206 user(s) are online (115 user(s) are browsing Forums)
TommyT-Bone, more...
« 1 2 3 (4) 5 6 7 »
BrianCunningham Re: Super Ram on the way
Good use of the bore scope
Be glad you caught it.
I know someone that didn't, wasn't too pleased with the results.
Posted on: 2013/12/19 14:02
istter1 Re: Super Ram on the way
Bakersfield Ca
2336 Posts
HF has some items that are worth their money.. This one sure was.
Posted on: 2013/12/19 14:22
Carol Burnett
bogus Re: Super Ram on the way
It's on my short list...
Posted on: 2013/12/20 3:07
Bakersfield Ca
2336 Posts
Posted on: 2013/12/20 6:15
Carol Burnett
Wow those came down quite a bit
Posted on: 2013/12/20 16:35
they have been. the proliferation of smart phones and cheap camera tech has made them cheap cheap cheap.
I have been watching them for some time; Fry's has been selling one for about $120 for at least a year.
Posted on: 2013/12/20 18:44
Bakersfield Ca
2336 Posts
Paid $70 on sale last year
Posted on: 2013/12/20 21:14
Carol Burnett
Churchkey Re: Super Ram on the way
69 Posts
Amazon 69.95 & free shipping
search "digital inspection camera"
Posted on: 2013/12/21 0:09
Bakersfield Ca
2336 Posts
Are there two vacuum lines that plug into this sensor?
Putting the valve covers on wasn't easy. Lots of nuts and bolts to disconnect and reconnect.
Getting close to firing her up.
jpeg  20131220_221811.jpeg (359.34 KB)
5144_52b53619638dd.jpeg 1200X1600 px
jpeg  20131220_221840.jpeg (232.81 KB)
5144_52b5365353f36.jpeg 1200X1600 px
Posted on: 2013/12/21 6:40
Carol Burnett
Woodstock Re: Super Ram on the way
Bremen/Germany
369 Posts
Sure, one into the EGR valve and the other into the throttle body.
Posted on: 2013/12/21 10:54
91 convertible
Bakersfield Ca
2336 Posts
Which line is on top.
pdf EGR System.pdf Size: 392.31 KB; Hits: 229
Posted on: 2013/12/21 13:30
Edited by istter1 on 2013/12/21 13:49:24
Carol Burnett
69 Posts
This may help
[URL=http://s863.photobucket.com/user/churchkey/media/vettevacuum2520lines.gif.html]Resized Image[/URL]
Posted on: 2013/12/21 15:22
Bremen/Germany
369 Posts
or this:
jpg  egr.jpg (138.33 KB)
1024_52b5b69c9f2aa.jpg 1000X563 px
Posted on: 2013/12/21 15:41
91 convertible
Bakersfield Ca
2336 Posts
Vacume on top
Off to get some plugs for extra vacum connections
And water hose clamps
Thanks
Posted on: 2013/12/21 18:38
Carol Burnett
Bakersfield Ca
2336 Posts
First question how do you move the bracket up the cable so I can mount it to the pelum?
Plugged excess vacuum ports.
No leaks pleasure holding.
Have to insert chip and then fire it up.
Was told to let it idle for 15 minutes so ecm can adjust?
jpeg  20131221_181632.jpeg (275.80 KB)
5144_52b661de455cf.jpeg 1200X1600 px
jpeg  20131221_121049.jpeg (383.46 KB)
5144_52b66214467d7.jpeg 1200X1600 px
jpeg  20131221_121656.jpeg (312.07 KB)
5144_52b6624bed63f.jpeg 1200X1600 px
Posted on: 2013/12/22 4:00
Carol Burnett
looking good!!!
Donno why you would have extra vacuum to cap off. Please explain...
Posted on: 2013/12/22 7:33
Bakersfield Ca
2336 Posts
looking good!!!
can't find any other lines to hook up. Drink a lot of whine while slowly going through the double and triple check process.in my memory there should be one more.
Posted on: 2013/12/22 15:05
Carol Burnett
Bakersfield Ca
2336 Posts
Churchkey wrote:
This may help
Andy if this chart is correct I have everything covered.
Right now concern is how to move the clips that hold the cables so I can attach the bracket to pelum
5144_52b70e8bc5267.jpeg 1200X1600 px
Posted on: 2013/12/22 16:11
Carol Burnett
Bakersfield Ca
2336 Posts
I had 1 & 2 reversed
Still checking
jpg  valvethr.jpg (22.59 KB)
5144_52b71e63745a6.jpg 640X480 px
Posted on: 2013/12/22 17:17
Carol Burnett
looking good!!!
same part for different years??
Just an educated guess on my part
Posted on: 2013/12/22 18:52
Bakersfield Ca
2336 Posts
Today feel like them.
http://www.youtube.com/watch?feature= ... _detailpage&v=J96zfbwijMs
Went to start engine and 4 injectors plugs off. Drivers side off trying to find something to
hold so I can re set it tight fit.
Linkage up side down duhhhh.
Phone rand Stacy call says we are going to church mow. Lunch. Next a long walk.
Nap time and in an hour try to figure out what to use to hold and position plug. Needle nose player's no luck.
Any suggestions
5144_52b7933e5b827.jpeg 1200X1600 px
Posted on: 2013/12/23 1:39
Carol Burnett
Bakersfield Ca
2336 Posts
Will try these to put caps back on injectors tomorrow
jpeg  20131222_211255.jpeg (316.32 KB)
5144_52b7cfd3a3466.jpeg 1200X1600 px
Posted on: 2013/12/23 5:56
Carol Burnett
Matatk Re: Super Ram on the way
22806 Posts
I had no problem with the injector harnesses on mine. I would try long needle nose pliers before chopsticks. Just me.
Posted on: 2013/12/23 12:44
Bakersfield Ca
2336 Posts
My son with the good eyes tried the long pliers had no luck. He is the one that knocked the plugs off when he installed the valve covers and didn't check before he tightened them down. When it warms up some I will get her done.
Posted on: 2013/12/23 13:35
Carol Burnett
Still checking
#1 is for PCV, #2 is evap emissions.
Posted on: 2013/12/23 15:02
Bakersfield Ca
2336 Posts
Still checking
Thanks got that right. Lol
Posted on: 2013/12/23 18:59
Carol Burnett
Bakersfield Ca
2336 Posts
These work great. Got some loose connection to fix.
May start tonight or tomorrow.
Fingers crossed
jpeg  20131223_163512.jpeg (357.86 KB)
5144_52b8e83ae475d.jpeg 1600X1200 px
Posted on: 2013/12/24 1:51
Carol Burnett
22806 Posts
Posted on: 2013/12/24 2:36
Bakersfield Ca
2336 Posts
Might have an injector in wrong place would this cause a backfire? Wants to start but not getting enough fuel I am thinking. Only one backfire. Never removed of moved Dizzy.
Posted on: 2013/12/24 4:46
Carol Burnett
69 Posts
L98 injection is batch fire not sequential. It does not make any difference which connector is attached to an injector.
Suggest cycling the ignition. Key on for 5 seconds then off, repeat 4-5 times this will fill the fuel rails etc.
Check the firing order.
Posted on: 2013/12/24 6:23
Bakersfield Ca
2336 Posts
Did not know that. Thanks
Posted on: 2013/12/24 12:25
Carol Burnett
22806 Posts
What he said....doesn't matter what injector wire is on which injector.
Double check wires and make sure dizzy wires and everything is hooked up correctly. Did you properly clock the distributor when you put it back in? Was the motor on TDC?
Posted on: 2013/12/24 12:44
22806 Posts
Sorry I just reread that you said you never removed the distributor. Was it loosened at all? Check timing. Backfire sounds like a timing issue.
Posted on: 2013/12/24 12:45
Bakersfield Ca
2336 Posts
Double checking everything
Going to reset throttel.position sensor
Looking for the setting
5 something
Posted on: 2013/12/24 18:32
Carol Burnett
69 Posts
5 something
You need a good digital voltmeter that will read voltages less than 1 volt.
The setting is .54 = just over 1/2 volt.
Merry Christmas "Doctor"
Posted on: 2013/12/24 20:17
Bakersfield Ca
2336 Posts
5 something
Just got back.from store bought a digital. Pain in butt getting .54.
Was .35. It tries to fire. Found out son was doing something . Two plug wires un hooked. Plug wire t cap pushed up and loose from installing pelum.
Now it wants to start. Sometime it trys to.idel other times reves uo.
My guess vacume leaks some where..
Feel like six pack time
Posted on: 2013/12/25 1:03
Carol Burnett
Bakersfield Ca
2336 Posts
Ya using old style meter not good. found line I didn't connect and added connector . I was looking Andy..
Closer to starting. Not yet
lol
jpeg  20131224_123046.jpeg (250.70 KB)
5144_52ba67c4855be.jpeg 1200X1600 px
jpeg  20131224_203632.jpeg (228.02 KB)
5144_52ba6814c632c.jpeg 1600X1200 px
jpg  hav.jpg (15.80 KB)
5144_52ba6a9e3c735.jpg 400X400 px
jpeg  20131224_205522.jpeg (151.49 KB)
5144_52ba6ac1a86ce.jpeg 1200X1600 px
Posted on: 2013/12/25 5:22
Carol Burnett
22806 Posts
Double check all those connections. It's easy to have a vacuum leak on these if you don't tighten everything evenly. Good luck.
Posted on: 2013/12/25 12:44
Bakersfield Ca
2336 Posts
Nothing else to do today. Thanks for the encouragement
Posted on: 2013/12/25 13:27
Carol Burnett
Bakersfield Ca
2336 Posts
Grasping at straws
Could I have installed the chip on the piggy back the wrong way.
If I did what would be the results
Posted on: 2013/12/25 19:22
Carol Burnett
nothing... perhaps a seriously pissed off SES light as the ECM would have been totally confused. crank yes, start no.
Posted on: 2013/12/26 0:17
Bakersfield Ca
2336 Posts
great answer
Posted on: 2013/12/26 1:39
Carol Burnett
BillH Re: Super Ram on the way
istter1 wrote:
Grasping at straws
The chip/board should be keyed (as ALL electronic connectors are).
Putting in backwards with power to the wrong connector could blow the prom depending on the circuitry path. Which is why things are keyed.
Posted on: 2013/12/26 3:44
Bakersfield Ca
2336 Posts
BillH wrote:
istter1 wrote:
Grasping at straws
I installed it before the SR and took a picture of it. My son put the chip in after the flash from PCM and thought he may have put it in wrong.
I pulled it and it looks correct
jpeg  20131007_183809.jpeg (257.82 KB)
5144_52bbbead2c569.jpeg 1200X1600 px
jpeg  1381716311932.jpeg (306.14 KB)
5144_52bbbebf5bee1.jpeg 1200X1600 px
Posted on: 2013/12/26 5:30
Carol Burnett
Bakersfield Ca
2336 Posts
My friends shop has a smoke machine I will check with him tomorrow and see if I can use it.
Guessing sucks
Posted on: 2013/12/26 6:33
Carol Burnett
22806 Posts
Im on my phone right now...pic looks ok but I am not sure off hand. The adapter can only be installed one way. The chip can in fact be installed backwards. Look at moates.net for a picture. There is a half moon shape on the chip that helps you identify orientation.
Posted on: 2013/12/26 14:51
Possible, I have one of Alvin's chip/adapters somewhere in the shop, I'll see if I can find it today.
Posted on: 2013/12/26 15:16
Bakersfield Ca
2336 Posts
The prom can be put on two directions. Nothing stops you from flipping over the prom . Moates chip is the same I have one here.
Gota go get blood drawn will pull it out and look at it when I get back.
Teachers have good vacations.
jpeg  20131226_075941.jpeg (175.04 KB)
5144_52bc5406e377f.jpeg 1600X1200 px
jpeg  20131226_080047.jpeg (167.98 KB)
5144_52bc542f66301.jpeg 1600X1200 px
jpeg  20131226_080020.jpeg (139.40 KB)
5144_52bc544d5ae78.jpeg 1200X1600 px
Posted on: 2013/12/26 16:07
Carol Burnett
Bakersfield Ca
2336 Posts
Well smoke machine is down so I will do the smoke machine the old school way.
jpeg  20131226_100337.jpeg (318.73 KB)
5144_52bc732bbc50a.jpeg 1600X1200 px
jpg  bth_red-dumb-ass.jpg (9.48 KB)
5144_52bc737d1e95a.jpg 280X210 px
Posted on: 2013/12/26 18:22
Carol Burnett
22806 Posts
So what are the symptoms of "trying" to start? Cranks? Catches? Runs and dies?
Are you sure all of the connectors are in and tight?
Even with a vacuum leak you will start and run, but it will be high idle, rough, uneven, etc.
Posted on: 2013/12/27 1:08
« 1 2 3 (4) 5 6 7 »
