241 user(s) are online (192 user(s) are browsing Forums)
jacobsimmons wheels
lititz pa.
40 Posts
on my '93 c4 LT-1 coup 40th, can i put 17x9.5 all the way around?
Posted on: 2012/11/27 21:59
j. simmons
CentralCoaster Re: wheels
Yep! But make sure they have a +56mm offset, or something close to it.
A 275/40 is a good tire size for that wheel. Or you can safely fit a 285 on it, but it's a less common size.
Posted on: 2012/11/27 22:30
BillH Re: wheels
17 x 9.5 is the stock setup on a 92.
They narrowed the fronts in 93 to cut down on the walking side to side over ruts.
Posted on: 2012/11/27 22:35
Eh, street manners are for metrosexuals. Put the fatties on there, and while you're at it, set the front toe to zero. I believe the 88-96 have less scrub radius so I'm not sure if that would make it behave better or worse than my 85.
It sure is nice having the ability to rotate tires. Different front/rears with direction tread prevents that.
I used to have some nice asymmetric tires, and on the non-directional wheels, you could rotate them anywhere.
Posted on: 2012/11/27 23:21
BillH Re: wheels
Yea, I shoulda added: "so they will fit"
Posted on: 2012/11/27 23:35
Ok, looks like extra scrub radius is bad for road manners. http://www.off-roadweb.com/tech/1106o ... _scrub_kopycinskis_brain/
But on your 93 you have nothing to worry about.
[OT] I wonder if my extra bit of scrub radius is making it harder on the power steering pump, which is already straining at these RPMs. [/OT]
Posted on: 2012/11/28 1:30
BillH Re: wheels
I don't have any problems on the track no noticeable straining, May be a different pump though.
Posted on: 2012/11/28 3:00
bogus Re: wheels
it is... the older C4s use a different PS pump, more like the old school GM pumps... IIRC.
Posted on: 2012/11/28 4:01
jacobsimmons Re: wheels
lititz pa.
40 Posts
thanx for the info, i'm putting in 7 days a week till xmas and thats going to get the wheels i'm looking at, a chrome set of 5 spoke , can't wait!!.
Posted on: 2012/11/28 22:14
j. simmons
SpectatorRacing Re: wheels
BillH wrote:
I don't have any problems on the toilet no noticeable straining, May be a different pump though.
Fixed it for ya
Posted on: 2012/11/29 18:36
BillH Re: wheels
SpectatorRacing wrote:
Fixed it for ya
Oh, I wanta meet you.................on the racetrack.
Posted on: 2012/11/29 21:08
