255 user(s) are online (155 user(s) are browsing Forums)
freakd new front tires
727 Posts
woohoo, i had them put on, man the others were crap, like riding rails now :thumbright:
Posted on: 2006/8/10 20:13
CREWZIN Re: new front tires
Lecanto, Florida
78 Posts
WELL!!! What kind were they?
I just upgraded to 17 inch. New wheels, tires, rotors and pads. I went with the BF Goodrich G Force Sport 275x40x17 and they ride and handle great.
Posted on: 2006/9/7 12:23
PeteK RE:new front tires
Good 16 inch tires are getting tougher to find. BFG discontinued my favorite tire a couple of years ago. I wound up going with Kuhmo's. They are a better tire than I expected.
The old set on my car was 10 years old. New sneakers always make a difference. :thumbleft:
Posted on: 2006/9/7 12:40
90EXPVette RE:new front tires
Martinez, Georgia
185 Posts
When I bought the Vette it had some old weird tires on there (I don't even remember the name of them now). I was amazed at the power since I couldn't keep traction in 1st, 2nd or 3rd...floor it and the rear end got twitchy. Hard tires...I replaced em with 315's in the rear not it only does that when I want it to (but not in 3rd)
Posted on: 2006/9/7 15:31
red_johnny RE:new front tires
New tires would be great! Heres a question, what PSI do you use. I mean, how much. I am at 26lbs in each tire and I am thinking that is alittle low. I want to raise it up to 32lbs. I would think I could get better gas milage and traction.
Posted on: 2006/9/7 15:58
CREWZIN RE:new front tires
Lecanto, Florida
78 Posts
My 87 door sticker calls for 35psi in both front and rear. I run 36 all around.
Posted on: 2006/9/7 17:18
Martinez, Georgia
185 Posts
26 is too low....32 is what I keep mine at. You'll feel the difference!
Posted on: 2006/9/7 17:37
Ok, I dont know why they were at 26 lbs. I will have to fill them up next time I fill up on gas Which by the way, is now at $2.57
Posted on: 2006/9/8 0:35
xrcrx tires
Webster TX
83 Posts
Kumhos are actually very good tires. I just put 17's on my 84 and went with 315's rear and 275's front. Love it! Handles great!
Posted on: 2006/9/8 5:53
Eric
84 Z51 Auto
05 Repsol Rep
00 TLR 1000
CasetheCorvetteman RE:new front tires
Do you blokes put nitrogen in your tyres over there? Ive always run it in mine on both my Corvettes, i remember when i made the change on the 87 it was noticed, but not so much on the 94 (had alot of other stuff done at the same time though)
Posted on: 2006/9/8 13:10
Lecanto, Florida
78 Posts
I've heard a lot of good things about running Nitrogen in the tires and a few of the owners in my PT Cruiser clubs do use it. My problem would be to have to go to the few and far between dealers to add any that is lost. It's not like everyone carries the stuff. I keep an eye on all my cars and check them at least every month (if not sooner). I add even 1 pound if one of the tires is lower than the others and I'd hate to run to a Nitrogen dealer to add 1 pound...they think I'm nuts. :tongue:
Posted on: 2006/9/8 13:30
Ive found it holds presure very well, ive never had to add any at any stage, but over here you can get it reasonably easy, so that is good
Posted on: 2006/9/8 14:49
freakd RE:new front tires
727 Posts
ok, i got smitomo htrz. i'm running 35lbs of pressure. i like the sumitomos, they are good tires for the $$$ :thumbright:
Posted on: 2006/9/9 11:10
I got rid of the Sumitomos and put a couple Hankook Ventus sport on a couple of my wheels a while back, they stick alot better than the Sumitomos and where cheaper for me here in Australia
Posted on: 2006/9/9 13:36
