188 user(s) are online (127 user(s) are browsing Forums)
Also known as SMC.
The only issu...
cmashark compression ratio question
virginia beach, va
74 Posts
i know that the compression ratio on the aluminum headed L98 is 9.5 to 1. What is it on the iron headed L98's?
chris
Posted on: 2008/2/15 3:16
1987 Coupe 2 tone white/silver, auto, Z52.
bone stock, except for Flowmaster catback and precats eliminated.
tobijohn RE:compression ratio question
Palm Beach Gardens, FL
515 Posts
Corvette Specs lists both the 84 and 85 at 9.0:1. The early 86s still had the iron heads...
Posted on: 2008/2/15 3:23
John
1996 LT4 coupe black/black
AIRFOIL FREE!
cmashark RE:compression ratio question
virginia beach, va
74 Posts
any idea of what the compression ratio would be if you took one of these 9.0 motors and put the 58 cc heads or 64 cc heads on it?
Posted on: 2008/2/15 3:41
Notorious RE:compression ratio question
If I had a buck for every time I've posted this link, I'd go buy a new ZO6. Calculators
Posted on: 2008/2/15 3:53
I hate sporks...
virginia beach, va
74 Posts
Thank you, i added it to my favorites. with the 64cc heads, it would jump to 10.2 to 1. and with the 58cc heads it goes to 11.01 to 1. i used a .024 gasket for this calculation, whats the thickes i could get? probably need a cam with alot of over lap to bleed off some of that pressure, huh?
chris
Posted on: 2008/2/15 4:50
