223 user(s) are online (143 user(s) are browsing Forums)
Rex_Ruby AVIC D3 install in my Ruby
Philly Suburbs
180 Posts
I was thinking about upgrading the stereo in my 1993 but I’m a complete novice when it comes to audio. As I did my research and ultimately the installation I took the following pictures and write up to document the process. Hope it helps someone! I had put up a post or two asking some audio questions, did a fair amount of reading and called on some members the vette community that I knew had audio knowledge. This research got me to a basic understanding of what I wanted to accomplish. In putting my questions out there a forum member offered me an Avic D3 for free. Thanks TIM!
So I have a nice head unit, I decided to do 6X9 3 way speakers up front and 2 8” subs in the back. From looking at pictures of other C4 installations using 5.5” speakers, researching measurements of some 6X9s and taking apart the front speaker area to take measurements I felt I could make that work. Also my thoughts were the 3 way would give me mid and tweeter. I used the Rockford Forsgate RF R1693. Others had done 8” subs but I still checked the rear areas to make the 8” JBL GTO804 subs fit. I came across a free Alpine MRV100M for the subs. I used a Rockford Forsgate Prime R 150-2 to power the 6X9s.
Here’s the start, always disconnect the battery!
DSC_2085
Original console area, I had an XM set up and a 12 disc CD changers both connected via FM modulators.
DSC_2086
Original right side front Bose speaker.
DSC_2088
Original left side front Bose speaker.
DSC_2089
Original Bose right side rear speaker.
DSC_2090
Original Bose left side rear speaker and 12 disc changer.
DSC_2091
Console bezel removed.
DSC_2094
DSC_2098
Bose head unit removed.
DSC_2100
First fitment of the Avic. Sits too far out, some of the internal plastic needs to be removed.
DSC_2101
The piece that needs to be removed.
DSC_2102
Piece of plastic is removed, I used a drill to drill holes along the edges. Be careful there are a lot of wires around that area!
DSC_2104
Test fit with the bezel looks like it was made to fit! Now the trick is to mount the unit in the dash and have it line up this good!
DSC_2103
I have it mocked in and mounted in the dash and the bezel lines up perfect! But I have no wires behind there yet. I wanted to make sure it would at least fit before doing all the wiring.
DSC_2106
Rear Bose w/o the grille.
DSC_2108
Body cavity the subs will sit in.
DSC_2117
First mock up of the rear subs, I cut some ½” MDF to test the subs fit. The bottom of the sub was touching the car body so this mock up will need some more work.
DSC_2111
Stock Bose cover over the mocked up sub. I’m trying to make this work as I’d like the rears to look stock.
DSC_2112
Adding a layer of ½” MDF on the top changes the mounting angle enough to keep the sub bottom off of the body.
DSC_2113
DSC_2118
DSC_2119
DSC_2120
Sub cavity done up with sound deadener.
DSC_2124
Left ready for sub install.
DSC_2131
Left sub installed.
DSC_2133
Right sub installed.
DSC_2132
You can see on the left side (right in pic) how I angled the MDF to change the sub’s mount angle a litte. Also you can see the 2 MDF strips in the back wall to mount the amp board.
DSC_2134
Bare Bose in the front.
DSC_2135
Wire connections on the 6X9s.
DSC_2136
I wanted to mount the 6X9s so the stock Bose grille would cover. When I mocked that up the 6X9 was sitting too far in and the magnet was sticking to the metal frame rail at the mounting location. I had to move the 6X9 out far enough so it was not too close to the metal frame rail. I was able to set this up so nothing was cut up too much and it could be returned to stock easily. Here is what I came up with using ¼” MDF and piece for the each side.
DSC_2139
DSC_2141
I covered the outer MDF with a black fabric which matches the black grille that came with the 6x9s.
DSC_2137
DSC_2138
DSC_2144
Now that the speakers are installed and the head unit mocked in it’s time to rum some wiring. I removed the drivers seat.
DSC_2145
Nice surprise here, some interior screws and bolts under the carper that must have been left there at Bowling Green!
DSC_2148
DSC_2149
Here’s the power line run in the rear. I ran a ground all the way to the battery.
DSC_2150
Power line up the frame rail.
DSC_2151
Power line out the door post to the battery.
DSC_2152
I bought a Metra kit to tap the power, ground, antenna output and antenna signal at the storage bin behind the pass seat.
DSC_2177
Running the speaker wires, RCA wires to the rear.
DSC_2189
As you saw previously I ran the 4 guage power wire up the left side of the car and all other wires ran down the right side frame rail into the back. Note: the front left speaker runs down the left side but I kept it way from the power wire as much as possible.
DSC_2190
Kind of hard to tell here but the head unit is secure. I used strapping and bent pieces 90 degrees connecting in side to the head unit and the other side to the stock mounting holes.
DSC_2193
Start wiring the amps.
DSC_2194
Almost done wiring the amps.
DSC_2196
Amps wired.
DSC_2201
One of the connections for this unit was to the reverse lights. Using the manual I thought I had it located where it comes inside the car along the rear. I was thinking it was this light green wire but I was wrong!
DSC_2200
It came up over here on the side.
DSC_2199
Finished shots.
DSC_2207
DSC_2209
DSC_2210
DSC_2211
In the end it was all well worth it. I figure I have about 60 hours into this project. I paid about $350.00 for the amps and speakers and about another $300.00 for 12 gauge speaker wire, 4 gauge power wire, RCA wires, fuse holders, wire connectors, sound deadener, MDF and misc. things. The sound it great, major improvement over stock. The nav is cool. I also have the blue tooth add on which works great too. The system also has an ipod hook up. I will probably add XM soon, I’ll have to remove the head unit to run a data wire so at that time I’ll also do the parking brake hack.
Posted on: 2011/6/25 4:03
'94 ZR1 Black on Black - Haibeck chip, Muffler eliminators and X pipe
* PA Plate: OBSSSD
'93 Ruby Coupe ZF6 - Muffler eliminators, Blink Blink kit and Polished ZR1 Wheels
* PA Plate: OBSSSN
'06 Lemans Blue C6 Coupe - Completely stock (wife's)
pianoguy Re: AVIC D3 install in my Ruby
Excellent pics, thanks much!
Posted on: 2011/6/25 4:22
Matatk Re: AVIC D3 install in my Ruby
Looks like you really took your time and did it right! I like your solutions to making non-stock speakers fit. That's what we have to do now on our cars to get better quality sound. Great write up with pics and hope you enjoy your new setup!
Posted on: 2011/6/25 11:06
flyboy Re: AVIC D3 install in my Ruby
Well done!
Posted on: 2011/6/25 17:03
bogus Re: AVIC D3 install in my Ruby
looks great John! You should mention that your basic research meant calling me...
How does it sound?
Posted on: 2011/7/5 19:46
j3studio Re: AVIC D3 install in my Ruby
How does it sound?
I vouch that it sounds (and looks) good ...
... you kids with your loud music!
Posted on: 2011/7/5 22:34
screamin_conure Re: AVIC D3 install in my Ruby
Northwest Indiana
346 Posts
Nice work! Looks like a killer system.
Posted on: 2011/7/7 15:42
