213 user(s) are online (107 user(s) are browsing Forums)
ttpfi Eletric fans
Fort Worth, Texas
25 Posts
I need a little help with electric fans. 1996 LT-4.
I remember back a while ago about someone going the junk yard and getting ford electric fans as a replacement for a C-4. One of my fans is starting to make noise so I was looking to upgrade the electric fans. If that is not feasible, recommendations on replacing the fan motors.
Posted on: 2013/5/4 12:21
bogus Re: Eletric fans
by 1996, the C4 had REALLY good fans... both are electric.
If they are making noise, it's because the fan motor itself has quit. All you need to do is replace the bad motor(s).
Rockauto.com has ACDelco, Part # 158404, for $62.89 each.
If you go to a salvage yard, here is the crossref:
CADILLAC DEVILLE (1994 - 1995)
CADILLAC ELDORADO (1989 - 1993)
CADILLAC SEVILLE (1989 - 1993)
CHEVROLET CAMARO (1996 - 2002)
CHEVROLET CORVETTE (1990 - 2004)
OLDSMOBILE TORONADO (1990 - 1992)
PONTIAC FIREBIRD (1996 - 2002)
The Ford retrofit is when you are dealing with an early C4 with 1 fan.
Posted on: 2013/5/4 19:45
Ultraman Re: Eletric fans
14785 Posts
Andy.....I am always amazed at the depth that you and the others here have of overall C4 knowledge......
Posted on: 2013/5/4 20:23
oh, don't be... I cut/paste that table from Rockauto.
Yea, the rest I knew... but the crossreference is just good interweb research.
Posted on: 2013/5/4 21:57
Matatk Re: Eletric fans
22810 Posts
It is not a direct swap and would involve modification. I would go with oem as an easy replacement. If you are looking for better flow, consider a SPAL which is high quality, but will also require some modification to mount it.
Posted on: 2013/5/5 2:24
ttpfi Re: Eletric fans
Fort Worth, Texas
25 Posts
Thanks,I'm going with rockauto.
Posted on: 2013/5/5 11:46
