cmashark | compression ratio question | ||
i know that the compression ratio on the aluminum headed L98 is 9.5 to 1. What is it on the iron headed L98's?
chris |
Posted on: 2008/2/15 3:16
1987 Coupe 2 tone white/silver, auto, Z52. bone stock, except for Flowmaster catback and precats eliminated. |
tobijohn | RE:compression ratio question | ||
Corvette Specs lists both the 84 and 85 at 9.0:1. The early 86s still had the iron heads...
Posted on: 2008/2/15 3:23
John 1996 LT4 coupe black/black 160 Tstat, K&N, Hypertech PPIII (for the fans), CAGS, Nitto 555 EPs, 275/315s, Chrome A-molds, a little tint and some black-outs AIRFOIL FREE! |
cmashark | RE:compression ratio question | ||
any idea of what the compression ratio would be if you took one of these 9.0 motors and put the 58 cc heads or 64 cc heads on it?
Posted on: 2008/2/15 3:41
Notorious | RE:compression ratio question | ||
If I had a buck for every time I've posted this link, I'd go buy a new ZO6. Calculators
Posted on: 2008/2/15 3:53
I hate sporks... |
Thank you, i added it to my favorites. with the 64cc heads, it would jump to 10.2 to 1. and with the 58cc heads it goes to 11.01 to 1. i used a .024 gasket for this calculation, whats the thickes i could get? probably need a cam with alot of over lap to bleed off some of that pressure, huh?
chris |
Posted on: 2008/2/15 4:50
