294 user(s) are online (252 user(s) are browsing Forums)
1989Convertible seat covers
Buna Texas
69 Posts
How does the seat come out on the 1989 cars. I will just buy the seats already on mounted on foam. anyone have something that shows how they come out and go in? thanks
Posted on: 2012/12/4 17:36
CentralCoaster Re: seat covers
Seats come out easy, 4 nuts underneath, a plug for the power seats, and the nuts are concealed below plastic trim that is held in with push nuts. You'll need seat power to move it back and forth to get all the nuts out first.
The cushions themselves are in 2 parts only. The seatback cushion clips in from both sides, 2 clips per side. If you tug them away from the seat back plastic gently you may be able to see where the clips are. Removing it requires squishing the sides of the cushion really hard towards the middle to undo the clip. Anything else will probably break it. Do one side at a time. They can be sticky with rust and hard to remove. Even harder to put back on too, but at least then you'll know where the clips are.
The bottom is easy, it slips in and clips in the front. When you have the whole seat out you'll see the front clip that has to be popped loose.
Hopefully someone will chime in with photos.
Posted on: 2012/12/4 17:42
pianoguy Re: seat covers
Here's a pretty good article with lots of pics:
http://www.corvettefever.com/techarti ... seat_covers/photo_01.html
Posted on: 2012/12/4 19:52
1989Convertible Re: seat covers
Buna Texas
69 Posts
Thanks, just what I was looking for!
Posted on: 2012/12/5 0:43
BillH Re: seat covers
Posted on: 2012/12/5 0:45
