djxib | Coolant temperature senders - mystery solved (or at least resolved) | ||
When I put the refreshed motor in my car over a year ago, I broke the coolant temperature sender (the one that goes into the passenger side head). Because I have LT4 heads and intake I ordered a 1996 sender. (My car is a 1992).
Since that moment my analog gauge has read 30-40 degrees hotter than the digital readout on the dash. I tried reburping the coolant system a few times but it was consistently higher. So today I decided to take advantage of the MLK holiday and I changed oil and did a coolant flush - I also bought 2 new sensors (water pump and passenger head), Voila - the analog gauge now tracks with the digital gauge (or at least the best I can tell given the gauge markings). It also behaves exactly like it used to before the refresh. So I wont freak out every time the digital gauge shows 200 (because the analog would previously show 240 ish). The problem was either: 1. Inadequate reburping 2. A bad sender from the factory or.. 3. the 1992 sender is calibrated differently from the 1996.. Thought I would share. |
Posted on: 2013/1/21 23:08
Andy 1996 Greenwood Collectors Edition LT4 Previously 1992 Convertible Polo Green. 383 LT1/LT4 forged/balanced. V7-YSi, Alky. 608RWHP... Now sitting at a dismantler with a salvage title. Still runs... |
BrianCunningham | Re: Coolant temperature senders - mystery solved (or at least resolved) | ||
Did you reroute the cooling lines at all?
Like the lines that go to the back of the heads? |
Posted on: 2013/1/21 23:13
CentralCoaster | Re: Coolant temperature senders - mystery solved (or at least resolved) | ||
I would guess if the 92 and 96 have different p/n's then yes, the 92 sensor would have been the correct one to use all along.
Posted on: 2013/1/22 0:13
djxib | Re: Coolant temperature senders - mystery solved (or at least resolved) | ||
Brian- I 'upgraded' the cooling system to a 96 configuration- which was primarily a water pump and different cooling hoses. The basic flow through the radiator and into the heads / block then out again is unchanged. The pipe at the rear of the heads is unchanged too. I'm convinced it was a bad sensor or wrong P/N- I've drained and reburped coolant on this car 10 times in 8 years!
Posted on: 2013/1/22 0:56
1Fast04Vert | Re: Coolant temperature senders - mystery solved (or at least resolved) | ||
Knock sensors ae also different - stay with the LT1 version.
Basically match the sensors to the computer, not to the LT4. Bet there is no crank positions sensor on the engine. |
Posted on: 2013/1/22 2:57
