283 user(s) are online (249 user(s) are browsing Forums)
marv02 Sound found
California City Ca
130 Posts
I was chasing a knocking sound in my Vett for a while now it’s been tracked down to the Fuel Pump Regulator.
It holds 43 PSI of pressure at Idle But as soon as you turn the engine off it drops to Zero.
It has almost NEW FIC Bosch III 24# injectors and same for the Fuel pump a Walberg 190.
When doing some more reading some are saying the Fuel pump regulator pulse dampener is bad.
That’s fine I ordered one where is it on the car.
Posted on: 2012/3/4 16:58
bogus Re: Sound found
well... this is interesting.
I am surprised the regulator had anything to do with pressure retention. That's usually dealt with by the check valve. and that's internal to the pump.
The pulse dampener is on the pump assembly.
And if you have an LT1, it's the round disk thing on the inlet line. Technically, with the LT1, there are 2. One on the pump, one on the inlet line.
Posted on: 2012/3/4 17:30
Matatk Re: Sound found
You need to do the troubleshooting tree to narrow down the reason for the pressure drop. Honestly, it won't necessarily hurt anything.
The dampener could be bad, I replaced mine with fuel hose with no ill effects.
Posted on: 2012/3/4 22:35
CorvetteBob Re: Sound found
1409 Posts
I don't mean to hijack the thread, but how important is the in-line fuelpump dampener on my L98? When I did my header install, I think I may have taken mine out, but I don't completely recall. The topic came up at the time, but I believe I may have followed the general thought that it wasn't needed.
Posted on: 2012/3/5 21:37
Bob - you would have to pull the fuel pump to remove the dampener. It is not essential. It is to reduce sound/vibration. It doesn't affect the running of the car.
Posted on: 2012/3/6 0:57
Are you talking about that 2nd one on the return line? I only just learned that was a dealer install bit for a recall. To fix line vibrations. Seemed like overkill to me.
Posted on: 2012/3/6 1:04
josephf31 Re: Sound found
New Jersey
375 Posts
Yep...in fact if it's bad it could cause not only a "hammering" sound (think of your water pipes if you have high pressure, the sound of the pipes banging when opening or closing a faucet) but pressure leak down can also cause a hard start condition as well.
Cheap enough to replace, really doesn't hurt to have it on, though it won't hurt to bypass with a piece of fuel hose.
Posted on: 2012/3/6 1:37
marv02 Re: Sound found
California City Ca
130 Posts
When I got home from work today my new pulse dampener was at the door
It took about 30 minutes to install it fired the car back up Idove it to work today it seems much better.
I find out more after the car sits and I can start it cold thats when it made the noise the worse.
But so far so good.
Posted on: 2012/3/10 1:36
California City Ca
130 Posts
The noise is back.
I am going to delete the 9th injector and see if this helps like I said before it only makes the noise when it is cold start up.
Posted on: 2012/3/17 17:36
California City Ca
130 Posts
I pulled the cap NO hitting at all the rotor seen better days I change that
I also pulled the distributor out and checked the end play it's at .017.
The Composite distributor gear is showing wear about half the teeth are worn though already with 7000 miles on it sounds funny to me also the lower 3/4 of the gear is worn more towarded the top of the gear.
I using the stock 1986 distributor with a composite gear is this my issues.
Posted on: 2012/3/17 19:42
Edited by marv02 on 2012/3/17 20:14:22
California City Ca
130 Posts
I just ordered a OEM GM melonized distributor gear.
When I built the motor others said the composite gear was the way to go now I reading GM saying for a LT4-Hotcam go with the melonized gear set.
I going to give this a try and see how this gear holds up compaired to the high dollar composite gear.
The OEM is half he price of the composite gear set.
With any luck this where the noise is comming from.
Posted on: 2012/3/17 20:50
EngineDoctor Re: Sound found
La Habra Ca.
791 Posts
I'm getting dizzy ?
jpg  Houston.jpg (98.04 KB)
7794_4f655903e53dc.jpg 750X600 px
Posted on: 2012/3/18 3:41
La Habra Ca.
791 Posts
Think about where all this contamination winds up ! idk.
Posted on: 2012/3/18 3:44
If your composite gear lasted 7000 miles the melonized will last 500. I have gone through two melonized GM cam gears with my aftermarket comp camp and switched to composite at their recommendation after the car broke down twice. I wouldn't go with melonized.
I've heard all different causes of distributor gear failure...cam walk, hvhp oil pump, cam gear teeth too sharp, etc. Not sure what the real answer is.
Posted on: 2012/3/18 22:50
La Habra Ca.
791 Posts
Matt, You basically nailed it, other causes could be a factor aswell. It's also noisy as hell when you've got this problem, sounds like "Idler gears" .In a condition like this the cam is definitly walking.IMHO
bmp  ant.bmp (900.05 KB)
7794_4f6679e8799e0.bmp 480X640 px
Posted on: 2012/3/19 0:12
California City Ca
130 Posts
Swapped the gear out fired the car up the noise still there.
I dont want to pull the motor again.
I just dont get it.
After the car is good and warm no noise.
I went to McDee's drive though on the way to work this morning you could hear the knocking noise very well as it echoed off the wall next to me.
Posted on: 2012/3/25 0:15
Sounds like it could be an exhaust tick then. Injectors can also be noisy as can roller rockers.
Posted on: 2012/3/25 2:20
California City Ca
130 Posts
It has a step nose cam shaft and I using OEM walk plate.
Posted on: 2012/3/25 4:01
California City Ca
130 Posts
Question I know the pushrods are a little bit on the long side when rolling the motor over and checking for patter wear on the valve stem tip it not completely center it on more the exhaust side more than center I using the stock length push rods 7.195
Do you think this could be the problem making the noise?
Posted on: 2012/3/26 2:59
How far off center are your pushrods? Did you use a length checker when installing them to get the right length?
I think that could be causing excessive valvetrain noise.
Posted on: 2012/3/26 11:31
