309 user(s) are online (241 user(s) are browsing Forums)
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
corvetteronw Am I on the right track with this no start?
Lowell, MI
91 L98. This week I have been unable to get her to fire up. Pulled codes (none), checked spark (it's strong), checked timing while it cranked (right on).
Checked fuel pressure while cranking: goes from 0 to 68 lbs after 20 seconds of cranking. My book says it should be at 40-42 lbs while cranking.
I checked #1 plug and it is wet and checked the oil dipstick (no fuel smell and not too high on dipstick). There is a gasoline smell after I crank on it for a while but I see no external leaks. Engine will not even cough.
I think I have a bad fuel pressure regulator. It came with my replacement intake manifold so I have no idea how many miles are on it. When I replaced the O rings in the fuel rail recently the existing rings were intact but some of them were a bit mushy.
I can get a fuel pressure regulator rebuild kit from Corvette Central for mid $80 range. I will check with the local NAPA store to see if they make one too.
Does it look like I am on the right track or should I be looking elsewhere?
Go Detroit Tigers! Getting ready to watch game 6 and hoping for the best.
Posted on: 2013/10/20 0:05
bogus Re: Am I on the right track with this no start?
gee... sounds like too much fuel pressure is blowing out the spark... in short, it's flooding.
TPiS also has a nice AFPR.
Posted on: 2013/10/20 0:07
corvetteronw Re: Am I on the right track with this no start?
Lowell, MI
The AFPR is the "hat" and disc only. I need the rubber guts too as mine are rotted.
Posted on: 2013/10/20 14:21
Matatk Re: Am I on the right track with this no start?
Order the diaphragm from tpis, they have the best price. Sounds like that is your problem.
Posted on: 2013/10/20 16:54
Schrade Re: Am I on the right track with this no start?
What's your static pressure? (before cranking) And pressure leakdown time?
Posted on: 2013/10/27 14:57
CentralCoaster Re: Am I on the right track with this no start?
You sure your fuel pressure guage is good? Is this a diagnostic gage or something you leave on the rail?
Posted on: 2013/10/27 22:37
Frank Re: Am I on the right track with this no start?
188 Posts
Fuel pressure is a bit too high but I'm thinking along the lines of either a bad Crankshaft or Camshaft Position Sensor. It will show a spark but a weak one.
Posted on: 2013/11/21 22:50
The old school L98 lacks both sensors...
Posted on: 2013/11/21 23:03
