tjpreul | timing chain cover | ||
I just put a new engine in my GMC jimmy. The front seal between the timing chain cover and the oil pan is leaking. There is about an 1/8 inch gap where you can see the seal between the two. It is leaking at the part that meets the pan. Any ideas to seal this without having to pull the engine or the pan.
Posted on: 2013/12/2 2:50
Calm | Re: timing chain cover | ||
The only way I know of in properly replacing the timing cover on any small block (6 or 8) is dropping the pan at least 1/2" to allow the timing cover front pan gasket to get compressed once the pan is re-tightened.
Posted on: 2013/12/2 3:03
1995 Forged 385 ZF6 227/234 1.6 FIC30# MSD BBK SS SLP Bullets X-Pipe DynoMax |
rklessdriver | Re: timing chain cover | ||
What engine? What year?
The SBC has 2 different front covers, that take 2 different thickness front seals between the timing cover and oil pan. Will |
Posted on: 2013/12/2 23:19
BrianCunningham | Re: timing chain cover | ||
sounds like the pan and the cover don't match
Posted on: 2013/12/2 23:35
tjpreul | Re: timing chain cover | ||
It is a 4.3l V6. Here is a picture of the timing cover. It is leaking at the top of the blue seal where the cover, pan and block meet.
Posted on: 2013/12/3 15:12
