201 user(s) are online (118 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
mechguy79 No Start
San Angelo, Tx
39 Posts
New problem. The car won't start. The starter won't engage at all. The fuel pump kicks on, but when trying to start, nothing. Battery is good. The security light goes out when the key is turned on. Starter is new. 1990 L98 6spd.
When VATS is tripped what all is disabled? Just the starter? Will the fuel pump still kick on? Does the security light flash?
Neutral safety switch?
Starter relay?
I haven't had a chance to diagnose it much. I am at work and had to leave the car at a fast food joint.
Any help is appreciated.
Posted on: 2013/12/16 18:41
bogus Re: No Start
if it's vats, it will crank, won't fire...
Leave it sit for 10 minutes and retry.
It could be a loose connection, too. They must be tight or they won't work at all.
Posted on: 2013/12/16 18:53
joeld Re: No Start
Actually VATS does control starter engagement, there is a starter enable relay under the hush panel drivers side. Pump will run, injectors will not fire.
Do you have a spare key? Try that if you do.
But like Andy said, check connections anyway.
Could possibly be the neutral safety switch.
Posted on: 2013/12/16 23:10
mechguy79 Re: No Start
San Angelo, Tx
39 Posts
Car started back up no problem when left alone for a while. Makes me think the "new" starter is having issues. Maybe the starter solenoid on the new starter gets flaky when hot, or something. I will check connections, and check the neutral switch. At this point I guess I have to park it again until I get these checks done. Bummer.
Posted on: 2013/12/17 0:56
bogus Re: No Start
Yes, the VATS does effect the starter... has happened to me a couple of times... thinking about it now!
So it more then likely was the VATS...
Clean off the key with some brake cleaner... and if you have a spare, use that.
Posted on: 2013/12/17 2:38
TommyT-Bone Re: No Start
33766 Posts
Alcohol works well too at cleaning the pellet, if that's the issue.
Posted on: 2013/12/17 3:31
BillH Re: No Start
Yea, clean the key.
When VATS doesn't recognize the key, a timer starts.
It's supposed to be around 10 minutes but some go a bit longer.
And, If you try and start the car within those 10 minutes, you reset the timer and it will take another 10-15.
If you want to see if it's VATS or the solenoid, you'll have to wait until you get a no start again. Put a voltmeter on the small "start" wire on the solenoid and turn the key to "start". If there's no voltage, then it's VATS (or the starter enable relay, but that's unusual).
Doing this will reset the VATS timer so, wait 15 and try to start. If the starter spins, it's the VATS system.
As Andy said, sometimes this happens and then goes away. I had 3 VATS no starts in one year then it hasn't happened again (6 years).
IIRC, you can pull the codes to confirm a VATS issue on your year. I know you can on 92 & up, you'll get a "pass key error" if it's a VATS problem.
Posted on: 2013/12/17 13:43
istter1 Re: No Start
Bakersfield Ca
2336 Posts
When I had my chip burned I had PCM eleminate VATS . On my 87 it would go months or just days for it to arm. When I finish the SR install I will hopefully have stopped that problem.. Tired of waiting for it to disarm.
Posted on: 2013/12/18 2:05
Carol Burnett
bogus Re: No Start
can't do that so easily with the later VATS... it's integrated into the CCM and ECM... yuck-o-rama.
easiest solution? get some resisters that match the key and bypass accordingly.
Posted on: 2013/12/18 2:16
San Angelo, Tx
39 Posts
I still need to get a new key. It is probably VATS because I just ordered my new tune from PCM4less and didn't remove VATS. Now enters murphy and kicks me in the a$$.
Posted on: 2013/12/18 19:09
Matatk Re: No Start
Have you revisited this at all?
Posted on: 2013/12/20 13:38
bogus Re: No Start
AFAIK, you can't program it out... there has been past discussions on it.
The CCM is sending a handshake and it's weird... Perhaps the tuners have figured it out.
Clean off the key, try again.
Posted on: 2013/12/20 18:45
San Angelo, Tx
39 Posts
The car seems happy at the moment. Havent found anything loose yet. I cleaned off the key (didn't look dirty). I will continue to monitor it. There may be a VATS bypass in my future.
Posted on: 2013/12/21 0:52
vetteoz Re: No Start
If VATS is programmed out in the tune on a SD car, the ECM will not look for the required fuel enable signal from the CCM ;
exactly the same as happens with the VATS delete on earlier MAF cars with the standalone VATS module
In any case ,you have to manually bypass the VATS operated starter enable relay to fully remove VATS from the car
Resistors only work to "fool" VATS into thinking the correct key is being used.If there is a fault with the VATS system itself , the resistors will do zilch
Posted on: 2013/12/30 0:27
