163 user(s) are online (102 user(s) are browsing Forums)
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
matts85vet broken valve spring -- need advice
Toledo, Ohio
58 Posts
the ex valve spring on #4 broke. the valve didn't drop down completely, only about 1/4 inch. retainer and keepers still on the valve.
leak down test shows same results as other pistons-all around 5%. i pulled the head today. no damage as far as i can tell without some more cleaning. the valve did touch the cylinder and wore away some of the buildup of grime, and you can see where there was contact.
i still need to remove the broken spring and valve and clean it up. the pistons are forged? its an 85.
it was a comp beehive
i ordered a new nitrided series set #1519 from pac, yet to arrive
what should i do?
ill try to get pics tomorrow
thanks in advance
Posted on: 2012/9/23 3:45
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
bogus Re: broken valve spring -- need advice
It seems you already have the answer... I would replace springs and move on.
I assume the miles on the engine are rather low, right?
Posted on: 2012/9/23 3:50
Matatk Re: broken valve spring -- need advice
My question is why did it break? What RPM are you running at and are the springs you selected suited for your cam?
Posted on: 2012/9/23 11:49
rklessdriver Re: broken valve spring -- need advice
Since you can see where the valve contacted the piston, I would recommend you take that valve to a machine shop and have it trued up.
It takes alot more than a valve bump to damage a piston. Nothing to worry about there.
Posted on: 2012/9/23 22:20
EngineDoctor Re: broken valve spring -- need advice
La Habra Ca.
791 Posts
Yes , have a machine shop set u you up !
Posted on: 2012/9/24 1:05
