Dads90 | Chip advice.. | ||
I 'am considering a chip from pcmforless. My car is stock except for replaced injectors. (Ford SVO yellow tops) The reason, after months of driving I've had a slight miss. Nothing bad, just the nagging, every couple of seconds, miss. Done pretty much all you would consider. Wires, plugs, rotor, cap, didn't replace the coil (the gizmo on the top of dist.) replaced the CTS, IAC, reset idle, timing, no codes. Would I be wasting my money? , am I dreaming this might solve my problem?. What would the chip do for me, other turn my fans on at a requested temp ?
Posted on: 2008/2/6 3:13
1990 Silver Blue Metallic, ZF6, Hurst shifter, Z51, Dana 44 3.33 ratio, FX3 system, mostly stock. |
jsup | Re: Chip advice.. | ||
I 'am considering a chip from pcmforless. My car is stock except for replaced injectors. (Ford SVO yellow tops) The reason, after months of driving I've had a slight miss. Nothing bad, just the nagging, every couple of seconds, miss. Done pretty much all you would consider. Wires, plugs, rotor, cap, didn't replace the coil (the gizmo on the top of dist.) replaced the CTS, IAC, reset idle, timing, no codes. Would I be wasting my money? , am I dreaming this might solve my problem?. What would the chip do for me, other turn my fans on at a requested temp ? I sent you a PM with details. I have a chip I have been running in my car before the mods. If you want to try it, I'll send it to you. If you like it, keep it. If not, send it back. See your PM with details. |
Posted on: 2008/2/6 3:32
Steve40th | Re: Chip advice.. | ||
Quote: The chip has to have the right ID on it to work, I believe. |
Posted on: 2008/2/6 3:34
Ko'u ohana aia ku'a ikaika |
Quote: Not when I purchased it. I called him gave him the year, he programmed it and I picked it up. Now, I am sure it's not as good as a dyno tune, but for a stock car, it ran great. My goal was simply to turn down the fan temp, which it does. It also advances the timing and changes the fuel delivery. I had Chuck at Corvettes of Westchester look at the programming, he said it's close enough to what he would do that there's no point in having him do a new one. I believe he gets his chips from PCMFORLESS, but I can't be sure. Based on his representation I believe the original guy did a decent job. |
Posted on: 2008/2/6 3:45
Dads90 | RE:Chip advice.. | ||
I will give it a try. I tried to call Alvin at PCMforless today and got a recorded message. I want to talk to someone before I would send it in. Really don't even know how the process works. Its my daily driver and I can't be without it.
Posted on: 2008/2/6 3:59
jsup | RE:Chip advice.. | ||
Honestly, on a stock car, I think you'll be happy with this one. If not, no big deal. It's a five minute job to put in. Three 10MM nuts, and four 1/4 inch screws on the bottom.
Posted on: 2008/2/6 4:02
Lettttttttts doooooooo ittttt !!!
Posted on: 2008/2/6 4:06
You can datalog it, or get someone who can, and send the files to PCM for less and ask him how much he can improve it....
Posted on: 2008/2/6 4:08
Woodstock | RE:Chip advice.. | ||
When do you have the miss, during idle or while driving?
To swap 90 and 91 chips is ok, but you'll have to compare transmissions and axle ratio. |
Posted on: 2008/2/6 12:43
91 convertible |
When do you have the miss, during idle or while driving? Oh crap, you're right. They're both 90s but Dad90 is a six speed, I have an auto. Won't work will it? |
Posted on: 2008/2/6 14:49
Well, for diagnostic purposes, I swapped an auto 2.59 chip for an auto 3.07 axle ratio chip. It wasn't the chip, but a previously intermittent problem became a permanent code and helped troubleshooting the problem. I guess we got lucky on that one.
With auto probably being 2.59 and manual 3.45 axle ratio, I doubt it would make any sense for Dads90 to swap chips. I would assume, using an auto chip in a manual set up is not so much a problem as vice versa. |
Posted on: 2008/2/6 15:49
91 convertible |
Well, for diagnostic purposes, I swapped an auto 2.59 chip for an auto 3.07 axle ratio chip. It wasn't the chip, but a previously intermittent problem became a permanent code and helped troubleshooting the problem. I guess we got lucky on that one. Dads90, before I go through the trouble, see if you can find out. I have a 3.07 rear auto. |
Posted on: 2008/2/6 16:48
I know its the Dana 44, but I can't see the ID plate on the rear end. It hidden by the spare tire tray. The miss is at idle. It's probably best I do some more checking before you send it to me. Thanks for the thought, jsup
Posted on: 2008/2/7 4:53
Midnight85 | RE:Chip advice.. | ||
I realize you have replaced the wires
and related parts but before you go any further, have you tried looking at the wires in the dark? I mean total darkness with no lights anywhere. Try it and look for small arcs while the car is idling. If you find any then you have probably found your miss. |
Posted on: 2008/2/7 17:40
HORSEPOWER! Some is good, more is better, too much is just right. |
I realize you have replaced the wires I have tried this. In my garage at midnight, garage door open of course. No arcing going on. All this after a injector replacement. |
Posted on: 2008/2/8 4:36
OK check the RPO codes in my car and I got the 3.33 ratio. Would this chip that Jsup is offering make any difference ? For diagnostics purposes if I put it in would I notice a smoother or even a rougher idle at least. I guess I'm looking for a solution in the programming/ECM department. I hope this makes sense. I don't want to spend big money on a chip and net nothing.
Posted on: 2008/2/9 3:36
Have you talked to pcmforless?
I can't see where the chip would be the cause of your miss. Any reputable tuner would not sell you a chip unless they thought it would help. |
Posted on: 2008/2/9 4:29
Have you talked to pcmforless? I called PCMforless and they were out of the office. Got their recorder. I will probably call again. I only have the stock setup, no chip. The car runs good, I just can't figure this miss out, it will probably need to go to a local tuner. |
Posted on: 2008/2/9 4:52
