-=Jeff=- | Modified Console and Radio Bezel | ||
So my vette has a 94 Console driver side (I feel the finish looks better)
it currently looks like this: But the Console is bowed at the passenger side and I don't care for the edge of the Radio Bezel. I had cut the 94 bezels to fit. Now I am working on grafting the 94 to the 91 bezels.. Here is the console: the start of the Radio Bezel (I am still working on it) |
Posted on: 2014/7/7 2:11
teebee | Re: Modified Console and Radio Bezel | ||
Wow, look like work. But it should be good when you're done.
Posted on: 2014/7/7 14:50
2007 Atomic Orange 3LT coupe. Borla Exhaust One of Americas' proud Deplorable |
-=Jeff=- | Re: Modified Console and Radio Bezel | ||
Console has been easier, partly because I started with the Radio bezel. Now when I do the next Radio bezel I have a different way to try it and potentially make it a bit easier.
Posted on: 2014/7/7 14:55
bogus | Re: Modified Console and Radio Bezel | ||
what glue(s) are you using?
Looks great!!! |
Posted on: 2014/7/7 15:02
I am mixing this:
with ABS Pellets I bought off eBay to make a MEK solution, I had it really thick but I have found that a thinner/runnier solution seems to work really well. I am very close on the Radio bezel and the nice thing of the MEK is it bonds quite nice and is solid |
Posted on: 2014/7/7 15:13
interesting... filler and glue in one mess... Thanks!!!
Posted on: 2014/7/7 15:26
Yes, but more than glue.. the mixture will melt the ABS pellets and it melts essentially to the bezel.. the bond is seriously solid
Posted on: 2014/7/7 15:33
pianoguy | Re: Modified Console and Radio Bezel | ||
Very cool! That is kind of how the Plastex stuff works - it turns into a moldable goo that hardens into plastic.
Posted on: 2014/7/7 18:07
Matatk | Re: Modified Console and Radio Bezel | ||
Do you have comparison pics of the two bezels before?
Nice work. |
Posted on: 2014/7/7 19:58
I don't have one of the Console, but can get one (I have like 3 or 4 console plates)
Here is the ZR-1 1990 bezel and my modded one in early stages I had to open up the Radio bezel for my tablet as well.. I will get a more recent picture of the radio bezel soon |
Posted on: 2014/7/7 20:13
that's the basic premise behind plastic model glue, but it won't do that to ABS. |
Posted on: 2014/7/7 21:33
here is the radio bezel:
the dark spots are my MEK (very thin mix) to try and fill the voids.. It is in primer so I can see all the voids and such while sanding it. I am quite happy with it so far I still need to add 2 holes to the bezel for my Volume and balance. The radio hole has been opened another 1/2" for the tablet as well |
Posted on: 2014/7/8 13:34
looks awesome! Have you considered some body filler instead?
Posted on: 2014/7/8 15:29
yes I did, but getting the mix just right...
Although I did use that on the console.. On this, the panel needed more of a build up and I wanted it to be solid.. this is working really well for me now |
Posted on: 2014/7/8 15:48
cool. I will have to check into that stuff.
If you can, some mix ratios would be nice! |
Posted on: 2014/7/8 16:13
It was also a guessing game.. more acetone, the more it is liquid.. more abs the more it is like caramel consistency
adjust to what you are doing |
Posted on: 2014/7/8 18:03
I think the Radio is ready for primer then paint:
Posted on: 2014/7/9 3:12
ok, that helps... more or less the same thickness as a 2 part epoxy And yes, it's looking REAL sharp!!!! |
Posted on: 2014/7/10 15:18
ready for paint
Posted on: 2014/7/15 18:53
that is impressive.
Posted on: 2014/7/15 20:30
Well it could be better but for a first attempt it is not too bad
Posted on: 2014/7/15 21:42
Looks very smooth and consistent.
Posted on: 2014/7/16 4:03
96LT4CE | Re: Modified Console and Radio Bezel | ||
Nice fab work.
Make sure you don't shoot the foot when you lay down the paint |
Posted on: 2014/7/16 4:15
My shoulder hurts bad |
Not quite perfect..
But will work for now Now I need to fix the door for the console and paint that **Disclaimer** foot was saved form being painted |
Posted on: 2014/7/17 2:58
the holes on the right are for Volume and Balance
just relocated from the previous panel |
Posted on: 2014/7/17 3:00
that does look most excellent!
Posted on: 2014/7/17 16:11
Matatk,
Here is a comparison of the OEM Bezel and my Bezel I will start on a second one now Here are the new panels installed. I used an older Ash Tray door as I have not finished refinishing the others Switches Left to Right: Amps Antenna Push button is Tablet power, lower toggle is Volume |
Posted on: 2014/7/21 3:16
that is serious work, Jeff. Well done and it looks EXCELLENT!
I sure hope it was worth it from a sonic perspective!!! |
Posted on: 2014/7/21 23:40
YEs an no..
Sonically it sounds great with Pandora/Slacker/ USB music With the Tuner, it could be better, but my Antenna is fubar, it rained the other night and I could not receive any stations. On clear days I need to exercise the antenna a couple times to get good reception (no fault of the system) I added the switches since there is no remote turn on out of the amp. I wish I could find a Audio sensing circuit for the amps.. in the end all the bezel work was more for the 95 side panel.. on the driver side not the radio, I will build 2 more panels but not cut yet for the Tablet.. |
Posted on: 2014/7/22 2:26
Very cool!
Posted on: 2014/7/22 12:19
Just bought another radio bezel to start widening..
I really prefer the 94-96 driver side console side, due to fit and finish. I thought I would prefer the 94-96 radio and console bezels, but after doing the work I did on the 91 bezel, I changed my mind. The one I bought is rough so it will be a fun project to rebuild. Keep in mind the new bezel I installed really was a first pass.. |
Posted on: 2014/7/22 12:40
I am going to remove my electric and go with a fixed short mast antenna... the new look... mostly because the electrics fail! |
Posted on: 2014/7/22 15:14
I thought of that route. with mine I don't know if it is the mast or the whole assembly. I have an assembly with the mast (not sure of the mast condition)
I have also tried the Tune Trapper (in the garage) and at one point it was better than the Mast.. Although a hidden will never be as good as a mast, just not sure which route to go |
Posted on: 2014/7/22 15:20
I understand your problem... I would love to do one of those cool sharkfin antenna's, but I don't know where to put it... the OEM location fades away and the fin would be leaning to port!
Posted on: 2014/7/24 16:22
SO I drove the car today..
Seemed to get better reception, I still think the Antenna is hosed. I will try the Tune Trapper hidden antenna I have, It was working really well in my basement for testing purposes anyway Updated pic: With the bezel being opened more I can press the home, back, and apps buttons easier. also looks more centered but I did nothing side to side. Volume and balance controls might be a bit too close, but it is different than before so they might be fine.. |
Posted on: 2014/7/24 16:35
that looks great! Lovely job!
I love the wallpaper on the tablet! PERFECT. Now... if we can figure out how to control things via the tablet... I have some thoughts... |
Posted on: 2014/7/24 23:45
there are some ways.. Arduino... or the IOIO..
maybe someday.. I need to learn Arduino programming first |
Posted on: 2014/7/25 2:42
Posted on: 2014/7/25 2:57
Raspberry.
Posted on: 2014/7/25 16:44
The thing with Raspberry is current draw.. Raspberry draws more current than Arduino, so depending on how it is powered etc..
This is cool too.. http://www.udoo.org/ basically android with Arduino Due all in one |
Posted on: 2014/7/25 17:51
time to research...
we will talk soon!! I was on the phone to AT&T way too late in the evening Friday... ugh... |
Posted on: 2014/7/27 19:29
back from traveling..
Going to start on my second radio bezel (basically going to make it fit the console for now. not adding anything else until I wrap up everything with the tablet... I still need to either find an audio sensing circuit already built or build one. that would work to handle the turn on of the amps, I will keep the toggle switch, but this would be seemless |
Posted on: 2014/8/12 12:28
Schrade | Re: Modified Console and Radio Bezel | ||
Coin slot buttons?
Nitrous, Methanol, and parachute? Quote: |
Posted on: 2014/8/16 2:09
Left to Right
Amp On/Off Antenna on/off Button, Tablet power Toggle Tablet volume Now I need to find a USB Audio input |
Posted on: 2014/8/16 3:58
cool.
Posted on: 2014/8/17 0:14
starting version 2. Not sure I will cut this one for the tablet just yet
Posted on: 2014/9/2 3:20
Looks like your starting bond in pic 1 is done with a slight gap there Jeff; is that deliberate?
Do you get more bonding agent in the gap like that? |
Posted on: 2014/9/2 14:21
No the gap is due to cutting both pieces with a coping saw, by hand it does help for bonding as well by having the goop get between the 2 pieces. This bezel so far has much less bonding material so far, I think it will look much better when complete. I am also thinking of building out the radio side and getting the tablet mounted to the bezel, it will make for a clean and better flush mount on the user side |
Posted on: 2014/9/2 15:15
this one will take much less work to get it smooth
Posted on: 2014/9/3 4:00
this bezel is working out much better
Posted on: 2014/9/10 2:14
