632 user(s) are online (246 user(s) are browsing Forums)
EngineDoctor 66 headlights
La Habra Ca.
791 Posts
Had my headlight motors rebuilt and installed, worked fine , now all of a sudden they wont go up or down ??
What could it be ????? switch under dash?
Posted on: 2012/6/12 22:26
Matatk Re: 66 headlights
22996 Posts
Are you gettng power at the motor? Did you check the fuse?
Posted on: 2012/6/12 23:20
EngineDoctor Re: 66 headlights
La Habra Ca.
791 Posts
not yet, Where is the fuse ?
thanks mat ;)
Posted on: 2012/6/12 23:37
22996 Posts
I find references to the firewall - not sure if your year is inside the dash or in the engine compartment.
But I found there should be a 40a relay for the headlight doors. Might be that, not sure where it is exactly.
Posted on: 2012/6/13 0:24
BillH Re: 66 headlights
The fuse box is under the dash above the dimmer sw.
However, there is no fuse for the headlight doors.
I'll get you some more info after I wake up.
Posted on: 2012/6/13 14:16
First, do you have power to the motors?
Check the DrG or Y wires at the motors with the switch engaged (up or down).
The switch just reverses polarity.
Check the red wire on the switch for power.
The power comes from the headlight sw. thru that 40a circuit breaker to the door sw. red wire.
Also the firewall connector.
Back trace from the motors to the switch.
Some guys have taken the switch apart and cleaned the contacts.
But first you have to know where you have power and where you don't.
Posted on: 2012/6/13 15:02
BTW, the C/B's probably under the dash.
Posted on: 2012/6/13 15:03
La Habra Ca.
791 Posts
Thank's guys... I'll check it out on the weekend , let u know wat I find.
Posted on: 2012/6/13 19:54
La Habra Ca.
791 Posts
It waz just the switch under the dash, thank's guys 4 ur help !
Posted on: 2012/6/26 4:02
