247 user(s) are online (178 user(s) are browsing Forums)
j3studio Thoughts On Recovering A Small Rubber Part?
The 90 degree rubber connector for the CCV in my emissions system is A) loose and B) somewhat heat damaged. Finding a replacement has so far proven to be impossible - I can't even find a part number for it.
Does anyone have any thoughts on anything that could be done to recover this connector at least a little bit?
Posted on: 2014/4/25 12:30
hcbph Re: Thoughts On Recovering A Small Rubber Part?
269 Posts
I don't know if it's the same part or not, but I had a 90 degree fitting that went from the tube off the pcv valve into the intake that had been replaced with a piece of heater hose on mine when I bought it. Mine was heat damaged and collapsed also.
The hose was 1/2" heater hose so I went to NAPA for a replacement - no luck. They did let me look around in back at the various preformed hoses to see if I could see something that would work and I did find one. I found a preformed hose with a 90 degree bend in it. I cut it down to the length I needed from the bend and it went on perfect.
I may still have the end with the NAPA number on it, if that sounds like what you're looking for, PM or email me and I'll see if I can dig it up. May take me a couple of days to get to it though.
Hope that helps.
Posted on: 2014/4/25 12:55
BillH Re: Thoughts On Recovering A Small Rubber Part?
If you can't find an elbow.
Plasti-Dip might work, it's the stuff you dip a tool in to put a rubber coating on the handles. Also known as Rubber Dip.
Corvette restorers sometimes use it to make the rubber coated J clips that hold the wire harness on the firewall.
Posted on: 2014/4/25 13:44
bogus Re: Thoughts On Recovering A Small Rubber Part?
GM Part numbers... ask and ye shall receive...
Grommet - 3989349
Hose (looks like 90*) - 14082442
Try xrefing those numbers at RockAuto or call up Chris May at Superior Chevy...
Posted on: 2014/4/25 14:02
j3studio Re: Thoughts On Recovering A Small Rubber Part?
GM Part numbers... ask and ye shall receive... Grommet - 3989349 Hose (looks like 90*) - 14082442 Try xrefing those numbers at RockAuto or call up Chris May at Superior Chevy...
Andy,
The part in question is much shorter, but you've given me some good ideas. Thank you.
Posted on: 2014/4/25 15:23
joeld Re: Thoughts On Recovering A Small Rubber Part?
I "think" I used this one awhile back on a SBC engine, Not 100% sure.
http://www.summitracing.com/parts/rnb ... Pa92pL8-70CFdEF7Aodgl0AlA
Posted on: 2014/4/25 15:41
j3studio wrote:
Andy,
Where on the engine is this part?
Posted on: 2014/4/25 16:23
Three pictures: one of them of the general area, a close-up, and the actual part.
jpg  generalview.jpg (114.52 KB)
718_535ac9212212e.jpg 600X400 px
jpg  inclose.jpg (151.16 KB)
718_535ac92f53cb2.jpg 533X800 px
jpg  actualpart.jpg (80.11 KB)
718_535ac93871448.jpg 600X400 px
Posted on: 2014/4/25 20:40
I will check tonight.
Posted on: 2014/4/25 21:16
I know other things happenned ...
... can you take a look?
Posted on: 2014/5/1 2:56
yes I will! Hadn't forgotten... you are quite right, many things have happened...
Posted on: 2014/5/1 17:33
these should be the numbers you need:
14082445
14087567
14082446
Posted on: 2014/5/2 5:01
14082445
14087567
14082446
Thank you, Andy - ordered. By the way, two out of three of these parts don't even show up in the 1985 Y-body parts manual ...
bandhead
Posted on: 2014/5/10 20:11
ah... You see... I have the entire Corvette parts fiche in PDF format... Trust me, I don't memorize all of this crap!
Posted on: 2014/5/10 21:39
A final update here. The rubber part that I needed and that Andy tracked down turned out not to exist anywhere.
I ended getting up an HPS high temperature silicone hose (designed for turbo applications) with a ninety degree bend and cutting it to fit. It's tight in there and I'll need to color the ends black, but it seems to be working.
Posted on: 2015/7/4 20:12
I am not surprised you couldn't find the parts...
I am finding more and more generic parts through the HELP! line at the various autoparts stores...
Posted on: 2015/7/5 21:44
BrianCunningham Re: Thoughts On Recovering A Small Rubber Part?
Pep Boys has a really great selection of that stuff.
Used it for reliability test rigs
Posted on: 2015/7/5 23:20
CentralCoaster Re: Thoughts On Recovering A Small Rubber Part?
Damn, I got all excited and crawled into my parts bin, but then realized I have the wrong elbow, to the valve cover part.
1st world problems!
It's like that damn mcdonalds monopoly game all over again. Dorman (Help!) has a decent selection of doodads, some of which are the same fit as factory parts, but you'd never find them listed properly for the application. Here's a start, may at least be something that looks closer to stock. I assume you already checked the catalogs for aftermarket replacments.
https://www.google.com/search?q=pcv+el ... IlfehpbnIxgIVzpSICh1V9AD2
Posted on: 2015/7/7 7:03
CorvetteBob Re: Thoughts On Recovering A Small Rubber Part?
1409 Posts
Now wait just one minute.....
Isn't the GRAND Imperial Poobah s'posed to have it memorized?
I thought the "GRAND" was for the superhuman capacity you possess. Does this mean you're actually a "Normal" Imperial Poobah?
This is just too much for me to take in....
Posted on: 2015/7/9 0:25
