321 user(s) are online (257 user(s) are browsing Forums)
Also known as the DIC.
Dads90 Chip advice..
Pearland, Tx
318 Posts
I 'am considering a chip from pcmforless. My car is stock except for replaced injectors. (Ford SVO yellow tops) The reason, after months of driving I've had a slight miss. Nothing bad, just the nagging, every couple of seconds, miss. Done pretty much all you would consider. Wires, plugs, rotor, cap, didn't replace the coil (the gizmo on the top of dist.) replaced the CTS, IAC, reset idle, timing, no codes. Would I be wasting my money? , am I dreaming this might solve my problem?. What would the chip do for me, other turn my fans on at a requested temp ?
Posted on: 2008/2/6 3:13
jsup Re: Chip advice..
1778 Posts
I sent you a PM with details. I have a chip I have been running in my car before the mods.
If you want to try it, I'll send it to you. If you like it, keep it. If not, send it back.
See your PM with details.
Posted on: 2008/2/6 3:32
Steve40th Re: Chip advice..
1114 Posts
The chip has to have the right ID on it to work, I believe.
Posted on: 2008/2/6 3:34
Ko'u ohana aia ku'a ikaika
1778 Posts
Not when I purchased it. I called him gave him the year, he programmed it and I picked it up.
Now, I am sure it's not as good as a dyno tune, but for a stock car, it ran great. My goal was simply to turn down the fan temp, which it does. It also advances the timing and changes the fuel delivery.
I had Chuck at Corvettes of Westchester look at the programming, he said it's close enough to what he would do that there's no point in having him do a new one. I believe he gets his chips from PCMFORLESS, but I can't be sure. Based on his representation I believe the original guy did a decent job.
Posted on: 2008/2/6 3:45
Dads90 RE:Chip advice..
Pearland, Tx
318 Posts
I will give it a try. I tried to call Alvin at PCMforless today and got a recorded message. I want to talk to someone before I would send it in. Really don't even know how the process works. Its my daily driver and I can't be without it.
Posted on: 2008/2/6 3:59
jsup RE:Chip advice..
1778 Posts
Honestly, on a stock car, I think you'll be happy with this one. If not, no big deal. It's a five minute job to put in. Three 10MM nuts, and four 1/4 inch screws on the bottom.
Posted on: 2008/2/6 4:02
Pearland, Tx
318 Posts
Lettttttttts doooooooo ittttt !!!
Posted on: 2008/2/6 4:06
1778 Posts
You can datalog it, or get someone who can, and send the files to PCM for less and ask him how much he can improve it....
Posted on: 2008/2/6 4:08
Woodstock RE:Chip advice..
Bremen/Germany
369 Posts
When do you have the miss, during idle or while driving?
To swap 90 and 91 chips is ok, but you'll have to compare transmissions and axle ratio.
Posted on: 2008/2/6 12:43
91 convertible
1778 Posts
Oh crap, you're right. They're both 90s but Dad90 is a six speed, I have an auto. Won't work will it?
Posted on: 2008/2/6 14:49
Bremen/Germany
369 Posts
Well, for diagnostic purposes, I swapped an auto 2.59 chip for an auto 3.07 axle ratio chip. It wasn't the chip, but a previously intermittent problem became a permanent code and helped troubleshooting the problem. I guess we got lucky on that one.
With auto probably being 2.59 and manual 3.45 axle ratio, I doubt it would make any sense for Dads90 to swap chips.
I would assume, using an auto chip in a manual set up is not so much a problem as vice versa.
Posted on: 2008/2/6 15:49
91 convertible
1778 Posts
Dads90, before I go through the trouble, see if you can find out. I have a 3.07 rear auto.
Posted on: 2008/2/6 16:48
Pearland, Tx
318 Posts
I know its the Dana 44, but I can't see the ID plate on the rear end. It hidden by the spare tire tray. The miss is at idle. It's probably best I do some more checking before you send it to me. Thanks for the thought, jsup
Posted on: 2008/2/7 4:53
Midnight85 RE:Chip advice..
Streator, IL.
264 Posts
I realize you have replaced the wires
and related parts but before you go
any further, have you tried looking
at the wires in the dark? I mean total
darkness with no lights anywhere.
Try it and look for small arcs while
the car is idling. If you find any then
you have probably found your miss.
Posted on: 2008/2/7 17:40
Pearland, Tx
318 Posts
I have tried this. In my garage at midnight, garage door open of course. No arcing going on. All this after a injector replacement.
Posted on: 2008/2/8 4:36
Pearland, Tx
318 Posts
OK check the RPO codes in my car and I got the 3.33 ratio. Would this chip that Jsup is offering make any difference ? For diagnostics purposes if I put it in would I notice a smoother or even a rougher idle at least. I guess I'm looking for a solution in the programming/ECM department. I hope this makes sense. I don't want to spend big money on a chip and net nothing.
Posted on: 2008/2/9 3:36
Streator, IL.
264 Posts
Have you talked to pcmforless?
I can't see where the chip would
be the cause of your miss.
Any reputable tuner would not sell
you a chip unless they thought it
would help.
Posted on: 2008/2/9 4:29
Pearland, Tx
318 Posts
would help.
I called PCMforless and they were out of the office. Got their recorder. I will probably call again. I only have the stock setup, no chip. The car runs good, I just can't figure this miss out, it will probably need to go to a local tuner.
Posted on: 2008/2/9 4:52
