jacobsimmons | injectors | ||
i was thinking of putting some injector cleaner that is added to the gas, is this ok for my '93 c4 LT1, and if so ,witch brand is best?
thanx for any help, |
Posted on: 2012/10/27 21:40
j. simmons |
josephf31 | Re: injectors | ||
From a lot of what I have heard and read, you don't need to use any cleaner, and it could end up doing more harm than good. If anything Seafoam will clean up any gunk in the system. |
Posted on: 2012/10/27 21:58
2002 Magnetic Red C5 6 spd LS1 convertible |
Matatk | Re: injectors | ||
I use Chevron Techron every once in a while. About $7 a bottle.
Posted on: 2012/10/27 21:59
jacobsimmons | Re: injectors | ||
thanks for the help, but what is "sea foam "??
Posted on: 2012/10/27 22:17
j. simmons |
Posted on: 2012/10/27 22:34
ok ,thnx.
Posted on: 2012/10/27 22:38
j. simmons |
whalepirot | Re: injectors | ||
i was thinking of putting some injector cleaner that is added to the gas, and if so, which brand is best? |
Posted on: 2013/1/20 0:21
409 cid four bolt, forged crank/11:1 comp/alum. Dart Pro-1/FMS-30pph@45 psi/BBK 52mm/'90 ECM Custom chip/Lingenfelter SuperRam/Comp Cams hydr. roller 230i-236e@050 /TPIS long tubes 3"/'84 Corvette cat/Flowmaster/ BeCool rad./FlowTech water pump/180* 'sta |
1Fast04Vert | Re: injectors | ||
I try to use nothing but Chevron as long as the pump price is competitive. It has Techron in it, so never a need for any additives.
Posted on: 2013/1/20 2:49
bogus | Re: injectors | ||
There is this thing called "tier 1" gas now... Shell, Chevron, Exxon (I think) are all involved. It's a standard for clean fuels, and I can say, looking at the valves on my 185k LT1, they mean it. They were clean... same with the piston tops (a little black, but not much).
The risk of additives is that they can damage the injectors. The only fuel system additive I have used are either Seafoam or BG products 44k. |
Posted on: 2013/1/20 3:09
