277 user(s) are online (238 user(s) are browsing Forums)
[IMG]http:/...
jonszr1 just got the best allignment ever
Lone Pine, CA
well went to visit my buddy the zfdoc , bill boudreau and had him and his partner ck over my suspension over as well as get her aligned . they have a trick setup that starts by what they call xing the car to make sure it is straight and then they align it . it is the same set up that they use in nascar . the car is also balance by weight on each wheel .the cost is 200 but it is the best money I have ever spent. they also fixed some shock problems I had. so if you live in the phoenix area go to see them and you will love the results the same as I did .
Posted on: 2014/6/3 6:21
Matatk Re: just got the best allignment ever
Did he give you the specs?
Posted on: 2014/6/3 14:32
bogus Re: just got the best allignment ever
"xing" the car isn't a new concept... most Hunter rigs do it now... they use the lazers to make sure the car is square and there isn't anything amiss with the frame alignment or the overall squareness of the suspension pickups.
I assume the NASCAR alignment is a road coarse setup? Otherwise, right turns could be a bitch!
Posted on: 2014/6/3 15:08
jonszr1 Re: just got the best allignment ever
Lone Pine, CA
he didn't give me the specs,i didn't ask he knows how I drive the car and set. it up accordingly . all I know is it handles better than ever.guess that is the weight balancing .
Posted on: 2014/6/3 21:01
you have coil overs, right?
Posted on: 2014/6/3 21:09
NelsonV Re: just got the best allignment ever
Sunny Southern CA
245 Posts
bogus wrote:I assume the NASCAR alignment is a road coarse setup? Otherwise, right turns could be a bitch!
Posted on: 2014/6/3 22:43
BrianCunningham Re: just got the best allignment ever
Nascar equipment guys
Posted on: 2014/6/4 23:10
Lone Pine, CA
yes I have coil overs. his set up ,he removes the wheels and then puts on the devices to do the alignment with weight pads attached to them . interesting setup.it took him a good 90 minutes to do it. and for what it is worth my car drives better than it ever has .might be best to contact them about all the particulars. for my monet I was very happy with the results
Posted on: 2014/6/8 16:23
I have seen those rigs before. Much more precise in some respects...
For anyone reading this however many years into the future... the stock C4 suspension is not adjustable for corner weights. The OEM transverse leaf spring setup simply will not allow for any corner adjustments.
Now, if you convert over to coil over shocks, meaning the spring is a conventional coil, wrapped around the shock, will allow for such changes.
Posted on: 2014/6/8 17:04
