138 user(s) are online (105 user(s) are browsing Forums)
ARman72 93 running issues
17 Posts
SORRY FOR THE LONG POST
Ok guys this is my 1st post, I am new here so let me give you alittle back ground on the car. Its a 1993 bone stock 60,000 miles. I replaced the opti a few years ago. The opti has never been wet or anything like that.
Here is the issue last fall i was driving the car at night to work and it died and it wouldnt start. So i left it went back at lunch it started right up so i took it home got my Daily driver. After this issue it sat for the winter well after a few months I got the car out had the tranny serviced. Thinking it was ready to go took it out for a drive and it died going down the road. So I thought ok its gotta be the ICM I replaced it and the coil. Took it out ran great till it gets to operating temp (180-190) and if you nail the gas it dies, it will start right back up after it sits for about 5 mins. So i replaced the fuel pump and filter. Still same issue runs great at low temps but after it hits operating temp it will die when u nail the gas and will restart after it sits. Also just FWIW it will also do this sitting in the drive way in park. Sorry for the long post. I am no expert or a repair guru lol, But there is no check engine light, havent pulled code dont have a code reader. Please help thanks in advance.
Posted on: 2011/6/18 13:06
Ultraman Re: 93 running issues
14768 Posts
Welcome to the Guru, hang on some knowledge will be coming your way soon. Guys are in and out on the weekend....
Posted on: 2011/6/18 13:11
BillH Re: 93 running issues
Welcome to the forum.
The nice thing about a 92-93 is you don't need a code reader, just a paper clip.
Go to our tech library, and under Engines is the info on how to pull all the codes up on the dash, it's esay to do. Suggest you print it out.
Sounds like that car runs on in Open Loop (cold) and the problem occurs when you hit Closed Loop.
You need to check for codes before you can do anything else.
Do you have a fuel pressure gauge?
Posted on: 2011/6/18 13:35
ARman72 Re: 93 running issues
17 Posts
thanks guys for the welcome
No BillH i dont have one.
will it throw out codes without a check engine light?
Posted on: 2011/6/18 13:41
Yes, codes w/o a check light are possible.
You really need to do the procedure before we can give the problem some more thought.
You can borrow a F/P gauge from one of the parts stores but you need to pull the codes first.
I have a 92 Factory Service Manual that will be very close to your 93.
Posted on: 2011/6/18 13:49
17 Posts
ok thanks ill pull them after i read the tech library section.
Posted on: 2011/6/18 13:52
17 Posts
ok no codes.....got some H but no C
Posted on: 2011/6/18 14:33
1Fast04Vert Re: 93 running issues
I know you just replaced the ICM, but everything points to it being the culprit. Might be a good idea to check for spark when it is not starting (hot).
Posted on: 2011/6/18 14:43
17 Posts
I took the new ICM off, before i did the fuel pump, and it checked out good.
Posted on: 2011/6/18 14:45
bogus Re: 93 running issues
This is my fave to blame... the ICM HARNESS.
This happened to the former owner of a 93 Vette several years ago. It would do exactly what you are reporting.
What was happening, due to age, the ICM harness assembly to and from the ICM to the coil had deteriorated to the point where it wasn't staying tight inside the sockets any more.
In short, the weather pack connector ends were dead. The plastic would get soft and the metal would lose contact.
Posted on: 2011/6/18 15:34
List the H codes for us.
What happens is that when you turn the key off, most codes go from C to H (History).
Write the H codes down, than clear all the codes so you can see if they come back.
Posted on: 2011/6/18 16:20
17 Posts
1.H 74
4. H 16
Posted on: 2011/6/18 20:53
17 Posts
You its funny you said that i thought it seemed kinda loose when i replaced it. Cant you get replacement harness?
Posted on: 2011/6/18 20:57
Rockauto has as ton of connectors... you can always make one.
Posted on: 2011/6/18 21:33
17 Posts
LOL I am not so sure i could make one. Can you give me a run down of what all i would need to make one>?
Posted on: 2011/6/19 4:31
ARman72 wrote:
1.H 74
4. H 16
oh, exciting.
We have found your problem - H16. The opti is dying a slow death. H16 is the low-res signal, this means that the fuel delivery is getting messed with. It happened to mine and the car runs like crap when it happens.
Code 74 is a dimming issue with the LCD... nothing to worry about.
Reset the codes and see if they come back.
Posted on: 2011/6/19 5:52
17 Posts
Ok does this mean its not the ICM connection?
Ok I went out this AM and cleared the codes now it shows ---
on 1,4,9.....No H,C's...So now i just drive it till it dies, right? Will it throw a code when it dies? will it show like a H16 when i paper clip it again after it dies? Sorry for all the questions just wanna understand and get this thing fixed..
Posted on: 2011/6/19 9:39
17 Posts
Ok just got back from a drive it died again, also the H16 came back after i pulled the codes again....
Posted on: 2011/6/19 12:00
What "brand" opti is in there now? Guys have had problems with the inexpensive ones on ebay.
A code 16 is usually the opti. However, it can also be the wiring.
Do you have a digital voltmeter that you can use to test the harness? If you do, I can wrire up a quick "how to".
Posted on: 2011/6/19 12:27
17 Posts
No i dont have a voltmeter, I know i need to invest in some tools for working on this car. I know the stock opti went out and i did buy the replacement one on ebay. However when the stock one went out it would act up right from the get go. I know the opti can act many strange ways and not always the same when its on the verge of death lol.
A another Vette owner i know said the wires going into the opti could be the issue..
Posted on: 2011/6/19 12:33
Yea, opti's can all act differently when they go out. Mine hickuped for 4 months before it even threw a 16.
Voltmeters are inexpensive, you can pick one up anywhere, Sears, Pep Boys even Home depot. You can get an OK one for less than $20.
If you plan to keep the car, get a Factory Service Manual.
I'll try to scan the 2 pages from the manual in a bit but usually they are hard to read. But, I have to wake up first, it's early here.
Posted on: 2011/6/19 12:41
17 Posts
Hey i know i been up since 4 here in Arkansas....I wanna thank you guys for all your help...
Posted on: 2011/6/19 12:43
These just don't come out well.
jpg  Code 16a.jpg (0.00 KB)
jpg  Code 16.jpg (0.00 KB)
Posted on: 2011/6/19 13:11
You may be able to save them as a photo on your computer and enlarge them.
Posted on: 2011/6/19 13:12
17 Posts
Yea i just did its pretty easy to read after you blow them up... Thanks .....
Posted on: 2011/6/19 13:13
I'm supprised it worked.
Posted on: 2011/6/19 13:16
17 Posts
WOW, Thats like reading Chinese to me LOL.
I read it, but dont understand it ......
ok your the guru, would you say the opti is doing lunch with the grim reaper? lol
Posted on: 2011/6/19 13:20
It's possible.
Yea, the FSM takes some getting used to.
On the chart, item #2, follow the ignition on/off instructions, disconnect the opti connector ( the one mounted on the right side of the engine). Terminal "A" will be the black/red wire. Set the voltmeter to 20 volts, hook the voltmeter red wire clip to this pin (the harness that goes back towards the firewall) then hook the black voltmeter to ground. Turn on the IGN and see what the voltmeter reads.
Posted on: 2011/6/19 13:33
biggrizzly Re: 93 running issues
Bill, your a saint!
@ ARman, welcome to the Guru! You're in good hands here!
Posted on: 2011/6/19 13:56
17 Posts
WOW i cant even get to the opti from the top side.! Any suggestions
Posted on: 2011/6/19 17:03
The wires from the opti are just a short pigtail that plugs into the harness under the passenger side fuel rail cover.
Posted on: 2011/6/19 17:15
I had one case where the wires to the opti were corroded.
This requires unplugging the harness to the opti at the opti! The harness plugs in on the right side, below the throttle body and kinda under the waterpump.
And yes, the FSM takes getting used to.
If you need a new opti, either get an MSD unit, Dynaspark or GM Delco.
I have the Dynaspark, and a pot load of other tricks I will explain when I am not walking out the door.
Posted on: 2011/6/19 18:19
Yea, I forgot about that one on the GM units. The voltage test should be run at both connectors.
Posted on: 2011/6/19 20:22
17 Posts
Ok guys my work week is over back to the car. LOL, If i replace the opti it should correct my issue>? right?
Posted on: 2011/6/22 19:19
I would confirm the condition of the harness first. If the leads area corroded in any way, they could cause a false code.
If you need to replace:
1. DynaSpark
2. MSD
3. GM Delco
Don't waste money on cheap assed opti kits. Rebuilds/remans are a waste of time and money.
Posted on: 2011/6/22 20:03
jaa1992 Re: 93 running issues
Stone Mtn, GA (near Atlanta)
187 Posts
Andy,
Actually some of the stuff I've read about the recent Dynaspark's would make me leary of them.
The MSD appears to be OK if you open them up and locktite the screws that hold down the wheel and rotor. Which may be over the OP's comfort level.
My 383 and the used iron head LT1 I put in my 92 I'm able to use the later style opti and after 6 months of track days the Summit Racing opti has held up just fine. And I'm not eating ICMs any more
The AC/Delco isn't positively vented so modifying it to an active vent may also be outside your comfort level.
Where in AR are you - maybe there is a guru near you that can help. I know 5 years ago when I replaced the opti on my original 92 engine it was a little intimidating - especially getting the balancer off the hub. I was able to get one of the last original Dynaspark optis and did not have a problem until the engine just got too tired.
Posted on: 2011/6/22 22:34
17 Posts
1. DynaSpark
2. MSD
3. GM Delco
Yeah I know bogus something tells me its something other then the opti being totally junk, but i am no mechanic. I think there is a 85% chance its the harness but man i am at a total lose! I would love some guru close by to offer a helping hand. I can do simple jobs like replacing ICM, fuel pump, coil, but the whole opti harness/unit it selfs alittle over my head.
Posted on: 2011/6/22 23:53
Reread the two pages that Bill posted from his FSM. With a $15 DVOM and less than an hour you can determine if it is the opti of something else. I would be glad to help in person, but Arkansas is a bit far.
Posted on: 2011/6/23 2:01
