Steve40th | Whats this little white part? Ignition switch in column area | ||
93 vette. This little white tab that is by the ignition switch black bolt and overlapping the silver torx bolt vats section broke off.
Posted on: 2008/2/8 4:01
Ko'u ohana aia ku'a ikaika |
bogus | RE:Whats this little white part? Ignition switch in column area | ||
I see it... but I don't believe that's the problem...
Posted on: 2008/2/8 4:32
Steve40th | RE:Whats this little white part? Ignition switch in column area | ||
I see it... but I don't believe that's the problem... Huh? What is it? Is it important to the ignition?Vats? |
Posted on: 2008/2/8 4:50
rayquayle | RE:Whats this little white part? Ignition switch in column area | ||
Steve,
I think that white tab is part of the retainer for the key-in reminder buzzer. The two copper contacts that extend from the white plastic to the left at about 10:30 over the VATS contact wires. Even if you removed this piece (plastic retainer housing copper contacts) you'd only lose your key-in warning buzzer. |
Posted on: 2008/2/8 6:59
Ray Quayle in England '86 Indy PaceCar, 4+3 NCM Founder #2896 NCM Lifetime #672 Graduate of Gordon's School |
CentralCoaster | RE:Whats this little white part? Ignition switch in column area | ||
It's not a contact for the horn? That needs something it can contact over the course of rotating the wheel 2 turns...
Posted on: 2008/2/8 7:17
BillH | RE:Whats this little white part? Ignition switch in column area | ||
Looking in the 92 FSM, it looks like the key buzzer switch assembly but the pic in the FSM isn't as good as Steve's.
Posted on: 2008/2/8 14:49
Thanks guys. It snapped off, as it is very brittle.
Posted on: 2008/2/8 17:34
