336 user(s) are online (274 user(s) are browsing Forums)
1963 through 1967 Corvette.
captmike13 Trouble codes.
Hillsboro Mo
2165 Posts
I think this should be made into a sticky or put in one of the stickies.
Engine Trouble Codes:
1984:
code 13 =1 flash followed by 3 flashes =>oxygen sensor
code 14 =1 flash followed by 4 flashes =>coolant sensor
code 15 =1 flash followed by 5 flashes =>coolant sensor
code 21 = 2 flashes followed by 1 flash =>throttle position sensor
code 22 = 2 flashes followed by 2 flashes=> throttle position sensor
code 23 = 2 flashes followed by 3 flashes=> manifold air temp sensor
code 24 = 2 flashes followed by 4 flashes=> vehicle speed sensor
code 25 = 2 flashes followed by 5 flashes=> manifold air temp sensor
code 32 =>egr system
code 33 =>map sensor
code 34 =>maf sensor
code 35 => idle air control
code 41 => cylinder select error
code 42 => electronic spark control
code 43 => electronic spark control
code 44 => lean exhaust
code 45 => rich exhaust
code 51 => PROM
code 52 => fuel calpak
code 53 => system over voltage
code 54 => fuel pump circuit
code 55 => ecm
code 62 => oil temp
1985-1991
Code #12: Normal No Codes.
Code #13: Open Oxygen Sensor Circuit.
Code #14: Coolant Sensor Circuit Low.
Code #15: Coolant Sensor Circuit High.
Code #21: Throttle Position Sensor High.
Code #22: Throttle Position Sensor Low.
Code #23: Manifold Air Temperature Circuit High.
Code #24: Vehicle Speed Sensor.
Code #25: Manifold Air Temperature Circuit Low.
Code #32: EGR System Failure.
Code #33: Mass Air Flow Sensor High. 85 Manual says Mass Air FLow Sensor Low.
Code #34: Mass Air Flow Sensor Low. 85 Manual says Mass Air Flow Sensor High.
Code #36: Mas Air Flow Sensor Burn-Off Function Fault.
Code #41: Cylinder Select Error.
Code #42: Electronic Spark Timing.
Code #43: Electronic Spark Control.
Code #44: Lean Exhaust indication.
Code #45: Rich Exhaust Indication.
Code #46: Vehicle Anti Theft Fault.
Code #51: Faulty Mem-Cal. 85 Manual says PROM.
Code #52: Fuel Calpak Missing.
Code #52(1990-91 Corvette Only): Engine Oil Temperature Sensor Low.
Code #53: System Over Voltage.
Code #54: Fuel Pump Circuit Low Voltage.
Code #55: Defective ECM.
Code #62: Engine Oil Temperature Sensor Circuit High
1992-1993
Code #13: Left Oxygen Sensor Circuit.
Code #14: Coolant Temperature Sensor Circuit High.
Code #15: Coolant Temperature Sensor Circuit Low.
Code #16: Opti-Spark Ignition Timing System.( Low Pulse)
Code #21: Throttle Position Sensor Circuit High.
Code #22: Throttle Position Sensor Circuit Low.
Code #23: Intake Air Temperature Sensor Circuit Low.
Code #24: Vehicle Speed Sensor Circuit.
Code #25: Intake Temperature Sensor Circuit High.
Code #26: Quad-Driver Module #1 Circuit.
Code #27: Quad-Driver Module #2 Circuit.
Code #28: Quad-Driver Module #3 Circuit.
Code #32: Exhaust Gas Recirclation Circuit.
Code #33: Manifold Absolute Pressure Sensor Circuit Low.
Code #34: Manifold Absolute Pressure Sensor Circuit High.
Code #36: Opti-Spark Ignition Timing System. (High Resolution Pulse.)
Code #41: Electronic Spark Timing Circuit Open.
Code #42: Electronic Spark Timing Circuit Grounded.
Code# 43: Electronic Spark Control Circuit.
Code #44: Left Oxygen Sensor Circuit Lean.
Code #45: Left Oxygen Sensor Circuit Rich.
Code #51: Mem-Cal Error.
Code #52: Engine Oil Temperature Sensor Circuit Low.
Code #53: System Voltage.
Code #55: Fuel Lean Monitor.
Code #56: Vacuum Sensor Circuit.
Code #61: Secondary Port Throttle Valve System.
Code #62: Engine Oil Temperature Sensor Circuit High.
Code #63: Right Oxygen Sensor Circuit Open.
Code #64: Right Oxygen Sensor Circuit Lean.
Code #65: Right Oxygen Sensor Circuit Rich.
Code #66: A/C Pressure Sensor Circuit Open.
Code #67: A/C Pressure Sensor Circuit. (Sensor or A/C Clutch Circuit Problem)
Code #68: A/C Relay Circuit Shorted.
Code #69: A/C Clutch Circuit.
Code #72: Gear Selector Switch Circuit.
1994-1996
DTC #11: Malfunction Indicator Lamp Circuit.
DTC #13: Bank #1 Heated Oxygen Sensor #1 Circuit:
DTC #14: Engine Coolant Temperature Sensor Circuit Voltage Low.
DTC #15: Engine Coolant Temperature Sensor Circuit Voltage High.
DTC #16: Distributor Ignition System Low Pulse.
DTC #18: Injector Circuit.
DTC #21: Throttle Position Sensor Circuit Voltage High.
DTC #22: Throttle Position Sensor Circuit Voltage Low.
DTC #23: Intake Temperature Sensor Circuit Voltage High.
DTC #24: Vehicle Speed Sensor Circuit.
DTC #25: Intake Air Temperature Sensor Circuit Voltage Low.
DTC #26: Evaporative Emission Canister Purge Solenoid Valve Circuit.
DTC #27: EGR Vacuum Control Signal Solenoid Valve Circuit.
DTC #28: Transmission Range Pressure Switch Assembly Fault.
DTC #29: Secondary Air Injection Pump Circuit.
DTC #32: Exhaust Gas Recalculation.
DTC #33: Manifold Absolute Pressure Sensor Circuit High.
DTC #34: Manifold Absolute Pressure Sensor Circuit Low.
DTC #36: Distributor Ignition System High Pulse.
DTC #37: Brake Switch Stuck On.
DTC #38: Brake Switch Stuck Off.
DTC #41: Ignition Control Circuit Open.
DTC #42: Ignition Control Circuit Shorted.
DTC #43: Knock Sensor Circuit.
DTC #44: Bank 1 LF Heated Oxygen Sensor #1 Circuit Lean.
DTC #45: Bank 1 LF Heated Oxygen Sensor #1 Circuit Rich.
DTC #47: Knock Sensor Circuit Or Module Missing.
DTC #48: Mass Air Flow Sensor Circuit.
DTC #50: System Voltage Low.
DTC #51: EEPROM Programming Error.
DTC #52: Engine Oil Temperature Sensor Circuit Voltage Low.
DTC #53: System Voltage Low.
DTC #55: Fuel Lean Monitor.
DTC #58: Transmission Fluid Temperature Sensor Circuit Low.
DTC #59: Transmission Fluid Temperature Sensor Circuit High.
DTC #62: Engine Oil Temperature Sensor Circuit Voltage Low.
DTC #63: Bank 2 RF Heated Oxygen Sensor #1 Circuit Open.
DTC #64: Bank 2 RF Heated Oxygen Sensor #1 Circuit Lean.
DTC #65: Bank 2 RF Heated Oxygen Sensor #1 Circuit Rich.
DTC #66: A/C Refrigerant Pressure Sensor Circuit Open.
DTC #67: A/C Pressure Sensor Circuit Sensor or A/C Clutch.
DTC #68: A/C Relay Circuit.
DTC #69: A /C Clutch Circuit.
DTC #70: A/C Clutch Relay Driver Circuit.
DTC #72: Vehicle Speed Sensor Loss.
DTC #73: Pressure Control Solenoid Circuit Current Error.
DTC #74: Traction Control System Circuit Low.
DTC #75: Transmission System Voltage Low
DTC #77: Primary Cooling Fan Relay Control Circuit.
DTC #78: Secondary Cooling Fan Relay Control Circuit.
DTC #79: Transmission Fluid Overtemp.
DTC #80: Transmission Component Slipping.
DTC #81: Transmission 2-3 Shift Solenoid Circuit.
DTC #82: Transmission 1-2 Shift Solenoid Circuit.
DTC #83: Torque Converter Solenoid Voltage High.
DTC #84: 3-2 Control Solenoid Circuit.(Auto Only).
DTC #84: 2nd And 3rd Gear Blockout Relay Control Circuit.
DTC #85: Transmission TCC Stock On.
DTC #90: Transmission TCC Solenoid Circuit.
DTC #91: One To Four Upshift Lamp(Manual Only).
DTC #97: VSS Output Circuit.
DTC #98: Tachometer Output Signal Voltage Wrong.
Posted on: 2011/7/26 23:36
13 GMC 3500 dually
captmike13@yahoo.com
italian1969 Re: Trouble codes.
7 Posts
do you know the codes for an OBD2 mine tells me P0170 and P0171 bank 1 and 2 running lean. is it the o2 sensors. just replaced the optispark and it runs fine but check engine light came on again.
Posted on: 2011/9/15 23:42
BillH Re: Trouble codes.
What year?
Posted on: 2011/9/15 23:47
If it's a 1996
Engine DTC's
DTC P0100 MAF Sensor Circuit Insufficient Activity
DTC P0101 Mass Air Flow (MAF) Sensor Performance
DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
DTC P0106 Manifold Absolute Pressure (MAP) System Performance
DTC P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
DTC P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
DTC P0121 TP Sensor Circuit Insufficient Activity
DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage
DTC P0123 Throttle Position (TP) Sensor Circuit High Voltage
DTC P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
DTC P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
DTC P0132 HO2S Circuit High Voltage Bank 1 Sensor 1
DTC P0133 HO2S Slow Response Bank 1 Sensor 1
DTC P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
DTC P0135 HO2S Heater Performance Bank 1 Sensor 1
DTC P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
DTC P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
DTC P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
DTC P0141 HO2S Heater Performance Bank 1 Sensor 2
DTC P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1
DTC P0152 HO2S Circuit High Voltage Bank 2 Sensor 1
DTC P0153 HO2S Slow Response Bank 2 Sensor 1
DTC P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
DTC P0155 HO2S Heater Performance Bank 2 Sensor 1
DTC P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
DTC P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
DTC P0160 HO2S Circuit Insufficient Activity Bank 2 Sensor 2
DTC P0161 HO2S Heater Performance Bank 2 Sensor 2
DTC P0171 Fuel Trim System Lean Bank 1
DTC P0172 Fuel Trim System Rich Bank 1
DTC P0174 Fuel Trim System Lean Bank 2
DTC P0175 Fuel Trim System Rich Bank 2
DTC P0200 Injector Control Circuit
DTC P0300 Engine Misfire Detected
DTC P0323 DI Low/High Resolution Circuit Intermittent
DTC P0325 Knock Sensor Module Performance
DTC P0327 Knock Sensor (KS) Circuit Bank 1
DTC P0332 Knock Sensor (KS) Circuit Bank 2
DTC P0335 Crankshaft Position (CKP) Sensor Circuit
DTC P0336 Crankshaft Position (CKP) Sensor Performance
DTC P0372 DI High Resolution Circuit
DTC P0400 Exhaust Gas Recirculation (EGR) System Performance
DTC P0403 Exhaust Gas Recirculation (EGR) Solenoid Control Circuit
DTC P0410 Secondary Air Injection (AIR) System
DTC P0412 Secondary Air Injection (AIR) Relay Control Circuit
DTC P0420 Catalyst System Low Efficiency Bank 1
DTC P0430 Catalyst System Low Efficiency Bank 2
DTC P0441 Evaporative Emission (EVAP) System No Flow During Purge
DTC P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P0500 Vehicle Speed Sensor (VSS) Circuit
DTC P0506 Idle Speed Low
DTC P0507 Idle Speed High
DTC P0530 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit
DTC P0531 Air Conditioning (A/C) Refrigerant Pressure Sensor Performance
DTC P0562 System Voltage Low
DTC P0563 System Voltage High
DTC P0601 Control Module Read Only Memory (ROM)
DTC P0602 Control Module Not Programmed
DTC P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
DTC P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
DTC P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
DTC P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
DTC P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
DTC P1133 HO2S Insufficient Switching Bank 1 Sensor 1
DTC P1134 HO2S Transition Time Ratio Bank 1 Sensor 1
DTC P1153 HO2S Insufficient Switching Bank 2 Sensor 1
DTC P1154 HO2S Transition Time Ratio Bank 2 Sensor 1
DTC P1171 Fuel System Lean During Acceleration
DTC P1187 EOT Sensor Circuit Low Voltage
DTC P1188 EOT Sensor Circuit High Voltage
DTC P1222 Injector Control Circuit Intermittent
DTC P1351 Ignition Coil Control Circuit High Voltage
DTC P1361 Ignition Coil Control Circuit Low Voltage
DTC P1371 DI Low Resolution Circuit
DTC P1380 Misfire Detected - Rough Road Data Not Available
DTC P1381 Misfire Detected - No Communication with Brake Control Module
DTC P1415 Secondary Air Injection (AIR) System Bank 1
DTC P1416 Secondary Air Injection (AIR) System Bank 2
DTC P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
DTC P1508 Idle Speed Low - Idle Air Control (IAC) System Not Responding
DTC P1509 Idle Speed High - Idle Air Control (IAC) System Not Responding
DTC P1539 Air Conditioning (A/C) Clutch Feedback Circuit High Voltage
DTC P1545 Air Conditioning (A/C) Clutch Relay Control Circuit
DTC P1546 Air Conditioning (A/C) Clutch Feedback Circuit Low Voltage
DTC P1572 ASR/TCS Active CKT Low Voltage Too Long
DTC P1641 Cooling Fan Relay 1 Control Circuit
DTC P1642 Cooling Fan Relay 2 and 3 Control Circuit
DTC P1643 Engine Speed Output Circuit
DTC P1652 Vehicle Speed Output Circuit
DTC P1657 Skip Shift Solenoid Control Circuit
DTC P1661 Malfunction Indicator Lamp (MIL) Control Circuit
DTC P1664 Skip Shift Lamp Control Circuit
Transmission DTC's
DTC P0502 Vehicle Speed Sensor (VSS) Circuit Low Input
DTC P0560 System Voltage
DTC P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
DTC P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input
DTC P0719 Brake Switch Circuit Low Input
DTC P0724 Brake Switch Circuit High Input
DTC P0742 TCC System Stuck On
DTC P0748 Pressure Control Solenoid Circuit Electrical
DTC P0751 1-2 Shift Solenoid Valve Performance
DTC P0753 1-2 Shift Solenoid Circuit Electrical
DTC P0756 2-3 (B) Shift Solenoid Performance
DTC P0758 2-3 (B) Shift Solenoid Electrical
DTC P1572 TCS Active Circuit Low Voltage Too Long
DTC P1810 TFP Valve Position Switch Circuit
DTC P1812 Transmission Fluid Overtemperature
DTC P1860 TCC PWM Solenoid Circuit Electrical
DTC P1864 TCC Solenoid Electrical
DTC P1870 Transmission Component Slipping
DTC P1886 3-2 SS Valve Assembly CKT Electrical
Posted on: 2011/9/16 0:33
Frank Re: Trouble codes.
188 Posts
Thanks for this post. It cleared up a mystery for me. My Chiltons said the code was either a MAF or a MAP.
Posted on: 2012/8/25 18:57
188 Posts
Learned something today I had a code 34 on my 1984 Corvette. The Chiltons said it was either a MAF or a MAP sensor. According to some other literature I found it was a MAF sensor so I started looking for it. Turns out my Corvette (is this true with all 1984's?) does not have a MAF sensor. Sooo I looked at the MAP sensor and found it unplugged.(?) Not sure how that happened but anyhow problem solved no more check engine light. If only everything was this easy......... Another clue for me early on was the fact that I couldn't find a MAF for this year Corvette at any of the parts houses.
Posted on: 2012/9/5 18:03
bogus Re: Trouble codes.
MAF = Mass Air Flow. 1984 Corvettes did NOT have this part.
MAP = Manifold Absolute Pressure. 1984 Corvettes DID have this part.
Get a new one. It's important for the computer to know this information. It's about how much air is going in, so it can adjust fuel mixture accordingly.
Posted on: 2012/9/5 18:18
188 Posts
"Sooo I looked at the MAP sensor and found it unplugged." Plugged it back in and all is well. Thanks for the good info.
Posted on: 2012/9/5 22:12
LV2XLR8 Re: Trouble codes.
Hoover AL
1 Posts
Im new to Corvettes this is my first She is a 1993 LT-1 5.7L V8 Torch Red with Red and Black interior Targa Top Coupe
I need to get a list of trouble codes for the 1993 Please if anyone has a list or link
Thanks In Advance
Lou "Diamond" Phillips
Posted on: 2013/1/1 18:51
Matatk Re: Trouble codes.
Welcome to the site. If you look above, they are listed under 1992-1993.
Posted on: 2013/1/1 19:09
Thanks In Advance
Named after a famous Marine, eh?
This is more specific for the 92/93... and if the the library function was working right....
Welcome aboard!!
pdf CCM Code Pull.pdf Size: 336.94 KB; Hits: 596
Posted on: 2013/1/1 20:05
VetteNut Re: Trouble codes.
1 Posts
I have code 22 coming up on my '89 convertible. Anyone have a cure? Thanks.
Posted on: 2013/6/10 19:15
That tells me your Throttle Position Sensor is more than likely failing.
You need a DVM - Digital Volt Meter - and back probe the TPS. Turn on the key - don't start - and watch the TPS voltage.
As your manually turn the throttle, the volts should climb from about .54 to 5v. If in that arc, it decides to drop out for a moment, well, you have found the dead spot.
The TPS is on the right side of the throttle body, and has a 3 wire connector, IIRC. There is also the IAC - Idle Air Control - but that is below the throttle body; and has a square 4 wire connector.
Posted on: 2013/6/10 22:03
