istter1 | roller rockers vs roller tip rockers | ||
http://www.summitracing.com/parts/SUM-141506/
Do these both require a roller cam? and as such a taller valve cover? |
Posted on: 2012/9/15 5:35
Calm | Re: roller rockers vs roller tip rockers | ||
Steve, the roller rockers will work with non-roller cams, no problem. Perhaps you should consider the 1.6 ratio rockers though, as they provide extra 'lift' and ~very~ slight increase in duration. Both will fit your valve cover...although the 1.6 ratio ~may~ require you to remove the oil deflector tabs inside the valve cover ~depending if you have them~.
Stock VC's allow the height required for 1.5 & 1.6 rockers...perhaps even 1.7 ratios would work....but I don't know. David (Eng Doc) would know for sure. |
Posted on: 2012/9/15 6:27
1995 Forged 385 ZF6 227/234 1.6 FIC30# MSD BBK SS SLP Bullets X-Pipe DynoMax |
istter1 | Re: roller rockers vs roller tip rockers | ||
Thanks I will be asking him questions when pick up my motor from him today. |
Posted on: 2012/9/15 14:19
benny42 | Re: roller rockers vs roller tip rockers | ||
I have a set like those on my '86 - non roller cam. I
trimmed the oil drippers in the valve covers just in case they might touch. I am a bit quicker in the 1/8th mile, but it may be my launch skills are improving. Worth it, get them. |
Posted on: 2012/9/16 2:40
bogus | Re: roller rockers vs roller tip rockers | ||
1.7 is a bit much for a small block... 1.6 is perfect.
Posted on: 2012/9/16 5:55
Matatk | Re: roller rockers vs roller tip rockers | ||
I have comp camps 1.52 roller tip rockers with edelbrock valve covers and there are no clearance issues.
Posted on: 2012/9/16 11:40
Dave and I were talking about that yesterday. I am going with the 1.6
Posted on: 2012/9/16 14:30
