213 user(s) are online (149 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Grand Sport
RPO Z16.
A one year special. 1000 were made to honor both the end of the C4 and the original racers, called Grand Sports, from 1963.
All were...
lenferg 96CE engine bay resto
North Augusta, SC
24 Posts
Had to fix a coolant leak on my 96CE and it turned into something a little more involved...
Before...
During...
And After...
Can't think of a better way to spend a weeks vacation.
Posted on: 2008/1/31 6:08
SpeedHound RE:96CE engine bay resto
Social Circle, GA
119 Posts
much better
Posted on: 2008/1/31 23:47
Trey
www.speedhound.com
pianoguy RE:96CE engine bay resto
Looks great! What did you use on the alternator and AC?
I have pretty much the same task in front of me. I'll be replacing the water pump, putting in a new opti, hoses, wires, plugs and headers. And I have an oil leak to fix somewhere, likely the intake or the crankshaft position sensor.
Posted on: 2008/1/31 23:56
Notorious RE:96CE engine bay resto
A vast improvement and a job well done.
Posted on: 2008/1/31 23:59
lenferg RE:96CE engine bay resto
North Augusta, SC
24 Posts
Thanks. Did the same sort of stuff...coolant leak was a failed gasket where the water pump mounts to the block on the drivers side. Replaced the original opti because it had 118K miles on it. Replaced intake & valve cover gaskets to address oil leaks. Polished the fins on the intake and painted it while it was out. Checked valve lash. New wires & plugs, replaced vacuum and coolant lines as needed. Had the alternator, a/c compressor, air filter housing, computer, and surge tank painted Sebring Silver. Did some general degreasing and cleanup. BTW...wouldn't recommend painting the computer, mine crapped out and I had to buy another one. Don't know why, maybe coincidence....?
Posted on: 2008/2/1 3:20
Social Circle, GA
119 Posts
Could be coincidence on the PCM. I know of plenty of them that were painted. People take the covers off and paint them and then reassemble. I'm planning to do it myself here soon.
Posted on: 2008/2/1 12:51
Trey
www.speedhound.com
skirlin RE:96CE engine bay resto
Caledonia Michigan
277 Posts
Wow, that looks great. I've gotta do that to mine. Thanks for the pictures. :thumbleft:
Posted on: 2008/2/1 16:34
