201 user(s) are online (174 user(s) are browsing Forums)
mistaben quick tunerpro question - how do you know when your in closed loop?
141 Posts
thanks!
Posted on: 2011/9/5 18:08
Matatk Re: quick tunerpro question - how do you know when your in closed loop?
22810 Posts
I haven't looked at Tunerpro in a while...I know on datamaster there is a box that flashes I think red/green with text for open/closed. Have you checked in all the menus?
Posted on: 2011/9/6 2:03
mistaben Re: quick tunerpro question - how do you know when your in closed loop?
141 Posts
yea... i just started letting it idle for aobut 2 mins. I don't think you can update blm's if you are in open loop?
thanks though btw.
Posted on: 2011/9/6 2:37
22810 Posts
I don't think you will be able to adjust blms in open loop either.
Are you running a heated o2 sensor? I had a problem with mine dropping in/out closed loop.
Posted on: 2011/9/6 2:47
141 Posts
how did you know it was dropping in and out of closed loop? datamaster?
I am not using a heated o2 sensor unfortuanately lol, but it is a pretty warm car already... and it is arizona... lol. ... I can try a run with datamaster tomorrow and find out for sure.
good idea btw, thanks.
Posted on: 2011/9/6 4:04
vetteoz Re: quick tunerpro question - how do you know when your in closed loop?
Datamaster has a box at top RH that says Open Loop in yellow in OL ;shows Clsd Loop in green when in CL
When O2 is working correctly ,O2 voltage should rapidly change from say 300 -700 and back again
Stock the CL timer is set at 3 minutes for a cold start.
Posted on: 2011/9/6 6:52
joshwilson3 Re: quick tunerpro question - how do you know when your in closed loop?
56 Posts
How do you know if you're running rich or lean in open loop?
Posted on: 2011/9/21 5:45
Woodstock Re: quick tunerpro question - how do you know when your in closed loop?
Bremen/Germany
369 Posts
Common senses, spark plugs, exhaust gases or wideband O2.
New TP Version 5 has the "closed loop" checkbox on the bottom of "Show Data List Views". The old Version 4.x, which I still prefer, has it under "F" values.
Posted on: 2011/9/21 8:08
91 convertible
flyboy Re: quick tunerpro question - how do you know when your in closed loop?
jpg  P1010002.JPG (129.75 KB)
1735_4e79ddebd478c.jpg 640X480 px
Posted on: 2011/9/21 12:52
56 Posts
flyboy wrote:
That doesn't tell you if it is running rich or lean in open loop.
But I guess just get the BLM's right in closed loop, then it should hopefully be running correct in open loop.
Posted on: 2011/9/22 2:11
56 Posts
I don't have a wideband 02, I keep everything stock. Don't have anything to check exhaust gases with.
Don't see how you can look at spark plugs to check if its running lean or rich in open loop.
Posted on: 2011/9/22 2:15
141 Posts
sure you could. start and stop the engine running it for about 2 minutes total a couple of times...
pull the plugs and check 'em.
Posted on: 2011/9/22 5:25
89Vette Re: quick tunerpro question - how do you know when your in closed loop?
135 Posts
thanks!
In case you still need to know...
Below the large variable window (where ALDL Dash items are normally being monitered), you'll see 5 tabs.
ALDL Values
ALDL Dash
ALDL Flags
ALDL Monitors
Item Comments
About the 3rd item down on the ALDL Flags tab is the Open Loop status. It'll say OPEN or CLOSED.
Posted on: 2011/9/22 14:19
141 Posts
89Vette wrote:
thanks!
ALDL Values
ALDL Dash
ALDL Flags
ALDL Monitors
Item Comments
oh! - no i never knew that! thankyou!
Posted on: 2011/9/26 22:35
