152 user(s) are online (96 user(s) are browsing Forums)
The ...
istter1 roller rockers vs roller tip rockers
Bakersfield Ca
2336 Posts
http://www.summitracing.com/parts/SUM-141506/
Do these both require a roller cam? and as such a taller valve cover?
Posted on: 2012/9/15 5:35
Carol Burnett
Calm Re: roller rockers vs roller tip rockers
Vancouver, Canada
608 Posts
Steve, the roller rockers will work with non-roller cams, no problem. Perhaps you should consider the 1.6 ratio rockers though, as they provide extra 'lift' and ~very~ slight increase in duration. Both will fit your valve cover...although the 1.6 ratio ~may~ require you to remove the oil deflector tabs inside the valve cover ~depending if you have them~.
Stock VC's allow the height required for 1.5 & 1.6 rockers...perhaps even 1.7 ratios would work....but I don't know. David (Eng Doc) would know for sure.
Posted on: 2012/9/15 6:27
istter1 Re: roller rockers vs roller tip rockers
Bakersfield Ca
2336 Posts
Thanks I will be asking him questions when pick up my motor from him today.
Posted on: 2012/9/15 14:19
Carol Burnett
benny42 Re: roller rockers vs roller tip rockers
Houston, Tx
91 Posts
I have a set like those on my '86 - non roller cam. I
trimmed the oil drippers in the valve covers just in
case they might touch. I am a bit quicker in the 1/8th
mile, but it may be my launch skills are improving.
Worth it, get them.
Posted on: 2012/9/16 2:40
bogus Re: roller rockers vs roller tip rockers
20860 Posts
1.7 is a bit much for a small block... 1.6 is perfect.
Posted on: 2012/9/16 5:55
Matatk Re: roller rockers vs roller tip rockers
22811 Posts
I have comp camps 1.52 roller tip rockers with edelbrock valve covers and there are no clearance issues.
Posted on: 2012/9/16 11:40
Bakersfield Ca
2336 Posts
Dave and I were talking about that yesterday. I am going with the 1.6
Posted on: 2012/9/16 14:30
Carol Burnett
