131 user(s) are online (96 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
Steve40th Whats this little white part? Ignition switch in column area
1114 Posts
93 vette. This little white tab that is by the ignition switch black bolt and overlapping the silver torx bolt vats section broke off.
Posted on: 2008/2/8 4:01
Ko'u ohana aia ku'a ikaika
bogus RE:Whats this little white part? Ignition switch in column area
20860 Posts
I see it... but I don't believe that's the problem...
Posted on: 2008/2/8 4:32
Steve40th RE:Whats this little white part? Ignition switch in column area
1114 Posts
Huh? What is it? Is it important to the ignition?Vats?
Posted on: 2008/2/8 4:50
rayquayle RE:Whats this little white part? Ignition switch in column area
139 Posts
Steve,
I think that white tab is part of the retainer for the key-in reminder buzzer. The two copper contacts that extend from the white plastic to the left at about 10:30 over the VATS contact wires. Even if you removed this piece (plastic retainer housing copper contacts) you'd only lose your key-in warning buzzer.
Posted on: 2008/2/8 6:59
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
CentralCoaster RE:Whats this little white part? Ignition switch in column area
It's not a contact for the horn? That needs something it can contact over the course of rotating the wheel 2 turns...
Posted on: 2008/2/8 7:17
BillH RE:Whats this little white part? Ignition switch in column area
Looking in the 92 FSM, it looks like the key buzzer switch assembly but the pic in the FSM isn't as good as Steve's.
Posted on: 2008/2/8 14:49
1114 Posts
Thanks guys. It snapped off, as it is very brittle.
Posted on: 2008/2/8 17:34
