109 user(s) are online (70 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
bren68 rattling noise when I accelerate
new jersey
54 Posts
recently replace the manifold gasket winch I think I am going to have to do again because the gasket is leaking,I also have a rattling noise when i accelerate can this be caused by a manifold leak or is it something more serious.when I am cruising its fine but when i hit down to pick up speed it rattles sounds like you are shaking a can with bolts in it.
Posted on: 2012/11/13 14:58
bogus Re: rattling noise when I accelerate
could be loose exhaust... a tool left in the vally...
Posted on: 2012/11/13 16:43
Matatk Re: rattling noise when I accelerate
I like the idea of checking the exhaust. Make sure it's all tight, no rattling heat shields, etc.
Did you remove / move anything else during the recent work?
Posted on: 2012/11/14 2:09
Calm Re: rattling noise when I accelerate
Vancouver, Canada
608 Posts
Perhaps one of your cats has failed?
Posted on: 2012/11/14 2:40
bren68 Re: rattling noise when I accelerate
new jersey
54 Posts
no, oil leak it seems that my intake pipes were loose and there was oil in my plenum and i think the oil was coming out of there,but know that's another issue not sure if the rattling had anything to do with this. going to change egr valve as well plenum is off.
Posted on: 2012/11/14 3:28
MK 82 Re: rattling noise when I accelerate
Palm Beach Gardens, FL
439 Posts
Are you sure it's not detonation?
Posted on: 2012/11/14 14:44
96 CE Roadster LT4
Ultraman Re: rattling noise when I accelerate
14768 Posts
That's what I was thinking.......
Posted on: 2012/11/15 0:24
new jersey
54 Posts
did plenum and runners to manifold over ,rattling seemed to have stopped I am hoping it was from a vacuum leak car seems to be running ok thanks for all your help
Posted on: 2012/11/23 21:56
I suspect it was a vacuum leak causing severe detonation... the key to understanding auto repair and troubleshooting is understanding cause and effect... they go hand in hand.
Posted on: 2012/11/23 22:51
