137 user(s) are online (113 user(s) are browsing Forums)
Transverse Leaf Spring
BillH Small block Water Pump Rebuild
SBC w/p rebuild, the kit is $25.
Good if you want to keep a pump with the correct part numbers.
The pump was working fine but I thought it best to rebuild. It was schmuky and the inside was rusty of course.
jpg  2006-02-23 08-02-18_0001.JPG (0.00 KB)
jpg  2006-05-26 06-21-51_0002.JPG (0.00 KB)
Posted on: 2012/1/30 23:14
BillH Re: Small block Water Pump Rebuild
Press off the fan hub, press out the shaft & bearing assy. and press the impeller off the old shaft.
The kit has all the parts including a tool to evenly press in the internal seal.
jpg  2006-05-26 06-19-30_0001.JPG (0.00 KB)
jpg  2006-05-26 07-02-15_0004.JPG (0.00 KB)
jpg  2006-05-26 07-15-17_0008.JPG (0.00 KB)
Posted on: 2012/1/30 23:17
Glass bead that parts especially the inside of the pump.
Install the new shaft/bearings/seals.
Install the new internal seal with some RTV.
Press on the fan hub to the correct dimension.
jpg  2006-05-26 07-33-17_0009.JPG (0.00 KB)
jpg  2006-05-26 07-42-18_0010.JPG (0.00 KB)
jpg  2006-05-26 07-55-31_0011.JPG (0.00 KB)
Posted on: 2012/1/30 23:20
Press on the impeller to the correct clearance to the housing. The dim. is 0.010 - 0.035. I use 0.012.
Pump's done and ready for paint.
jpg  2006-05-26 08-13-02_0012.JPG (0.00 KB)
jpg  2006-05-26 08-19-38_0013.JPG (0.00 KB)
jpg  2006-05-26 08-19-49_0014.JPG (0.00 KB)
Posted on: 2012/1/30 23:23
Ultraman Re: Small block Water Pump Rebuild
14746 Posts
Nice work......you better hit the casino to unwind some.....
Posted on: 2012/1/30 23:36
I was in this morning for 10 minutes, took in $20, left with $345. Probably shouldn't try to double dip. :binky:
Posted on: 2012/1/30 23:43
Matatk Re: Small block Water Pump Rebuild
Wow that looks like a brand new pump. Will it be painted or is it a natural finish? Clear coat?
Posted on: 2012/1/31 0:04
The fan hub will be black. The pump orange. If I do it "factory" , the pump will be bolted to the block and then painted.
I'll probably bolt it up since the bolt heads get painted orange too.
Posted on: 2012/1/31 0:22
j3studio Re: Small block Water Pump Rebuild
Looks good!
I have to remember to check this out since there's actually some activity in C1 ...
Posted on: 2012/2/1 18:16
