gman35 | images of installed c4 corvette X brace | ||
Does anyone have or know of any images of a x frame brace that are installe on c4 corvette convertibles.
Posted on: 2013/4/13 2:08
Retired IBEW,ILA Current CWA1101 card holder. Comp/tia,A+,NETWORK+,Security+microsoft: MCDST,MCSA+,MCSE+, CEH |
pianoguy | Re: images of installed c4 corvette X brace | ||
I don't have a pic of the convertible brace, but have this pic of the R-D Racing Cross-Frame that I installed on my coupe. It uses the same factory front mounting holes/nuts as the convertible brace would use, but for the Cross-Frame I had to drill holes and use nut inserts for the rear mounts. Unfortunately the pic doesn't show any detail of the mounts:
Posted on: 2013/4/13 3:08
Aboatguy | Re: images of installed c4 corvette X brace | ||
What are you specifically looking for? Mike |
Posted on: 2013/4/17 19:42
corvetteronw | Re: images of installed c4 corvette X brace | ||
I saw the same request on another forum. He is installing a convertible X brace on his C4 coupe and wants to see where the rears are attached and how they look.
Posted on: 2013/4/18 14:41
A VETERAN IS SOMEONE WHO AT ONE POINT WROTE A BLANK CHECK MADE PAYABLE TO THE UNITED STATES OF AMERICA FOR AN AMOUNT OF UP TO AND INCLUDING THEIR LIFE. |
gman35 | Re: images of installed c4 corvette X brace | ||
i have searched everywhere i can think of.. just trying to get some pictures of x frame braces.. preferably from under the car.. my car is a C4. thanks, gary
Posted on: 2013/6/18 21:02
Lonewolf | Re: images of installed c4 corvette X brace | ||
I haven't been on this site for sometime but your posted question was just a few short months back, have you gotten the answer's you were looking for?
If not, have you tried Corvette Central and looked up part #184146? If not do so, or if you have one of their free catalogs at home it is on page 162. It is the 84-96 Cross-Frame for attaching to the frame of the C4 Corvette with pictures & installation instructions, with included photos and related hardware as needed. If not here is a link to the page itself: http://www.parts123.com/parts123/yb.dll?parta~partsort~A2~cadefibF On this page it says; For more information, please check out our Tech Blog, click on the words "Tech Blog" & it will take you to the instruction page as I have outlined above. This is the direct link: http://tech.corvettecentral.com/2012/ ... te-chassis-reinforcement/ This looks like a nice afternoon weekend project so with tools in hand go for it. While you are at it maybe you would want to think about making this an all day project & include the front L98 Camber Brace to shore up the front end as well? Matching that Cross-Frame with a Camber Brace, you should have not only reduced body flex but suspension control as well, one would think. Here is the link for the Corvette Central Camber Brace, part #184106; http://www.parts123.com/parts123/yb.dll?parta~partsort~A2~cadefib Good luck with your project if you haven't done so already. I'm looking as to why my C4 is "choking" when I give it gas under normal driving conditions. Attach file: Picture 5.jpg (0.00 KB) |
Posted on: 2013/6/20 15:14
93ragtop | Re: images of installed c4 corvette X brace | ||
Gary, I have a 93 vert. It is hard to take pictures since I don't have a lift to put it up on. But if you could tell me what you are specifically looking for, ie mounts etc. I can take pictures and send them to you.
Posted on: 2013/6/21 11:06
93 White Vert. 3.73 gears, Yank 3000 converter,385ci. Built by Rklessdriver!! Ross pistons, Scat Rods, and Crank, custom Mike Jones Cam, AFR 210 heads, Exotic Muscle LT headers, magnaflow mufflers Meziere water pump. My best run 11.19 ET at 124.63mph |
