184 user(s) are online (86 user(s) are browsing Forums)
1st Gear: 2.52
2nd Gear: 1.52
- 13 Bolt ...
matts85vet engine break-in oil and filter
Toledo, Ohio
58 Posts
what do you guys usually use? how long before you change it?
thanks!
Posted on: 2014/1/18 2:47
bogus Re: engine break-in oil and filter
filter? K&N.
Oil? I use basic Castrol GTX, but you may want to check out the high-zinc content racing oils.
Also, I change mine out about 100 miles in and again at 1000, then it should be ok.
I would change to synthetic at about 4k to 5k miles.
Posted on: 2014/1/18 4:20
Matatk Re: engine break-in oil and filter
22810 Posts
Flat tappet cam? If so, buy the special, expensive break in oil that contains zinc for flat tappet cams. Do not use synthetic for break in.
I changed my break in oil at 20 minutes, then 500 miles, then 1500 miles, then 3000 miles. Overkill, but cheap insurance.
Posted on: 2014/1/18 12:32
matts85vet Re: engine break-in oil and filter
Toledo, Ohio
58 Posts
thanks for the replies!
it's a retrofit roller cam. the guy at oreily's suggested mobil 1 synthetic plus lucas additive.
do you reuse the same oil filter after you change the oil at 20 min. or 100/500 miles? or is it a new filter each time?
Posted on: 2014/1/18 14:26
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
BillH Re: engine break-in oil and filter
We don't even do that with race engines, and the pro builders don't.
Warm it up, run it to readline in a couple gears, the rings will be seated.
Run it a few miles and change to synth, done.
Posted on: 2014/1/18 14:38
22810 Posts
Well Bill, you are welcome to do that but I don't have the luxury of rebuilding my motor every season.
Posted on: 2014/1/18 17:01
I don't do it on street motors either Matt.
And I got 100,000+ on the last one.
Posted on: 2014/1/18 18:29
BrianCunningham Re: engine break-in oil and filter
Builder said he would have broke it in on the dyno, but I needed to get 200 miles on the clutch 1st in order to break it in.
Posted on: 2014/1/18 19:52
Danspeed1 Re: engine break-in oil and filter
Mooresville, North Carolina
1121 Posts
Posted on: 2014/2/5 17:46
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
