| EngineDoctor | 66 headlights | ||
Had my headlight motors rebuilt and installed, worked fine , now all of a sudden they wont go up or down ??
What could it be ????? switch under dash? |
Posted on: 2012/6/12 22:26
Transfer
| Matatk | Re: 66 headlights | ||
Are you gettng power at the motor? Did you check the fuse?
Posted on: 2012/6/12 23:20
Transfer
| EngineDoctor | Re: 66 headlights | ||
not yet, Where is the fuse ? thanks mat ;) |
Posted on: 2012/6/12 23:37
Transfer
I find references to the firewall - not sure if your year is inside the dash or in the engine compartment.
But I found there should be a 40a relay for the headlight doors. Might be that, not sure where it is exactly. ![]() |
Posted on: 2012/6/13 0:24
Transfer
| BillH | Re: 66 headlights | ||
The fuse box is under the dash above the dimmer sw.
However, there is no fuse for the headlight doors. I'll get you some more info after I wake up. |
Posted on: 2012/6/13 14:16
Transfer
First, do you have power to the motors?
Check the DrG or Y wires at the motors with the switch engaged (up or down). The switch just reverses polarity. Check the red wire on the switch for power. The power comes from the headlight sw. thru that 40a circuit breaker to the door sw. red wire. Also the firewall connector. Back trace from the motors to the switch. Some guys have taken the switch apart and cleaned the contacts. But first you have to know where you have power and where you don't. |
Posted on: 2012/6/13 15:02
Transfer
BTW, the C/B's probably under the dash.
Posted on: 2012/6/13 15:03
Transfer
Thank's guys... I'll check it out on the weekend , let u know wat I find.
Posted on: 2012/6/13 19:54
A&D ENGINES http://andengines.com |
Transfer
It waz just the switch under the dash, thank's guys 4 ur help !
Posted on: 2012/6/26 4:02
Transfer
Transfer
