113 user(s) are online (79 user(s) are browsing Forums)
Also known as SMC.
The only issu...
« 1 (2)
marv02 Re: FUEL RETURN LINE
California City Ca
130 Posts
Nope when you forget the fitting the line you spent hours to get it right is junk start all over again Ya it get you mad.
With any luck it will be time to go home for the Day LOL.
We have a CNC tube bender it good if you'r making bunch of the same lines or you have a titanium line you can't bend with the manual tubing rack bender.
But setting up the CNC bender is a pain in the you know where.
Posted on: 2012/2/18 2:26
istter1 Re: FUEL RETURN LINE
Bakersfield Ca
2336 Posts
So there are 3 lines going to the fuel tank. The line I got an adapter for isn't fricken needed. LOL. pulling the old lines out was a pain in the a??. Will finish in the morning son is tired. We are having fun. It is going to look and work great.
Can't say thanks enough
Steve
Posted on: 2012/2/18 5:12
Carol Burnett
California City Ca
130 Posts
Steve
Ha Ha told you they were a pain but can be done LOL.
Posted on: 2012/2/18 5:41
Bakersfield Ca
2336 Posts
marv02 wrote:
Steve
Visual inspection of the lines show our timing on starting this progress was perfect.. One of the lines had been rubbing on the hole under the airconditioning pump. Another of the line was showing signs of heat rott.
Steve
Posted on: 2012/2/18 5:54
Carol Burnett
Bakersfield Ca
2336 Posts
Something I didn't talk about was the smell from the old fule filter. The gas going in to it smelled fine.The gas coming out smelled like it sat in an old abandoned vehicle for a couple of years. Not a good sign. Last year when I had someone work on it I paid for a new filter. Low it looks like I got the filter and it went in someones else car.
Steve
Posted on: 2012/2/18 6:40
Carol Burnett
Bakersfield Ca
2336 Posts
Well broke my golden rule when working on my vehicles don't drink. Was going out to measure the legnth of hoses from fule rail to the fule filter and return line and wamo. We put the fittings in the fule rail. I forgot whether the fule filter line is on the passanger side ore the driver side. My son I hope remembers or back to pulling fittings off before cutting the SS fule lines. LOL
Steve
jpg  dumbass-400x320.jpg (20.34 KB)
5144_4f3fcf5a16d20.jpg 400X320 px
Posted on: 2012/2/18 16:18
Carol Burnett
California City Ca
130 Posts
I dont trust shops that one of the reasons why.
I had a loca; shop rebuild my trans it was BOHCA time.
I got screwed I end up buying a complete new trans from a know trans builder I knew better that try a cheeper way of doing things.
Steve
Posted on: 2012/2/18 19:54
bogus Re: FUEL RETURN LINE
fuel filter is on the passengers side rail.
This could also be a good chance to find a better - more maintenance friendly - location... or even part!
This of something trick like this, which could be mounted up on the frame rail somewhere... far away from the heat of the exhaust!
http://www.summitracing.com/parts/AEI-12308/?rtype=10
Just an idea.
Also, when you get the SS line, get the teflon core. It will hold up a lot better than rubber core.
Posted on: 2012/2/18 20:05
Bakersfield Ca
2336 Posts
Just an idea.
I like that idea Andy. For now we will hook it up the old way and when I order more parts I will look while it's up on the lift and continue this transformation. I hate the cat being so close. Easter vacation I have a week off will try this idea then.
Great minds think alike You and Marvin are pretty sharp.
Steve
Posted on: 2012/2/18 20:37
Carol Burnett
Bakersfield Ca
2336 Posts
It is alive. The power is back must have been a bad fule filter.
WILL try your idea next andy. Those SS lines and fittings were a snap.
Thanks Marvin Very happy camper
Steve
jpg  ss2.jpg (273.97 KB)
5144_4f4053162aa73.jpg 2048X1536 px
jpg  ss1.jpg (270.86 KB)
5144_4f405336e7a4b.jpg 2048X1536 px
Posted on: 2012/2/19 1:43
Carol Burnett
Matatk Re: FUEL RETURN LINE
22996 Posts
I've seen on some modified fuel line setups where the filter was moved to the area of the blower housing along the firewall. Makes changing it much easier.
Also, did you run the new lines all the way back to the fuel tank?
Posted on: 2012/2/19 2:42
California City Ca
130 Posts
Looks good I glad it worked out for you.
Like I said before at least if starts leaking again ever you can see it not under the AC pump where you cant.
Steve
Posted on: 2012/2/19 2:47
Bakersfield Ca
2336 Posts
That will be part of my easter project . Unless I go on another Cruise.
Steve
Posted on: 2012/2/19 3:28
Carol Burnett
California City Ca
130 Posts
Dont change them to SS Hose unless the hard lines are bad.
If they are bad put hard lines back in.
Posted on: 2012/2/19 3:37
Bakersfield Ca
2336 Posts
I am only looking at changing the location of the fuel filter if if is a safe secure area. Not the lines,
Steve
Posted on: 2012/2/19 4:52
Carol Burnett
Bakersfield Ca
2336 Posts
Couple of minor problems so far. Lines rubbing in two spots. One on the underside of the hood. Put painters tape so when I get home from work tomorrow I can tell if that is the spot. There were some new markes in the area from the body shop this may be one of them. The other is on the silver bracket on the airconditioning pump. Very minor. Son bring rubber over Sat. He had all the crap vehicles at his house.
The other problem has happened twice now. After driving for several days (running great) I stop at COSCO to get gas . Truck is filling tanks. I go to open the cap and the cape is not screwed on. I fill the tank, try to start the engine and it acts like it has no gas. Crank it again starts to go almost dies I give it gas works fine till tonight. Leaving for the Gym it does the same thing. I do the same process and it runs fine. I either got crap fom the COSCO gas or the extra filter is causing a problem. Just a guess.
[quote]
That is the return line, if it does get blocked, problems will ensue... things like bursting lines and such. It will keep throwing pressure and eventually, something will burst. It will not go back from whence it came.[quote]
All lines are fine nothing kinked. Will change filter sat.
Replacement element is AC Delco # GF157.
http://www.summitracing.com/parts/ACF-GF157/
Any idea if the Fram cg20dp or NAPA fil327 will fit?
Steve
jpg  IMG00310-20120222-2019.jpg (180.57 KB)
5144_4f45c337197a8.jpg 2048X1536 px
jpg  IMG00311-20120222-2023.jpg (88.03 KB)
5144_4f45c34de52ee.jpg 1024X768 px
Posted on: 2012/2/23 4:52
Carol Burnett
California City Ca
130 Posts
I need to take a look at my hood.
Posted on: 2012/2/23 13:50
Bakersfield Ca
2336 Posts
It just bareley touches it .
Posted on: 2012/2/23 14:15
Carol Burnett
Bakersfield Ca
2336 Posts
No new marks on hood will go for a long windy drive on the way home.
Posted on: 2012/2/23 19:16
Carol Burnett
Bakersfield Ca
2336 Posts
Found exact spot using tape One more tie did the trick. For now. Not touching hood or air.
Pain in the butt finding AC delco Filter here in town Marvin. Car Quest had a bunch of them. Sat time to replace.
How are you holding up Brad? Take it easy working on that car. Will be warming up in the Lone Pine area this week end.
Steve
jpg  fixed.jpg (181.70 KB)
5144_4f46f53c80e1b.jpg 1536X1152 px
Posted on: 2012/2/24 2:24
Carol Burnett
look'n sharp! Great improvement!
And better to service, too.
Posted on: 2012/2/24 15:44
22996 Posts
You can wrap some old radiator hose or fuel line around the rubbing areas.
As far as your starting problems, you need to do a fuel pressure and leakdown test.
Posted on: 2012/2/24 16:35
Bakersfield Ca
2336 Posts
Stealing a hose off one of my son's wrecked jeeps. Will be changing filter tomorrow morning. Test it for a week and if needed preform the test you suggested. The fule filter on the return line acording to the service may be the one installed years ago. The other fuel filter was changer every two years.
Funny I didn't know that 87 vetts had two fuel filters.
Steve
Posted on: 2012/2/24 22:57
Carol Burnett
BillH Re: FUEL RETURN LINE
I think you outa leave the blue tape on. It wouldn't necessarily mean "RedNeck" or anything .toothy10
jpg  38_medium.jpg (0.00 KB)
Posted on: 2012/2/24 23:11
I fixed a leaky exhaust with a cut up soda can and a couple of clamps... lasted them until they could get the pipe fixed right... which ended up being about 6 months before they junked the car. I was a little sad, really. It was a mid-70s Mercury Capri. Liked those little things. best car ford had in that seriously tragic era.
Posted on: 2012/2/25 0:08
Bakersfield Ca
2336 Posts
I would let my son see that picture and the next thing I would know is he would try it. LOL
Steve
Posted on: 2012/2/25 0:52
Carol Burnett
California City Ca
130 Posts
When you're broke down middle of NO where who cares what it looks like as long as it got you some where safe or got you home thats what counts.
Been there my selfs many times before LOL.
Posted on: 2012/2/25 3:08
Bakersfield Ca
2336 Posts
When your driving a classic or a piece of junk you have to be inventive to keep her going.
Steve
Posted on: 2012/2/25 4:10
Carol Burnett
Bakersfield Ca
2336 Posts
What type of wrench do you use on this canaster to get it off without crushing it? Top picture is my filter in car have not removed it like the bottom picture.
http://www.autopartsexpress.com/searc ... id=281460516&ctt_nwtype=e
Steve
jpg  filter2.jpg (178.94 KB)
5144_4f487ea2b3813.jpg 2048X1536 px
jpg  Filter.jpg (136.54 KB)
5144_4f487ebc706ea.jpg 692X546 px
Posted on: 2012/2/25 6:25
Edited by istter1 on 2012/2/25 6:48:12
Edited by istter1 on 2012/2/25 6:51:02
Carol Burnett
Bakersfield Ca
2336 Posts
Gona soak this baby in Part blaster see if that helps before I get pissed off remove the hole thing in the morning.
ACDelco Gf62
From $32- $90
not always in stock
the filter ac delco gf157 that goes in side is $3
lol
steve
Posted on: 2012/2/25 7:32
Carol Burnett
Woodstock Re: FUEL RETURN LINE
Bremen/Germany
369 Posts
How about putting it first in a pot with boiling water?
Posted on: 2012/2/25 12:24
91 convertible
Steve
A strap wrench - quite handy, I have a couple.
$7 at Harbor Ft.
jpg  strap.jpg (0.00 KB)
Posted on: 2012/2/25 14:28
Bakersfield Ca
2336 Posts
BillH wrote:
Steve
$7 at Harbor Ft.
My son and I were just talking about if harbor freight has one. When they open up this morning I will be the first in line.
If that does't work I will remove the whole unit put it in a vice and gently beat it to death with a big hammer.
Steve
Posted on: 2012/2/25 15:02
Carol Burnett
istter1 wrote:
BillH wrote:
Steve
$7 at Harbor Ft.
Steve
Drill a hole thru it and stick a big ass phillips screwdriver thru the holes - leverage.
Posted on: 2012/2/25 15:12
Bakersfield Ca
2336 Posts
BillH wrote:
istter1 wrote:
BillH wrote:
Steve
$7 at Harbor Ft.
Steve
I thought that was an oil filter wrench. Being a red neck. Didn't think about it being universal.
Steve
Posted on: 2012/2/25 15:21
Carol Burnett
istter1 wrote:
BillH wrote:
istter1 wrote:
BillH wrote:
Steve
$7 at Harbor Ft.
Steve
Steve
I used it to open a pickle jar once.
Posted on: 2012/2/25 15:33
Bakersfield Ca
2336 Posts
You must of been hungry. Were you cooking the rest of your meal on the manifold at the same time?
Posted on: 2012/2/25 15:39
Carol Burnett
Bakersfield Ca
2336 Posts
Thanks Bill the Harbor Freights Strap Wrench on sale for $4.99 worked great. The o-ring was rotted and the filter was totally clogged. Who knows how many years this one has been on there. I used anti-size on the o-ring and threads. No leaks motor fired right up. Going to wash up and go for a test ride.
Steve
jpg  filter1.jpg (334.01 KB)
5144_4f4933dc68770.jpg 2048X1536 px
jpg  oring.jpg (350.56 KB)
5144_4f4933fdbe2df.jpg 1792X1344 px
Posted on: 2012/2/25 19:22
Carol Burnett
Bakersfield Ca
2336 Posts
Steve
Went for the test drive and it just keep getting better. Before between 4500-5000 there was a little hesatitation but that is gone. Toke it out on Taft Hwy passing Carrot trucks (Bunny Luv) 2nd -4th flying.
Thanks to all Marvin, Vetteoz (from Down Under), Bill, Brad and everyone else on the Guru chat.
Marvin if you go to Willow springs would love to come out and watch.
Next weekend here is Famosa Drags 1st-4th. Looking for tools and parts.
Don't you love it when you stomp on the gas throws your head back and you sink into the seat. Lol
Steve
pdf coors corvette@indy 1984.pdf Size: 187.43 KB; Hits: 222
jpg  Warren Coburn Rain for rent.jpg (58.07 KB)
5144_4f494a030bfae.jpg 625X414 px
Posted on: 2012/2/25 20:52
Carol Burnett
Bakersfield Ca
2336 Posts
Steve
While browsing the Swaps at the Famosa drags today I found one of these filter and asked the guy what type of wrench was used to take the filter loose.He showed me the wrench in the picture. He sent me up to one of the parts venders and they sold me this for $6
It is ajustable not like the one Harbor freight has.It has teeth on it that fit the pattern on the end of the filter. Will try it next time I change my filter.
jpg  filter ren.jpg (327.31 KB)
5144_4f52dc1ab2af4.jpg 2048X1536 px
5144_4f52dc6a895f5.jpg 692X546 px
Posted on: 2012/3/4 3:11
Carol Burnett
I am glad it's all back together and working great!
Posted on: 2012/3/4 7:40
Bakersfield Ca
2336 Posts
We had a little problem with the motor being starved for fuel 1-3 times a week> Checked everything out fule pump, strainer, fule pressure reg.
Works great after the long trip to the beach. When I changed lines and the last filter must have gotten some juck in the line.
Marvin idea on the lines is great.
Thanks
Posted on: 2012/4/23 4:58
Carol Burnett
It sounds like your car sat a lot, that does explain some of these freaky problems your having.
Posted on: 2012/4/23 5:25
Bakersfield Ca
2336 Posts
Parked for a few years in a back yard I was told. They didn'y have time or money to work on her.
Posted on: 2012/4/23 6:54
Carol Burnett
rklessdriver Re: FUEL RETURN LINE
As a racer that has dealt with braided lines all my life, I want to let you know that if you let those lines sit on anything unsecured or rub on anything they will cut thru it like a saw eventually.
When I run braided lines over stuff (like your accy bracket and heater hose) I take clear flexible PCV tubing - cut it length wise (think hot dog bun) and wrap it around the braided lines so it won't chaff anything.
You can buy it at fish tank supply stores or Lowes sometimes.
You can use regular black rubber hose as well, but the clear PVC tubing looks better.
Posted on: 2012/4/23 22:28
Bakersfield Ca
2336 Posts
Marv02 (Marvin) went in to great detail on making sure nothing is in contact so nothing will cut through. Thanks for the advice.
Posted on: 2012/4/23 23:17
Carol Burnett
« 1 (2)
