241 user(s) are online (181 user(s) are browsing Forums)
gman35 images of installed c4 corvette X brace
orange park fla
3 Posts
Does anyone have or know of any images of a x frame brace that are installe on c4 corvette convertibles.
Posted on: 2013/4/13 2:08
Retired IBEW,ILA
Current CWA1101 card holder.
Comp/tia,A+,NETWORK+,Security+microsoft: MCDST,MCSA+,MCSE+,
CEH
pianoguy Re: images of installed c4 corvette X brace
I don't have a pic of the convertible brace, but have this pic of the R-D Racing Cross-Frame that I installed on my coupe. It uses the same factory front mounting holes/nuts as the convertible brace would use, but for the Cross-Frame I had to drill holes and use nut inserts for the rear mounts. Unfortunately the pic doesn't show any detail of the mounts:
Posted on: 2013/4/13 3:08
Aboatguy Re: images of installed c4 corvette X brace
My Avatar was redistributed!
498 Posts
What are you specifically looking for?
Posted on: 2013/4/17 19:42
corvetteronw Re: images of installed c4 corvette X brace
Lowell, MI
I saw the same request on another forum. He is installing a convertible X brace on his C4 coupe and wants to see where the rears are attached and how they look.
Posted on: 2013/4/18 14:41
gman35 Re: images of installed c4 corvette X brace
orange park fla
3 Posts
i have searched everywhere i can think of.. just trying to get some pictures of x frame braces.. preferably from under the car.. my car is a C4. thanks, gary
Posted on: 2013/6/18 21:02
Retired IBEW,ILA
CEH
Lonewolf Re: images of installed c4 corvette X brace
San Francisco
15 Posts
I haven't been on this site for sometime but your posted question was just a few short months back, have you gotten the answer's you were looking for?
If not, have you tried Corvette Central and looked up part #184146? If not do so, or if you have one of their free catalogs at home it is on page 162. It is the 84-96 Cross-Frame for attaching to the frame of the C4 Corvette with pictures & installation instructions, with included photos and related hardware as needed. If not here is a link to the page itself:
http://www.parts123.com/parts123/yb.dll?parta~partsort~A2~cadefibF
On this page it says; For more information, please check out our Tech Blog, click on the words "Tech Blog" & it will take you to the instruction page as I have outlined above. This is the direct link:
http://tech.corvettecentral.com/2012/ ... te-chassis-reinforcement/
This looks like a nice afternoon weekend project so with tools in hand go for it. While you are at it maybe you would want to think about making this an all day project & include the front L98 Camber Brace to shore up the front end as well? Matching that Cross-Frame with a Camber Brace, you should have not only reduced body flex but suspension control as well, one would think. Here is the link for the Corvette Central Camber Brace, part #184106;
Good luck with your project if you haven't done so already. I'm looking as to why my C4 is "choking" when I give it gas under normal driving conditions.
jpg  Picture 5.jpg (0.00 KB)
Posted on: 2013/6/20 15:14
93ragtop Re: images of installed c4 corvette X brace
Manassas Va
61 Posts
Gary, I have a 93 vert. It is hard to take pictures since I don't have a lift to put it up on. But if you could tell me what you are specifically looking for, ie mounts etc. I can take pictures and send them to you.
Posted on: 2013/6/21 11:06
