110 user(s) are online (75 user(s) are browsing Forums)
The Natio...
jaa1992 Help with You Tube
Stone Mtn, GA (near Atlanta)
187 Posts
I don't get it I tried to embed a you tube video in my AMP post in the Autocross and road racing section and It isn't working.
I looked at other posts with you tube videos and I thought I had it.
Any help?
Posted on: 2012/5/16 1:08
Matatk Re: Help with You Tube
22947 Posts
Did you use the embed feature from youtube?
Also, there is some software glitch with xoops that if you try to use the "quick reply" box at the bottom it won't post, you have to hit the "reply" button on the post itself.
Posted on: 2012/5/16 2:02
BillH Re: Help with You Tube
Also. it won't work if you changed your post tp "Tiny Mice" to get the better graphics.
Jim, did you use "copy imbeded html" on your youtube vid?
Posted on: 2012/5/16 3:41
Ultraman Re: Help with You Tube
15371 Posts
Bring up the vid you want then left click on share, that will bring the embed button up. left click on that and the embed code will come up. Right click on the embed code with your mouse and copy. Then go back to your Guru post and place the vid where you want it then click paste and the embed code should appear.
I then go to the bottom of the page and hit the preview post, the one at the bottom of the post does not work for me. It should show your post and if it is good go down to the bottom and hit submit......easy peasy....
Like Matt said it won't work with the quick reply box.
Posted on: 2012/5/16 13:07
jaa1992 Re: Help with You Tube
187 Posts
That may have been my problem, although I copied it in when I was in edit post mode
Someone else was able to embed it in a post.
I'll try again when I get the next one stripped down and posted on YouTube.
Thanks for all the suggestions
Posted on: 2012/5/18 1:42
