275 user(s) are online (240 user(s) are browsing Forums)
jacobsimmons injectors
lititz pa.
40 Posts
i was thinking of putting some injector cleaner that is added to the gas, is this ok for my '93 c4 LT1, and if so ,witch brand is best?
thanx for any help,
Posted on: 2012/10/27 21:40
j. simmons
josephf31 Re: injectors
New Jersey
375 Posts
thanx for any help,
From a lot of what I have heard and read, you don't need to use any cleaner, and it could end up doing more harm than good. If anything Seafoam will clean up any gunk in the system.
Posted on: 2012/10/27 21:58
Matatk Re: injectors
I use Chevron Techron every once in a while. About $7 a bottle.
Posted on: 2012/10/27 21:59
jacobsimmons Re: injectors
lititz pa.
40 Posts
thanks for the help, but what is "sea foam "??
Posted on: 2012/10/27 22:17
j. simmons
New Jersey
375 Posts
Posted on: 2012/10/27 22:34
lititz pa.
40 Posts
ok ,thnx.
Posted on: 2012/10/27 22:38
j. simmons
whalepirot Re: injectors
SoCal
19 Posts
i was thinking of putting some injector cleaner that is added to the gas, and if so, which brand is best?
Why? Lucas is also superb, but Pontiac did a study and found that quality, detergent gasoline will clean dirty injectors within 2-3 tankfuls.
Posted on: 2013/1/20 0:21
409 cid four bolt, forged crank/11:1 comp/alum. Dart Pro-1/FMS-30pph@45 psi/BBK 52mm/'90 ECM Custom chip/Lingenfelter SuperRam/Comp Cams hydr. roller 230i-236e@050 /TPIS long tubes 3"/'84 Corvette cat/Flowmaster/ BeCool rad./FlowTech water pump/180* 'sta
1Fast04Vert Re: injectors
I try to use nothing but Chevron as long as the pump price is competitive. It has Techron in it, so never a need for any additives.
Posted on: 2013/1/20 2:49
bogus Re: injectors
There is this thing called "tier 1" gas now... Shell, Chevron, Exxon (I think) are all involved. It's a standard for clean fuels, and I can say, looking at the valves on my 185k LT1, they mean it. They were clean... same with the piston tops (a little black, but not much).
The risk of additives is that they can damage the injectors.
The only fuel system additive I have used are either Seafoam or BG products 44k.
Posted on: 2013/1/20 3:09
