Crazy8 | LS2 swap into early C4? | ||
Are there any kits on the market to do this? Or is it all custom fab work? My shop suggested that I look at this as an option to the 383, as the prices are about the same. I currently have a factory L98 with a 700R4. Rear was upgraded before I bought it to a Dana 44, but am going to go with a 4 link solid rear end from CF member ski_dwn_it. My 86 Vette will be mostly used on the drag strip, but will also need street manners, as I will have to drive the Vette to the strip and want to drive it from time to time around town and on Corvette Cruises. Any input would be great!! Thanks.
Posted on: 2008/2/20 16:15
2008 Corvette - JSB, 3LT, Z51, NPP, U3U, A6 1986 Corvette - For Sale...PM me for info 1986 Monte Carlo SS - 400hp 2007 Dodge Charger Daytona R/T - Plum Crazy #981 of 1400 |
bogus | RE:LS2 swap into early C4? | ||
the LSx engine family is nice. and it is do able.
I don't remember all the sources, tho... This is a good start: http://www.hotrodlane.cc/ |
Posted on: 2008/2/21 3:49
Shadow | RE:LS2 swap into early C4? | ||
As the LSx swap becomes more popular, many shops are now starting to make adapter plates and motor mounts to ease the application.
I read about one recently but can't find the info I think you can probably find the answers with Google |
Posted on: 2008/2/23 3:49
Who knows what evil lurks in the heart of men? The SHADOW knows... The CF Artist fka: STREETKNIGHT..R.I.P. www.CorvetteFlorida.com www.CorvetteInternational.com |
cuisinartvette | RE:LS2 swap into early C4? | ||
Posted on: 2008/2/23 4:08
Danspeed1 | RE:LS2 swap into early C4? | ||
I think Trey over at Speed Hound Sells a set of adapter plates from this conversion cheap; and other stuff too.
DG |
Posted on: 2008/2/23 6:28
Motown blocks now makes an LSx block with the bosses to fit to a SBC engine compartment.
Posted on: 2008/2/23 7:06
I think Trey over at Speed Hound Sells a set of adapter plates from this conversion cheap; and other stuff too. Thats the one I was thinking about If those fukkr's at brand X hadn't locked me out, I had it saved in my subscribed threads Andy, do you have a link for the Motown blocks? |
Posted on: 2008/2/23 11:34
corvetteronw | RE:LS2 swap into early C4? | ||
I attended a seminar put on by Chris Petris at Carlisle last year. They had an 85 there with an LSx crate motor hooked up to a late model auto tranny. They drove the car up from Florida with no problems. The class was cosponsored by Corvette Central and Corvette Fever.
Try contacting Corvette Central or Corvette Fever for more info. You could also try Chris Petris at chris@corvetteclinic.com[size=12:5d1f8bbc05] [/size:5d1f8bbc05] |
Posted on: 2008/2/26 14:49
A VETERAN IS SOMEONE WHO AT ONE POINT WROTE A BLANK CHECK MADE PAYABLE TO THE UNITED STATES OF AMERICA FOR AN AMOUNT OF UP TO AND INCLUDING THEIR LIFE. |
Whoops, can't get pics to work here for some reasons. I have several good ones of the car. You can e-mail me at corvetteronw@hotmail.com and I will send them to you.
Posted on: 2008/2/26 14:52
Quote: I just did a search for "World Castings," IIRC. |
Posted on: 2008/2/26 15:43
Crazy8 | RE:LS2 swap into early C4? | ||
Whoops, can't get pics to work here for some reasons. I have several good ones of the car. You can e-mail me at corvetteronw@hotmail.com and I will send them to you. Thanks, email sent. Depending on pricing to do this, I may end up going back to the Gen I block and just doing a stroker with a carb. My 86 is going to see 70% track, 30% street duties. Thanks for all the posts...if anyone has any more insight, I'd love to hear it!! |
Posted on: 2008/2/26 21:19
Raidmagic | RE:LS2 swap into early C4? | ||
You can buy 69 myways for 10 grand. A boat load eaiser than doing it yourself.
Posted on: 2008/3/2 3:42
Stroke that LS2, great heads and put in a solid roller, youll have a 10 sec car you can drive anywhere. Im sold. The way is pulls from 100 to 140/160 will knock your socks off. Pulling HARD and sideways at 90 will make you religious. http://www.youtube.com/watch?v=kvZ5sl3Sn1c http://www.youtube.com/watch?v=YLPEhoDvgiU&feature=related |
Posted on: 2008/3/2 5:04
You can buy 69 myways for 10 grand. A boat load eaiser than doing it yourself. 1st off, Raid...happy to have you aboard 2nd...he's right! Unless you just want to do it yourself, 69's would be the way to go. Everything on that car works like factory, air, the works! All except 2 of the digidash stations, I think they were volts and average MPG or some such nonsense. I've seen his car 1st hand and it's beautiful. The installation looks factory, the motor is still under warranty and the car is daily driven by his wife. 10k is a hell of a lot cheaper than DIY for the most part. If i had an extra 10k, It would be in my driveway |
Posted on: 2008/3/2 5:48
SpeedHound | Re: LS2 swap into early C4? | ||
man the threads I miss while being busy.
Yes, I have adapter plates and headers available for this swap. As well as pretty much anything else needed. No cutting on the car is required with my plates. That's a personal preference though as not cutting on the car requires you to do something about the AC. The LS2 compressor mounts on the lower passenger side of the engine. The motor mount horn on that side is in the way. You know you can always run a carb on that LS2. I can get you the manifold and other parts needed to do it. |
Posted on: 2008/3/3 2:59
