the wheel well. Good luck. Later! Frank
Posted on: 2008/1/26 23:43
93 Red LT-1
Bought in Nov.
First mod is a set of Magnaflows.
I got to them without taking anything off mine, but it was quite a tight squeeze
Posted on: 2008/1/27 3:18
