Browsing this Thread:
2 Anonymous Users
BrianCunningham | Re: Super Ram on the way | ||
Good use of the bore scope
Be glad you caught it. I know someone that didn't, wasn't too pleased with the results. |
Posted on: 2013/12/19 14:02
istter1 | Re: Super Ram on the way | ||
HF has some items that are worth their money.. This one sure was. |
Posted on: 2013/12/19 14:22
bogus | Re: Super Ram on the way | ||
It's on my short list...
Posted on: 2013/12/20 3:07
$90 not sale price http://www.harborfreight.com/digital-inspection-camera-67979.html http://images.harborfreight.com/manuals/66000-66999/66550.pdf |
Posted on: 2013/12/20 6:15
Wow those came down quite a bit
Posted on: 2013/12/20 16:35
they have been. the proliferation of smart phones and cheap camera tech has made them cheap cheap cheap.
I have been watching them for some time; Fry's has been selling one for about $120 for at least a year. |
Posted on: 2013/12/20 18:44
Paid $70 on sale last year
Posted on: 2013/12/20 21:14
Churchkey | Re: Super Ram on the way | ||
Amazon 69.95 & free shipping
search "digital inspection camera" |
Posted on: 2013/12/21 0:09
Are there two vacuum lines that plug into this sensor?
Putting the valve covers on wasn't easy. Lots of nuts and bolts to disconnect and reconnect. Getting close to firing her up. |
Posted on: 2013/12/21 6:40
Woodstock | Re: Super Ram on the way | ||
Sure, one into the EGR valve and the other into the throttle body. |
Posted on: 2013/12/21 10:54
91 convertible |
Which line is on top. |
Posted on: 2013/12/21 13:30
Edited by istter1 on 2013/12/21 13:49:24 |
This may help
[URL=http://s863.photobucket.com/user/churchkey/media/vettevacuum2520lines.gif.html][/URL] |
Posted on: 2013/12/21 15:22
or this:
Posted on: 2013/12/21 15:41
91 convertible |
Vacume on top
Off to get some plugs for extra vacum connections And water hose clamps Thanks |
Posted on: 2013/12/21 18:38
First question how do you move the bracket up the cable so I can mount it to the pelum?
Plugged excess vacuum ports. No leaks pleasure holding. Have to insert chip and then fire it up. Was told to let it idle for 15 minutes so ecm can adjust? |
Posted on: 2013/12/22 4:00
looking good!!!
Donno why you would have extra vacuum to cap off. Please explain... |
Posted on: 2013/12/22 7:33
Posted on: 2013/12/22 15:05
Andy if this chart is correct I have everything covered. Right now concern is how to move the clips that hold the cables so I can attach the bracket to pelum |
Posted on: 2013/12/22 16:11
I had 1 & 2 reversed
Still checking |
Posted on: 2013/12/22 17:17
same part for different years?? Just an educated guess on my part |
Posted on: 2013/12/22 18:52
Today feel like them. http://www.youtube.com/watch?feature= ... _detailpage&v=J96zfbwijMs Went to start engine and 4 injectors plugs off. Drivers side off trying to find something to hold so I can re set it tight fit. Linkage up side down duhhhh. Phone rand Stacy call says we are going to church mow. Lunch. Next a long walk. Nap time and in an hour try to figure out what to use to hold and position plug. Needle nose player's no luck. Any suggestions |
Posted on: 2013/12/23 1:39
Will try these to put caps back on injectors tomorrow
Posted on: 2013/12/23 5:56
Matatk | Re: Super Ram on the way | ||
I had no problem with the injector harnesses on mine. I would try long needle nose pliers before chopsticks. Just me.
Posted on: 2013/12/23 12:44
My son with the good eyes tried the long pliers had no luck. He is the one that knocked the plugs off when he installed the valve covers and didn't check before he tightened them down. When it warms up some I will get her done. |
Posted on: 2013/12/23 13:35
Posted on: 2013/12/23 15:02
Thanks got that right. Lol |
Posted on: 2013/12/23 18:59
These work great. Got some loose connection to fix.
May start tonight or tomorrow. Fingers crossed |
Posted on: 2013/12/24 1:51
Posted on: 2013/12/24 2:36
Might have an injector in wrong place would this cause a backfire? Wants to start but not getting enough fuel I am thinking. Only one backfire. Never removed of moved Dizzy.
Posted on: 2013/12/24 4:46
L98 injection is batch fire not sequential. It does not make any difference which connector is attached to an injector.
Suggest cycling the ignition. Key on for 5 seconds then off, repeat 4-5 times this will fill the fuel rails etc. Check the firing order. |
Posted on: 2013/12/24 6:23
Did not know that. Thanks |
Posted on: 2013/12/24 12:25
What he said....doesn't matter what injector wire is on which injector.
Double check wires and make sure dizzy wires and everything is hooked up correctly. Did you properly clock the distributor when you put it back in? Was the motor on TDC? |
Posted on: 2013/12/24 12:44
Sorry I just reread that you said you never removed the distributor. Was it loosened at all? Check timing. Backfire sounds like a timing issue.
Posted on: 2013/12/24 12:45
Double checking everything Going to reset throttel.position sensor Looking for the setting 5 something |
Posted on: 2013/12/24 18:32
You need a good digital voltmeter that will read voltages less than 1 volt. The setting is .54 = just over 1/2 volt. Merry Christmas "Doctor" |
Posted on: 2013/12/24 20:17
Just got back.from store bought a digital. Pain in butt getting .54. Was .35. It tries to fire. Found out son was doing something . Two plug wires un hooked. Plug wire t cap pushed up and loose from installing pelum. Now it wants to start. Sometime it trys to.idel other times reves uo. My guess vacume leaks some where.. Feel like six pack time |
Posted on: 2013/12/25 1:03
Ya using old style meter not good. found line I didn't connect and added connector . I was looking Andy..
Closer to starting. Not yet lol |
Posted on: 2013/12/25 5:22
Double check all those connections. It's easy to have a vacuum leak on these if you don't tighten everything evenly. Good luck.
Posted on: 2013/12/25 12:44
Nothing else to do today. Thanks for the encouragement |
Posted on: 2013/12/25 13:27
Grasping at straws
Could I have installed the chip on the piggy back the wrong way. If I did what would be the results |
Posted on: 2013/12/25 19:22
nothing... perhaps a seriously pissed off SES light as the ECM would have been totally confused. crank yes, start no.
Posted on: 2013/12/26 0:17
great answer |
Posted on: 2013/12/26 1:39
BillH | Re: Super Ram on the way | ||
The chip/board should be keyed (as ALL electronic connectors are). Putting in backwards with power to the wrong connector could blow the prom depending on the circuitry path. Which is why things are keyed. |
Posted on: 2013/12/26 3:44
I installed it before the SR and took a picture of it. My son put the chip in after the flash from PCM and thought he may have put it in wrong. I pulled it and it looks correct |
Posted on: 2013/12/26 5:30
My friends shop has a smoke machine I will check with him tomorrow and see if I can use it.
Guessing sucks |
Posted on: 2013/12/26 6:33
Im on my phone right now...pic looks ok but I am not sure off hand. The adapter can only be installed one way. The chip can in fact be installed backwards. Look at moates.net for a picture. There is a half moon shape on the chip that helps you identify orientation.
Posted on: 2013/12/26 14:51
Possible, I have one of Alvin's chip/adapters somewhere in the shop, I'll see if I can find it today. |
Posted on: 2013/12/26 15:16
The prom can be put on two directions. Nothing stops you from flipping over the prom . Moates chip is the same I have one here. Gota go get blood drawn will pull it out and look at it when I get back. Teachers have good vacations. |
Posted on: 2013/12/26 16:07
Well smoke machine is down so I will do the smoke machine the old school way.
Posted on: 2013/12/26 18:22
So what are the symptoms of "trying" to start? Cranks? Catches? Runs and dies?
Are you sure all of the connectors are in and tight? Even with a vacuum leak you will start and run, but it will be high idle, rough, uneven, etc. |
Posted on: 2013/12/27 1:08
