223 user(s) are online (180 user(s) are browsing Forums)
GRIS, more...
tobijohn Need ZF clutch slave cylinder recommendation
Palm Beach Gardens, FL
515 Posts
I last replaced mine in in December 2010 and thought I was past that epidemic of universally bad after-market choices. Apparently not, as this one is leaking after around 2000 miles and has to be topped off every couple of weeks. Has anyone replaced theirs and gotten at least oh, say, five thousand miles out of the new one? If so, what brand did you go with? TIA..
Posted on: 2013/2/5 3:03
John
1996 LT4 coupe black/black
AIRFOIL FREE!
donhall Re: Need ZF clutch slave cylinder recommendation
297 Posts
Wish I could help you, JT, but I drive an automatic.
You will get your answer here, just takes a few minutes.
(It has been awhile, but I was delighted to see your post. I would
guess #1 kitty is no longer with us. Hope all is well.)
don hall santa cruz, ca
Posted on: 2013/2/5 3:16
Edited by donhall on 2013/2/5 3:43:10
bogus Re: Need ZF clutch slave cylinder recommendation
NAPA. I got one from NAPA 3+ years ago and it's been excellent.
The slave is cast instead of that questionable welded thing.
No leaks, nothing.
Expect to pay about $100. It was made in Taiwan. Part number NCF 73116.
Posted on: 2013/2/5 3:27
tobijohn Re: Need ZF clutch slave cylinder recommendation
515 Posts
Hey Don, it's been a while for sure. Yes, as the New Agers say, Cat #1 made his transition about three years ago, a week shy of 22 yo. Other big change was I got divorced. If you're afraid that I'm now catless, fear not. While the ex took just about all the furniture when she moved out, she left most of the cats. So I'm still happily scooping away...
jpg  tobin_family_update.jpg (94.91 KB)
112_5111a1dce5350.jpg 720X528 px
Posted on: 2013/2/6 0:15
John
AIRFOIL FREE!
515 Posts
No leaks, nothing.
Thanks Andy, I'll check to see if I can order online from NAPA as there doesn't seem to be any actual stores near me...
Posted on: 2013/2/6 0:19
John
AIRFOIL FREE!
sorry to hear about the divorce... no matter the cause, that is a sucky situation!!
Posted on: 2013/2/6 1:59
515 Posts
Thanks but actually it was a relief for both of us. Nobody had been having any fun for a long time. No kids so that made it a lot easier...
Posted on: 2013/2/6 2:02
John
AIRFOIL FREE!
yea, if that's the case... but still disappointing.
Posted on: 2013/2/6 6:03
-=Jeff=- Re: Need ZF clutch slave cylinder recommendation
Bartlett, IL
573 Posts
I got my Master and Slave from :
http://www.powertorquesystems.com/
Jim is a great guy and a corvette owner. these are OEM pieces
Posted on: 2013/2/12 17:25
-=Jeff=-
1990 Corvette ZR-1 #1051
The OEM is the problem!! GM had a run of them where the seals were installed backwards, and, because they sat on the shelf for so long, started to rust internally.
This is a case where aftermarket fixed the bug... so to speak.
Posted on: 2013/2/12 22:21
Bartlett, IL
573 Posts
Not with Jim's
he bought all the OEM pieces, he puts them together correctly.
Jim also refinishes the Master Cylinders.. the Aftermarket Cast ones don't last long, I bought new pieces from Jim and they work great.
Way back in 2005 when the OEM backwards seal was backwards I was one that helped Bill B confirm it.. I had 3 that way..
Posted on: 2013/2/13 13:37
-=Jeff=-
CentralCoaster Re: Need ZF clutch slave cylinder recommendation
I've seen some where electrolysis seems to happen between the bore and the piston. This will pit the bore and allow the fluid to leak past after 3/4 travel or so. I can't recall which ones this happened to, but I'd want to make sure the piston and casting or DOM piece are made of the same metal.
Posted on: 2013/2/13 16:13
Not with Jim's
Interesting... I have about 13k miles on my NAPA cast unit, and it is great. A little flash rust outside, but the coating is holding up well. No leaks, no loss of pressure. I should change fluid, tho... To be honest, I haven't added fluid in the three + years it's been installed.
Posted on: 2013/2/13 17:19
